<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Report Relay state to GW]]></title><description><![CDATA[<p dir="auto">Good morning everybody I have following Problem:</p>
<p dir="auto">My controller (pimatic) opens via Gateway my Relay which activates a magnetic valve to fill my pond. depending on the water level, measured by my distance sensor.<br />
By rule pimatic closes the relay if the distance is less or equal to 14cm. NOW: one out of ten my communication fails and pimatic changes the state of the switch in the frontend, therefor the controller thinks the relay is off (valve closed) But in the GW debug I see the the message to turn of was NOACK. Meaning the water keeps running and my pond overflows.</p>
<p dir="auto">After reading everything I found Pimatic does not resend when NOACK or refuses Statechange when noack. IS IT POSSIBLE to report the state of the relay to the controller periodically like every time a distance Message gets send? Like correcting the "Wrong" state in the controler?</p>
<p dir="auto">Here is my node Sketch:</p>
<pre><code class="lang-#include">
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Version 1.0 - Henrik Ekblad
 * Example sketch for a "light switch" where you can control light or something
 * else from both HA controller and a local physical button
 * (connected between digital pin 3 and GND).
 * This node also works as a repeader for other nodes
// Enabled repeater feature for this node
#define MY_REPEATER_FEATURE
#include &lt;SPI.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;Bounce2.h&gt;
#include &lt;NewPing.h&gt;
#define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
#define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
#define CHILD_ID_RELAY 1   // Id of the sensor child
#define RELAY_ON 1
#define RELAY_OFF 0
#define CHILD_ID_DIST 10
#define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
MyMessage msgDist(CHILD_ID_DIST, V_DISTANCE);
int lastDist;
bool metric = true;
Bounce debouncer = Bounce();
int oldValue=0;
bool state;
MyMessage msgRelay(CHILD_ID_RELAY,V_LIGHT);
long previousMillis = 0;        // will store last time Distance was measured
long interval = 10000;           // interval at which to measure (milliseconds)
  // Setup the button
  pinMode(BUTTON_PIN,INPUT);
  // Activate internal pull-up
  debouncer.attach(BUTTON_PIN);
  debouncer.interval(1);
  pinMode(RELAY_PIN, OUTPUT);
  state = loadState(CHILD_ID_RELAY);
void presentation()  {
  sendSketchInfo("Relay &amp; Button Distance", "1.0");
  present(CHILD_ID_RELAY, S_LIGHT);
  present(CHILD_ID_DIST, S_DISTANCE);
  debouncer.update();
  // Get the update value
  int value = debouncer.read();
  if (value != oldValue &amp;&amp; value==0) {
      send(msgRelay.set(state?false:true), true); // Send new state and request ack back
  oldValue = value;
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  if(currentMillis - previousMillis &gt; interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
int dist = metric?sonar.ping_cm():sonar.ping_in();
  Serial.print("Ping: ");
  Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
  Serial.println(metric?" cm":" in");
  if (dist != lastDist) {
      send(msgDist.set(dist));
      lastDist = dist;
 // sleep(SLEEP_TIME);
void receive(const MyMessage &amp;message) {
  if (message.isAck()) {
     // Change relay state
     state = message.getBool();
     // Store state in eeprom
     saveState(CHILD_ID_RELAY, state);
     // Write some debug info
     Serial.print(message.sensor);
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/9547/report-relay-state-to-gw</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 09:36:51 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9547.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Jul 2018 07:09:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Report Relay state to GW on Wed, 18 Sep 2019 13:51:56 GMT]]></title><description><![CDATA[<p dir="auto">Asking the controller at startup: issue a request, see <a href="https://www.mysensors.org/download/sensor_api_20#requesting-data" rel="nofollow ugc">https://www.mysensors.org/download/sensor_api_20#requesting-data</a>, imo you should as for V_STATUS.</p>
<p dir="auto">Then your controller should respond, the response is handled by the receive()-function (=no action needed), but to get this to work, your node should not sleep (you sketch seems to be incomplete wrt. that).<br />
But you should first switch off everyhing to have it in a defined state and avoid loading values from the EEPROM.</p>
<p dir="auto">Wrt. to regular status info: If that's necessary, you should try to use a so called "non blocking loop", use g**gle or similar for that. Imo, it's not necessary to update the value as it doesn't change. Better use the heartbeat funcionality instead (dependend on your controller).</p>
]]></description><link>https://forum.mysensors.org/post/101355</link><guid isPermaLink="true">https://forum.mysensors.org/post/101355</guid><dc:creator><![CDATA[rejoe2]]></dc:creator><pubDate>Wed, 18 Sep 2019 13:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to Report Relay state to GW on Wed, 18 Sep 2019 09:27:47 GMT]]></title><description><![CDATA[<p dir="auto">Think I got the button now working on the node and just informing the controler, cant figure out to ask the controller for the state on startup and how to send periodicly the relay state</p>
<pre><code>void presentation()  {
  debouncer.update();
      digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); //realy state change on the node?
      send(msgRelay.set(state?false:true)); // Send new state
  oldValue = value;
      send(msgRelay.set(state?false:true), true); //Do I send relay status here?
      lastDist = dist;
  sleep(SLEEP_TIME);
</code></pre>
]]></description><link>https://forum.mysensors.org/post/101353</link><guid isPermaLink="true">https://forum.mysensors.org/post/101353</guid><dc:creator><![CDATA[Philipp Geis]]></dc:creator><pubDate>Wed, 18 Sep 2019 09:27:47 GMT</pubDate></item><item><title><![CDATA[Reply to Report Relay state to GW on Tue, 17 Sep 2019 10:58:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rejoe2" aria-label="Profile: rejoe2">@<bdi>rejoe2</bdi></a>  THANKS !!!! I Will post again with edited sketch... but will take some time! Thanks alot!</p>
]]></description><link>https://forum.mysensors.org/post/101340</link><guid isPermaLink="true">https://forum.mysensors.org/post/101340</guid><dc:creator><![CDATA[Philipp Geis]]></dc:creator><pubDate>Tue, 17 Sep 2019 10:58:27 GMT</pubDate></item><item><title><![CDATA[Reply to Report Relay state to GW on Tue, 17 Sep 2019 10:56:01 GMT]]></title><description><![CDATA[<p dir="auto">Based on the great sketch korttoma posted <a href="https://forum.mysensors.org/post/51488">here</a>, the following <em>could</em> work:</p>
<pre><code>// Enable debug prints to serial monitor
#define SN "RelayButtonArray"
#define SV "1.0"
#define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
#define RELAY_OFF 1
#define noRelays 4                     //2-4
const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
class Relay             // relay class, store all relevant data (equivalent to struct)
  public:
    int buttonPin;                   // physical pin number of button
    int relayPin;             // physical pin number of relay
    boolean relayState;               // relay status (also stored in EEPROM)
Relay Relays[noRelays];
Bounce debouncer[noRelays];
MyMessage msg[noRelays];
  void before() {
  for (int sensor=1, pin=RELAY_1; sensor&lt;=NUMBER_OF_RELAYS;sensor++, pin++) {
    pinMode(pin, OUTPUT);
        digitalWrite(pin, RELAY_OFF); //digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
  wait(100);
  // Initialize Relays with corresponding buttons
  for (int i = 0; i &lt; noRelays; i++) {
    Relays[i].buttonPin = buttonPin[i];              // assign physical pins
    Relays[i].relayPin = relayPin[i];
    msg[i].sensor = i;                                   // initialize messages
    msg[i].type = V_LIGHT;
    pinMode(Relays[i].buttonPin, INPUT_PULLUP);
    wait(100);
    //Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
	// digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
    //send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
    wait(50);
    debouncer[i] = Bounce();                        // initialize debouncer
    debouncer[i].attach(buttonPin[i]);
    debouncer[i].interval(30);
    wait(50);
  sendSketchInfo(SN, SV);
  wait(100);
    present(i, S_LIGHT);                               // present sensor to gateway
    request(i, V_LIGHT); //...not sure if this is the right syntax
  wait(100);
  for (byte i = 0; i &lt; noRelays; i++) {
    if (debouncer[i].update()) {
      int value = debouncer[i].read();
      if ( value == LOW) {
        // save sensor state in EEPROM (location == sensor number)
        //saveState( i, Relays[i].relayState );
  //wait(20);
    if (message.sensor &lt; noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor &lt;=noRelays){ ]]]
      digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
      //saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
  wait(20);
</code></pre>
<p dir="auto">I tried to just comment out things not needed, so you might find it easier to understand the differences between loading from EEPROM and requesting the state from controller side.</p>
]]></description><link>https://forum.mysensors.org/post/101339</link><guid isPermaLink="true">https://forum.mysensors.org/post/101339</guid><dc:creator><![CDATA[rejoe2]]></dc:creator><pubDate>Tue, 17 Sep 2019 10:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to Report Relay state to GW on Tue, 17 Sep 2019 10:35:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rejoe2" aria-label="Profile: rejoe2">@<bdi>rejoe2</bdi></a>  Hi sorry but I  never really solved this problem but u are totally right!</p>
<p dir="auto">since I am not really firm with writing sketch this was my first attempt. The sketch works as long as i have communication. to the controller as soon as I Dont have communication nothing works as it should.</p>
<p dir="auto">How can I ask the controller about the desired state?</p>
<p dir="auto">How can i make the button work on the node but report the state change to the controller?</p>
<p dir="auto">can i just kill the code where i update von eeprom?</p>
<p dir="auto">I would be greatfull for any indication!</p>
<p dir="auto">I will post my own attemps as soon as I figured out what i am doing :relaxed: :joy:</p>
<p dir="auto">Thanks Philipp</p>
]]></description><link>https://forum.mysensors.org/post/101338</link><guid isPermaLink="true">https://forum.mysensors.org/post/101338</guid><dc:creator><![CDATA[Philipp Geis]]></dc:creator><pubDate>Tue, 17 Sep 2019 10:35:46 GMT</pubDate></item><item><title><![CDATA[Reply to Report Relay state to GW on Tue, 31 Jul 2018 08:00:32 GMT]]></title><description><![CDATA[<p dir="auto">It's pretty easy to send back the actual state of the relay.</p>
<p dir="auto">But imho there are several options to improve the behaviour of the whole thing:</p>
<ul>
<li>if it's more secure to start the whole thing with the relay switched off instead of reading value from EEPROM. Then ask the controller about the desired state and keep it off until message arrives or button is pressed?</li>
<li>keep track of the actual state of your relay within the loop(). By now, the switching logic of the button/switch seems to be weired. Does this work as expected?</li>
<li>if it's a security function: let the node decide whether the relay should be switched off, dependend on the meassured value and the state of the relay. Just inform the controller it had been switched off.</li>
</ul>
<p dir="auto">It might be necessary to add some overriding functionality (eg. keep relay on for x minutes if it has been switched on using the button and so on).</p>
]]></description><link>https://forum.mysensors.org/post/92088</link><guid isPermaLink="true">https://forum.mysensors.org/post/92088</guid><dc:creator><![CDATA[rejoe2]]></dc:creator><pubDate>Tue, 31 Jul 2018 08:00:32 GMT</pubDate></item></channel></rss>
