<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] Raspberry PI gateway]]></title><description><![CDATA[<p dir="auto">Hi.<br />
Just install RPi gateway 2.3.0 and add it to Vera<br />
inclusion button inactive - both grey.??<br />
Please help</p>
]]></description><link>https://forum.mysensors.org/topic/9680/solved-raspberry-pi-gateway</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 08:06:26 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9680.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Sep 2018 08:23:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] Raspberry PI gateway on Wed, 05 Sep 2018 16:37:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cadet" aria-label="Profile: cadet">@<bdi>cadet</bdi></a> Great to hear you solved it and thanks for the feedback! :+1:</p>
]]></description><link>https://forum.mysensors.org/post/93258</link><guid isPermaLink="true">https://forum.mysensors.org/post/93258</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Wed, 05 Sep 2018 16:37:01 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Raspberry PI gateway on Wed, 05 Sep 2018 12:36:57 GMT]]></title><description><![CDATA[<p dir="auto">Found</p>
<p dir="auto">anvil 2 years ago<br />
Solved - user error 🙂<br />
Inside the Raspberry Pi setup (file /MySensors/examples_linux/mysgw.cpp), the inclusion mode define must be added:<br />
#define MY_INCLUSION_MODE_FEATURE<br />
This is present in the Serial &amp; Ethernet gateway example ino files, just missing from the Raspberry Pi version as it is on GitHub.</p>
<p dir="auto">With this added, the response to the StartInclusion mode request is then received &amp; everything is fine:</p>
<p dir="auto">TX(fromController)	0;0;3;0;5;1<br />
RX(fromRaspberryPiGateway)	0;255;3;0;5;1<br />
On the plus side, by working this out I'm a lot more familiar with the workings of MySensors!</p>
<p dir="auto">Cheers!</p>
<p dir="auto">1</p>
]]></description><link>https://forum.mysensors.org/post/93251</link><guid isPermaLink="true">https://forum.mysensors.org/post/93251</guid><dc:creator><![CDATA[cadet]]></dc:creator><pubDate>Wed, 05 Sep 2018 12:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Raspberry PI gateway on Wed, 05 Sep 2018 11:58:47 GMT]]></title><description><![CDATA[<p dir="auto">install 2.1.1 - same problem<br />
try another Vera - same problem<br />
I have arduino GW on that Vera and it work fine<br />
But no inclusion with RPi<br />
????</p>
]]></description><link>https://forum.mysensors.org/post/93250</link><guid isPermaLink="true">https://forum.mysensors.org/post/93250</guid><dc:creator><![CDATA[cadet]]></dc:creator><pubDate>Wed, 05 Sep 2018 11:58:47 GMT</pubDate></item></channel></rss>
