<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My sensors Arduino connection via USB to Rpi &#x2F; Ethernet Shield in Home Assistant help needed]]></title><description><![CDATA[<p dir="auto">Hi guys. I am beginner at Mysensors but I really enjoy this IoT idea. I would like to connect my Arduino with Mysensors sketch nto Home Assistant in Raspberry Pi. In Home Assistant there is a connection method done (I just need to add some code into my configuration.yaml file - <a href="https://www.home-assistant.io/components/mysensors" rel="nofollow ugc">https://www.home-assistant.io/components/mysensors</a>).<br />
Long story short... I have one relay for test and I try to use some sketchet. Unfortunately I cannto use any sketch, After connecting to Rpi it throws 2 warnings:<br />
Not a valid message: not enough values to unpack (expected 5, got 0)<br />
Error decoding message from gateway, bad data received: 8943007 TSF:TDI:TSL</p>
<p dir="auto">And I have no sensors. What should I do? Maybe I need to create a serial gateway before connecting to USB? Please help I am totally noob in this subject.</p>
<p dir="auto">P.S I didn't connect nothing to Arduino (no radion, just relay). Should I buy and use NRF24L01 or any other radio? Is this neccessary connecting via USB / Ethernet shield?</p>
]]></description><link>https://forum.mysensors.org/topic/9701/my-sensors-arduino-connection-via-usb-to-rpi-ethernet-shield-in-home-assistant-help-needed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 09:10:32 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9701.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Sep 2018 21:14:29 GMT</pubDate><ttl>60</ttl></channel></rss>
