<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Jumpering IC pins]]></title><description><![CDATA[<p dir="auto">I have a bit of an issue. I’d like to replace the voltage regulator on an 5v Arduino with a 3.3v regulator. Both are 5 pin and the input on both is the same pin (pin number 1).  2, 3 and 4 are also unused on the 5v with the output on pin 5.  My problem is that on my regulators the output pin is 4 and 5 is unused. In this case can you just jumper pin 4 and 5 with a small wire on the new regulator since 5 is unused but on the PCB that is where the output needs to be?</p>
]]></description><link>https://forum.mysensors.org/topic/9781/jumpering-ic-pins</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 19:11:54 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9781.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Oct 2018 16:56:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Jumpering IC pins on Mon, 08 Oct 2018 18:13:40 GMT]]></title><description><![CDATA[<p dir="auto">Well the replacement regulator datasheet says that pin 5 its not connected to anything so I'm assuming that it doesn't matter.  With regard to the PCB, I don't know the answer to that and didn't really consider that.  I don't have the actual schematic but my understanding is that all Arduino Mini Pro's are made from the same schematic so if so, pin 4 per the schematic is "bypass" and is not attached to anything on the PCB.</p>
]]></description><link>https://forum.mysensors.org/post/94215</link><guid isPermaLink="true">https://forum.mysensors.org/post/94215</guid><dc:creator><![CDATA[thecricketer]]></dc:creator><pubDate>Mon, 08 Oct 2018 18:13:40 GMT</pubDate></item><item><title><![CDATA[Reply to Jumpering IC pins on Mon, 08 Oct 2018 17:21:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thecricketer" aria-label="Profile: thecricketer">@<bdi>thecricketer</bdi></a> I’d say it depends on the layout of the pcb (does pin 4 go anywhere?), and the specifications of the regulator (does it allow to put 3.3V on pin 5?).</p>
]]></description><link>https://forum.mysensors.org/post/94214</link><guid isPermaLink="true">https://forum.mysensors.org/post/94214</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Mon, 08 Oct 2018 17:21:47 GMT</pubDate></item></channel></rss>
