<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nodo 485]]></title><description><![CDATA[<p dir="auto">this is the message sent by the well known Arduino 2009 :<br />
TSF: MSG: SEND, 9-9-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, v = OK:<br />
this is the message sent by the well known Arduino micro ;<br />
TSF: MSG: SEND, 255-255-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, v = OK:<br />
the program is the same for the two cards<br />
how does this happen?</p>
]]></description><link>https://forum.mysensors.org/topic/9809/nodo-485</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 00:59:15 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9809.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Oct 2018 16:24:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nodo 485 on Fri, 19 Oct 2018 19:20:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bocmau" aria-label="Profile: bocmau">@<bdi>bocmau</bdi></a> that's very strange. Which controller are you using?</p>
]]></description><link>https://forum.mysensors.org/post/94483</link><guid isPermaLink="true">https://forum.mysensors.org/post/94483</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Fri, 19 Oct 2018 19:20:44 GMT</pubDate></item><item><title><![CDATA[Reply to Nodo 485 on Fri, 19 Oct 2018 16:53:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> said in <a href="/post/94477">Nodo 485</a>:</p>
<blockquote>
<p dir="auto">that's a strange format of the debug log. Where does it come from? The log parser is unable to understand it.<br />
Could you post the rest of the logs? Just a single line without context is quite hard to make sense from.</p>
</blockquote>
<p dir="auto">Thanks I solved in 485 the registration does not work<br />
We must add  #define MY_NODE_ID XX</p>
]]></description><link>https://forum.mysensors.org/post/94478</link><guid isPermaLink="true">https://forum.mysensors.org/post/94478</guid><dc:creator><![CDATA[bocmau]]></dc:creator><pubDate>Fri, 19 Oct 2018 16:53:09 GMT</pubDate></item><item><title><![CDATA[Reply to Nodo 485 on Fri, 19 Oct 2018 16:45:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bocmau" aria-label="Profile: bocmau">@<bdi>bocmau</bdi></a> that's a strange format of the debug log. Where does it come from? The <a href="https://www.mysensors.org/build/parser" rel="nofollow ugc">log parser</a> is unable to understand it.</p>
<p dir="auto">Could you post the rest of the logs? Just a single line without context is quite hard to make sense from.</p>
]]></description><link>https://forum.mysensors.org/post/94477</link><guid isPermaLink="true">https://forum.mysensors.org/post/94477</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Fri, 19 Oct 2018 16:45:51 GMT</pubDate></item></channel></rss>
