<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sensor measuring force during pulling]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I’m surching a sensor as small<br />
As<br />
Possible. It has to kome in a little machine to measure the force during pulling at both sides of the machine. The range of the forces’ll be between 0 and 300kg or 0 till 3000 N</p>
<p dir="auto">Anyone can help me witj that?</p>
<p dir="auto">Grts</p>
<p dir="auto">Bart</p>
]]></description><link>https://forum.mysensors.org/topic/9818/sensor-measuring-force-during-pulling</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 03:58:52 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9818.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Oct 2018 23:25:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sensor measuring force during pulling on Mon, 29 Oct 2018 11:47:49 GMT]]></title><description><![CDATA[<p dir="auto">The 300kg might be a challenge.  It seems most ali express load cells are aimed at light weights, or weighing humans.<br />
Here are some for lighter weights:<br />
<a href="https://www.aliexpress.com/item/1kg-5kg-10kg-small-range-weighing-pressure-sensor-load-cell-set-weight-sensor-set-sensor-HX711AD/32765498523.html" rel="nofollow ugc">https://www.aliexpress.com/item/1kg-5kg-10kg-small-range-weighing-pressure-sensor-load-cell-set-weight-sensor-set-sensor-HX711AD/32765498523.html</a></p>
<p dir="auto">Here is one for 200kg:<br />
<a href="https://www.aliexpress.com/item/New-Arrival-1PCX-200kg-electronic-platform-scale-load-cell-pressure-balanced-cantilever-load-weight-sensor-New/32703877639.html" rel="nofollow ugc">https://www.aliexpress.com/item/New-Arrival-1PCX-200kg-electronic-platform-scale-load-cell-pressure-balanced-cantilever-load-weight-sensor-New/32703877639.html</a></p>
<p dir="auto">If you can't find one that does 300kg, you could use a lever mechanism to scale the force appropriately.  I also saw some adds for custom load cells, but that is more expensive.</p>
]]></description><link>https://forum.mysensors.org/post/94644</link><guid isPermaLink="true">https://forum.mysensors.org/post/94644</guid><dc:creator><![CDATA[nagelc]]></dc:creator><pubDate>Mon, 29 Oct 2018 11:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to Sensor measuring force during pulling on Sun, 28 Oct 2018 17:41:44 GMT]]></title><description><![CDATA[<p dir="auto">No help possible?<br />
Is force measuring so difficult?</p>
<p dir="auto">Grts bart</p>
]]></description><link>https://forum.mysensors.org/post/94626</link><guid isPermaLink="true">https://forum.mysensors.org/post/94626</guid><dc:creator><![CDATA[bartseger]]></dc:creator><pubDate>Sun, 28 Oct 2018 17:41:44 GMT</pubDate></item></channel></rss>
