advice to improve my door and temeperature sketches
  • Its been a while since I've been on the forum as my temp and door contact sensors have been working well , recently I purchased some easy PCB's to upgrade the hardware of my sensors. Now I'm wondering if I could upgrade the Software as well any advice on how i could improve my sketches would be really appreciated .
    **Door sketch **
    // ------------------ MYSENSORS ------------------
    #define MY_NODE_ID 4
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define SLEEP_TIME 0 // sleep forever
    // ------------------ BATTERY ------------------
    int oldBatteryPcnt = 0;  // remember last measured percentage
    #define V_MIN 2.7  // 0% Battery voltage
    #define V_MAX 3.3  // 100% Battery voltage
    byte oldSwitch_State = HIGH;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
    void presentation() {
      present(CHILD_ID, S_DOOR);
      // Setup 1.1 V internal reference for analoge GPIO
      analogReference(INTERNAL);
      delay(500);
      // read analog pin
      // calculate battery voltage
      float vBat  = static_cast<float>((sensorValue * (V_MAX/1023)) + 0.10);
      // calculate % left of defined interval
      int batteryPcnt = static_cast<int>(((vBat-V_MIN)/(V_MAX-V_MIN))*100.);
      // debugging
      #ifdef MY_DEBUG
        Serial.print("Sensor value: ");
        Serial.println(sensorValue);
        Serial.print(vBat);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
      // If battery % has change send to controller
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
       byte switchState = digitalRead (BUTTON_PIN);
      if (switchState != oldSwitch_State) {
         // Send in the new value
         send(msg.set(switchState==LOW ? 1 : 0));
         oldSwitch_State = switchState;
         sleep(5);
     sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, SLEEP_TIME);
    Temp Sketch
    #define MY_NODE_ID 3
    #include <OneWire.h>
    unsigned long SLEEP_TIME =  5 * 60000; // Sleep time between reads (in milliseconds), 60000 ms = 1 minute
    // ------------------ TEMPERATURE ------------------
    #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
    #define MAX_ATTACHED_DS18B20 1
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
      sendSketchInfo("Temperature Sensor", "1.1");
         present(i, S_TEMP);
      // read analog pin
      float vBat  = static_cast<float>(sensorValue * (V_MAX/1023));
      // debugging
      #ifdef MY_DEBUG
        Serial.print(vBat);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    thank you in advance .
380
8.0k
8.8k
94.3k
