<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Reboot!]]></title><description><![CDATA[<p dir="auto">Hello.<br />
I dipped my toes into the world of home automation and discovered  mysensors a couple of years ago. Then, I built (successfully) couple of relay actuators and stopped. Reason: I was in a rented apartment and couldn’t do anything permanent as such. Now, I have my own apartment and we have more or less settled in.<br />
I would like to make our home a wee bit smarter- turn on/off lights , put a timer on a washing machine power source, humidity detection , gas leak detection , door sensors etc.<br />
I have Arduinos pro mini and nrf24 radios with me from earlier.<br />
My questions are the following</p>
<ol>
<li>I used domoticz earlier but now more inclined towards openahb2. Is it advisable to make a switch ?</li>
<li>I read about zigbee and zwave. But I don’t have any existing hardware of these protocols but the only advantage I have so far read is that these protocols are “stable” or “safer”. I am in India and as far as I know there are no regulations as such when it comes to tinkering with home electricals (I still don’t want to burn down the house). In my scenario , will Mysensors be a stable solution?</li>
<li>I want some kind of redundancy in the setup - if my home network fails or is down, I should still be able to get things running. Hence, shall I also consider building a scene controller which can control the relays if a phone is unavailable or Alexa is down etc. basically it should be SO friendly or a guest friendly.<br />
I am planning to start tomorrow and looking for advice. Thanks.</li>
</ol>
]]></description><link>https://forum.mysensors.org/topic/9887/reboot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 00:05:48 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9887.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Nov 2018 17:51:38 GMT</pubDate><ttl>60</ttl></channel></rss>
