<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[bme280 sensor missing&#x2F;combining&#x2F;domoticz heartbeat and battery level]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/3816/bme280-temp-humidity-pressure-sensor">BME280 temp/humidity/pressure sensor</a><br />
Re2: <a href="/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz">DS18B20 ans SHT31-D show up as combined sensors on Domoticz</a><br />
Re3: <a href="/topic/9600/heartbeat-working-or-not">Heartbeat working or not?</a></p>
<p dir="auto">I'm trying to make outdoors(now debugging indoors)  sleep node with tqfp32 atmega328p internal 8mhz + bme280 + BH1750 (in future battery powered with two lithium AA batteries (not accumulators).<br />
I'm using Domoticz stable Version 4.9700 (June 23th 2018)<br />
and MySensors 2.3.0  at nodes and at gateway(almost shure about gateway version)</p>
<p dir="auto">Note, that according MYSController (by tekka) <strong>all messages and presentations are received and sent normally</strong>, so no problems in my pcb, radiochannel and gateway are expected. Only in code order and/or domoticz processing.</p>
<p dir="auto">I've faced three problems:</p>
<hr />
<p dir="auto"><strong>First</strong> is related to <a href="https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz">combining sensors</a> - i do not fully understand, how to avoid and how to not avoid. <em>To avoid</em> i've tried to change code, so to present humidity before temperature(but not id's), as mentioned in topic: humidity - temperature - pressure. But it didn't helped - temperature and humidity sensors are combined.<br />
I've <a href="https://forum.mysensors.org/post/50666">also</a> couldn't find topic about combining, <a href="https://github.com/domoticz/domoticz/issues/276#issuecomment-250957671" rel="nofollow ugc">mentioned in issue</a> on <a href="https://github.com/domoticz/domoticz/pull/847" rel="nofollow ugc">git</a> by gizmocuz.</p>
<hr />
<p dir="auto"><strong>Second</strong> might be related to first. I see all presented childs in my node in domoticz <em>hardware</em>. But in <em>devices</em> i'm missing one of them (temp-hum-pres-lux). For code that i will show below - i'm missing pressure. That code uses <a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a>  order of ID's and order of presenting, taken from his post <a href="https://forum.mysensors.org/post/76246">here</a> because he mentioned that he avoided combining. And what are "red nodes" in domoticz?<br />
(also i have one boolean and one text - for debugging and to be sure have reboot, it was before i found about smarts sleep "true". Also i have a lot of defines and ifdefs - to easily test this problem - about this later)<br />
Here is my code at the moment:</p>
<pre><code>//The maximum payload size is 25 bytes! The NRF24L01+ has a maximum of 32 bytes. The MySensors library (version 2.0) uses 7 bytes for the message header.
//mysensors 8mhz bits L=0xE2 H=0xD2 E=0x06 L=0x3F
#define MY_NODE_ID 4
#define MY_BAUD_RATE 9600
//#define MY_DEBUG
#define MY_SPECIAL_DEBUG
#define MY_RADIO_RF24
#define MY_RF24_IRQ_PIN (8)
#define DEB_ID 88
#define PRES_BME_ID 0
#define TEMP_BME_ID 1
#define HUMID_BME_ID 2
#define LIGHT_LUX_ID 3
#define REBOOT_ID 10
#define MEASURE_BATT_FUNCT //uncomment to measure and send battery level
#define LUX_FUNCT //uncomment to enable light measuring
#define LUX_AUTOAJUST //uncomment to enable auto-ajust resolution of sensor
#define BME_FUNCT //uncomment to enable bme measuring
#define SLEEP_TIME 20000UL  // sleep time between reads (seconds * 1000 milliseconds)
#include &lt;MySensors.h&gt;
#define BME_PRES_FUNCT //uncomment to enable sending pressure
#define BME_TEMP_FUNCT //uncomment to enable sending temperature
#define BME_HUM_FUNCT //uncomment to enable sending humidity
#if defined(LUX_FUNCT) || defined(BME_FUNCT)
  # include &lt;Wire.h&gt;
#ifdef LUX_FUNCT
  # include &lt;BH1750.h&gt;
  BH1750 lightMeter;
  MyMessage light_msg(LIGHT_LUX_ID, V_LEVEL); //VARIABLE_TYPE:    V_TEXT - из второй таблицы https://www.mysensors.org/download/serial_api_20#set,-req
#ifdef BME_FUNCT
  # include "SparkFunBME280.h"
  BME280 bme;
  MyMessage pressure_msg(PRES_BME_ID, V_PRESSURE); //VARIABLE_TYPE:    V_TEXT -set,req table https://www.mysensors.org/download/serial_api_20#set,-req
  MyMessage temperature_msg(TEMP_BME_ID, V_TEMP); //VARIABLE_TYPE:    V_TEXT -set,req table https://www.mysensors.org/download/serial_api_20#set,-req
  MyMessage humidity_msg(HUMID_BME_ID, V_HUM); //VARIABLE_TYPE:    V_TEXT -set,req table https://www.mysensors.org/download/serial_api_20#set,-req
//MyMessage(uint8_t childSensorId, uint8_t variableType);
MyMessage deb_msg(DEB_ID, V_TEXT); //VARIABLE_TYPE:    V_TEXT -set,req table https://www.mysensors.org/download/serial_api_20#set,-req
MyMessage reboot_msg(REBOOT_ID, V_STATUS);
int oldBatteryPcnt = 0;
long old_lux = 0;
float old_t = 0;
int old_h = 0;
int old_p = 0;
bool bme_init_status = false;
bool lux_init_status = false;
bool got_reboot_response = false;
bool metric = false;
 * before
 * connect
 * present
 * setup
 * loop
void(* resetFunc) (void) = 0; //declare reset function @ address 0
void before()
  //void sendSketchInfo(const char *name, const char *version, bool ack);
  sendSketchInfo("lodjiya", "0.1");
  //void present(uint8_t childSensorId, uint8_t sensorType, const char *description, bool ack);
  present(DEB_ID, S_INFO, "lodjiya_Debug");//SENSOR_TYPE:   S_INFO - из таблицы presentation https://www.mysensors.org/download/serial_api_20#presentation
#ifdef BME_FUNCT
  # ifdef BME_PRES_FUNCT
  present(PRES_BME_ID, S_BARO, "lodjiya_bme_pres");
  wait(100);
  # endif
#ifdef LUX_FUNCT
  present(LIGHT_LUX_ID, S_LIGHT_LEVEL, "lodjiya_lux_light");
#ifdef BME_FUNCT
  # ifdef BME_TEMP_FUNCT
  present(TEMP_BME_ID, S_TEMP, "lodjiya_bme_t");
  wait(100);
  # endif
  present(REBOOT_ID, S_BINARY, "lodjiya_reboot_bool");
#ifdef BME_FUNCT
  # ifdef BME_HUM_FUNCT
  present(HUMID_BME_ID, S_HUM, "lodjiya_bme_humid");
  wait(100);
  # endif
  analogReference(INTERNAL);  // use the 1.1 V internal reference
  send(deb_msg.set(""));
  Wire.begin(); // Initialize the I2C bus (BH1750 library doesn't do this automatically)
#ifdef LUX_FUNCT
  lux_init_status = lightMeter.begin(BH1750::ONE_TIME_LOW_RES_MODE);
  if (lux_init_status == false)
    send(deb_msg.set("ErrorInitLux"));
#ifdef BME_FUNCT
  bme.setI2CAddress(0x76);
  bme_init_status = bme.beginI2C();
  if (bme_init_status == false)
    send(deb_msg.set("ErrorInitBme"));
  bme.setMode(MODE_SLEEP); //Sleep for now
  send(reboot_msg.set(false));
  //wait(5000); //ждать команды bool wait(unsigned long ms, uint8_t cmd, uint8_t msgtype);
  unsigned long timer = millis();
  request(REBOOT_ID, V_STATUS);
#ifdef MEASURE_BATT_FUNCT
    int batteryPcnt = getBandgap() / 3.3;
      sendBatteryLevel(batteryPcnt);// Power up radio after sleep
      oldBatteryPcnt = batteryPcnt;
      wait(50);
#ifdef LUX_FUNCT
  if (lux_init_status)
    long lux = lightMeter.readLightLevel();
    # ifdef LUX_AUTOAJUST
      After the measurement the MTreg value is changed according to the result:
      lux &gt; 40000 ==&gt; MTreg =  32
      lux &lt; 40000 ==&gt; MTreg =  69  (default)
      lux &lt;    10 ==&gt; MTreg = 138
      if (lux &lt; 0)
        send(deb_msg.set("ErrorLuxMsr"));
      else
        if (lux &gt; 40000.0)  // reduce measurement time - needed in direct sun light
          if (!lightMeter.setMTreg(32))
            send(deb_msg.set("ErrorSetMTReg32"));
        else
            if (lux &gt; 10.0) // typical light environment
              if (!lightMeter.setMTreg(69))
                send(deb_msg.set("ErrorSetMTReg69"));
            else
              if (lux &lt;= 10.0)  //very low light environment
                if (!lightMeter.setMTreg(138))
                  send(deb_msg.set("ErrorSetMTReg138"));
    # endif
    if (old_lux != lux)
        send(light_msg.set(lux));
        old_lux = lux;
        wait(50);
#ifdef BME_FUNCT
  if (bme_init_status)
    bme.setMode(MODE_FORCED);
    int p = bme.readFloatPressure()/133;
    int h = bme.readFloatHumidity();
    float t = bme.readTempC();
    if (abs(old_t - t) &gt; 0.1)
        send(temperature_msg.set(t, 1));
      # endif
        old_t = t;
        wait(50);
    if (old_h != h)
        send(humidity_msg.set(h));
      # endif
        old_h = h;
        wait(50);
    if (old_p != p)
        send(pressure_msg.set(p));
      # endif
        old_p = p;
        wait(50);
  // send(deb_msg.set((  abs(millis() - timer) ))); //50-60ms
  if (!got_reboot_response)
    wait(3000, C_REQ, V_STATUS);//wait(const uint32_t waitingMS, const uint8_t cmd, const uint8_t msgType)
    // send(deb_msg.set("endwait1"));
  // send(deb_msg.set((  abs(millis() - timer) ))); //800-900ms
  // sleep(SLEEP_TIME, true);
  wait(SLEEP_TIME);
  //void requestTime(); //answer will be back to void receiveTime(uint32_t ts);
const long InternalReferenceVoltage = 1068;  // Adjust this value to your board's specific internal BG voltage
// Code courtesy of "Coding Badly" and "Retrolefty" from the Arduino forum
// results are Vcc * 100
// So for example, 5V would be 500.
int getBandgap()
  // REFS0 : Selects AVcc external reference
  // MUX3 MUX2 MUX1 : Selects 1.1V (VBG)
   ADMUX = bit (REFS0) | bit (MUX3) | bit (MUX2) | bit (MUX1);
   ADCSRA |= bit( ADSC );  // start conversion
   while (ADCSRA &amp; bit (ADSC))
     { }  // wait for conversion to complete
   int results = (((InternalReferenceVoltage * 1024) / ADC) + 5) / 10;
   return results;
} // end of getBandgap
void receive(const MyMessage &amp;message) //handles received message
  // send(deb_msg.set(message.type));
  // send(deb_msg.set(message.sensor));
  // send(deb_msg.set(mGetCommand(message)));
    if (message.sensor == REBOOT_ID)
      got_reboot_response = true;
      // send(deb_msg.set("got answer"));
      if (message.getBool())
        resetFunc();
</code></pre>
<p dir="auto">How i tried to test this behaviour:<br />
(a)comment in code one of (temp-hum-pres) ... start upload in MYSController<br />
while  uploading code to node via MYSController (so node doesn't send any presentation or child data to domoticz)<br />
i go to domoticz-devices, select all devices realated to this node and in upper left corned press bucket to delete them (to do that i present all sensors with names, starting with "lodjiya", so i can find them by sorting by name. also remember to press "all devices" and choose in upper left to show all, not only 25 devices)<br />
then i go to hardware-mysensors-setup select node and delete it (or delete only testing childs)<br />
but domoticz may prevent them from appearing/registering/presentating again, so<br />
i go to my putty window and do <code>sudo service domoticz.sh restart</code><br />
after that code is finished uploading, device reboots, present nodes, send first-time data for each sensor.<br />
then i checked and printsreened domoticz list of this node childs (that they all appeared and send their data, confirm identical for all last seen time) and same for list of devices<br />
(b)then uncomment sensor that was commented, and upload code (so "new" child-sensor will present himself and sent his data after upload and reboot while other sensors already present in  domoticz system)<br />
after doing checking and printscreenenig i go and comment next one of (temp-hum-pres) and start from beginning</p>
<p dir="auto">Also i tested case without commenting any sensor (all appear at once after domoticz restart)</p>
<p dir="auto">ID's: lux=commented,disabled; p=1; t=2; hum=3; presenting order don't remember, but i think temperature was presented last<br />
I've got next results: (i have screens, bu will not post them, because it is already big and hard to read post)<br />
Note: in all cases in hardware all childs were present with all latest data!<br />
so, below are described DEVICES  status only</p>
<ol>
<li>all sensors: t+h not combined, because temperature is missed in devices, h and p present</li>
<li>p+h: a)ok b) <strong>t</strong> is missed, so nothing combined, p+h still present</li>
<li>p+t: a)ok b) <strong>h</strong> is missed, so nothing combined, p+t still present</li>
<li>t+h: a)ok b) <strong>p</strong> is missed, t+h still present and still combined (as one temp sensor and temp+hum WTGR800 device)</li>
</ol>
<p dir="auto">so in all cases i always miss one of  (temp-hum-pres), even if i tried to present to domoticz later</p>
<hr />
<p dir="auto"><strong>Third</strong> is related to sendHeartbeat or sendbatterylevel without sending any sensors data or having no sensors.<br />
I've asked in old closed issue <a href="https://github.com/domoticz/domoticz/issues/1396" rel="nofollow ugc">here</a>  (there is something about workaround <em>after</em> issue was closed, but i wasn't able to find in commits).<br />
So i've opened <a href="https://github.com/domoticz/domoticz/issues/2878" rel="nofollow ugc">new issue</a>, and i think i must look at line <a href="https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp#L470" rel="nofollow ugc">470</a>  which is called at line <a href="https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp#L1819" rel="nofollow ugc">1819</a> but i see only 12 types.<br />
And i do not understand if it is possible to update only node (first table) last seen time and/or #255 child (second table in hardware in domoticz in mysensors setup).<br />
If send no sensor data, but only heartbeat (with wait or with smartsleep) - node and childs will not update "last seen". Nor wait neither smart sleep. Only on presentation (without sending sensor data).<br />
Same for battery level if i send only battery level without any sensors data it seems not to update nor last seen neither battery level. Nor wait neither smart sleep. Only on presentation (if i do not send sensor data)...<br />
Function is called at line <a href="https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp#L1797" rel="nofollow ugc">1797</a>  looks like must update all childs...</p>
]]></description><link>https://forum.mysensors.org/topic/9924/bme280-sensor-missing-combining-domoticz-heartbeat-and-battery-level</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 11:20:58 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9924.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Nov 2018 20:04:24 GMT</pubDate><ttl>60</ttl></channel></rss>
