<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nodes not showing up]]></title><description><![CDATA[<p dir="auto">Hi guys!<br />
I recently switched from Domoticz to HA and I'm having some problems to get my Mysensors stuff working.<br />
I can see that HA communicates with the ethernet gateway, and that my repeater gets "pinged". It also get some information from a Temp/Hum sensor. But none of this seems to get added to the UI. I can't find them in "states" either.</p>
<p dir="auto">What am I doing wrong? Do I need to collect all my nodes and add something in the sketches? That would be a pain :)</p>
]]></description><link>https://forum.mysensors.org/topic/9936/nodes-not-showing-up</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 01:54:43 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9936.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Nov 2018 15:42:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nodes not showing up on Sat, 01 Dec 2018 18:33:42 GMT]]></title><description><![CDATA[<p dir="auto">Ok a bit of an update. I removed my "version" part from config...yaml. I then removed the mysensors.pickle file, restarted HA and then restarted my nodes. And voila, the started showing up. So either there was something wrong with the pickle-file or the version data didn't work.</p>
<p dir="auto">But I can see now that the gw sends it's version to HA all the time, like a heartbeat. I'm not sure if this is correct or not.</p>
<p dir="auto">Now I just need to figure out how to change the names of the sensors in HA to  get them more like all my other devices.</p>
]]></description><link>https://forum.mysensors.org/post/95517</link><guid isPermaLink="true">https://forum.mysensors.org/post/95517</guid><dc:creator><![CDATA[royson84]]></dc:creator><pubDate>Sat, 01 Dec 2018 18:33:42 GMT</pubDate></item><item><title><![CDATA[Reply to Nodes not showing up on Sat, 01 Dec 2018 07:32:56 GMT]]></title><description><![CDATA[<p dir="auto">There is the "discovery" option in configuration but I thinks that's more for gateways and bigger devices, not individual nodes. Not sure so I'll give it a try and activate it.<br />
Other than adding the gw to my configuration, I haven't changed anything in my sketches, since that would be more work than I have time for at the moment.</p>
]]></description><link>https://forum.mysensors.org/post/95496</link><guid isPermaLink="true">https://forum.mysensors.org/post/95496</guid><dc:creator><![CDATA[royson84]]></dc:creator><pubDate>Sat, 01 Dec 2018 07:32:56 GMT</pubDate></item><item><title><![CDATA[Reply to Nodes not showing up on Fri, 30 Nov 2018 17:32:10 GMT]]></title><description><![CDATA[<p dir="auto">Maybe you can check if HA have similar as Domoticz, that the gateway needs to accept new hardware, before any sensors are being created</p>
<p dir="auto">Did you follow?<br />
<a href="https://www.home-assistant.io/components/mysensors/#presentation" rel="nofollow ugc">https://www.home-assistant.io/components/mysensors/#presentation</a></p>
]]></description><link>https://forum.mysensors.org/post/95485</link><guid isPermaLink="true">https://forum.mysensors.org/post/95485</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Fri, 30 Nov 2018 17:32:10 GMT</pubDate></item></channel></rss>
