<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I need some help regarding repeaters         SOLVED!]]></title><description><![CDATA[<p dir="auto">So the question is , I have my minipro o/s with a humidity sensor and using the standard radio, but cannot receive signal i/s home. I have enough parts to build a repeater and install it adjacent to the o/s sensor in hopes of bouncing the signal.  I have not found the required info on the learning pages of My Sensors, and so need to ask the form once again what needs to be done . Guessing it needs a  sketch and anything else. what would this sketch be called ?</p>
]]></description><link>https://forum.mysensors.org/topic/997/i-need-some-help-regarding-repeaters-solved</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 07:46:47 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/997.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Feb 2015 17:41:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I need some help regarding repeaters         SOLVED! on Wed, 18 Feb 2015 19:29:19 GMT]]></title><description><![CDATA[<p dir="auto">just needed to make the repeater node the mother( or reporting to node ) in the humidity parmeters . In my case, change the node from a   0 to a   2.  simple!</p>
]]></description><link>https://forum.mysensors.org/post/10348</link><guid isPermaLink="true">https://forum.mysensors.org/post/10348</guid><dc:creator><![CDATA[5546dug]]></dc:creator><pubDate>Wed, 18 Feb 2015 19:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to I need some help regarding repeaters         SOLVED! on Wed, 18 Feb 2015 15:24:03 GMT]]></title><description><![CDATA[<p dir="auto">I have set up the repeater node called repeater 2<br />
I wish to have o/s humidity sensor 3 which cant see the gw to report to repeater 2.<br />
Using the my sensors repeater sketch on lib 1.4 ver 1.4</p>
<p dir="auto">Not getting any action from anything.<br />
If I look in the work area of repeater it indicates it is clearing childs is there a step or steps missing do I need to input more info into repeater on humidity sensor here are sceenshots<img src="/uploads/upload-ba3b9aa1-5f72-47c9-ae1f-c25a541888a7.png" alt="Screenshot (28).png" class=" img-fluid img-markdown" /> <img src="/uploads/upload-26a92a86-d34f-49b1-89b5-223850f954d4.png" alt="Screenshot (27).png" class=" img-fluid img-markdown" /> <img src="/uploads/upload-aa32f8d6-5074-4caa-a511-fb51ce2acccc.png" alt="Screenshot (29).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/post/10334</link><guid isPermaLink="true">https://forum.mysensors.org/post/10334</guid><dc:creator><![CDATA[5546dug]]></dc:creator><pubDate>Wed, 18 Feb 2015 15:24:03 GMT</pubDate></item><item><title><![CDATA[Reply to I need some help regarding repeaters         SOLVED! on Tue, 17 Feb 2015 17:44:32 GMT]]></title><description><![CDATA[<p dir="auto">Think I found the answer in the ardunio library , once again under my sensors must have bad eyes.</p>
]]></description><link>https://forum.mysensors.org/post/10298</link><guid isPermaLink="true">https://forum.mysensors.org/post/10298</guid><dc:creator><![CDATA[5546dug]]></dc:creator><pubDate>Tue, 17 Feb 2015 17:44:32 GMT</pubDate></item></channel></rss>
