Mysensors with RFM98
  • Hi All,
    I'm trying to migrate from RFM69 to RFM9x but need to use 433Mhz (legal in Australia). I have purchased rfm98 modules thinking they were just the 433Mhz rfm95's. I am now having issues getting anything to work.
    I have simply declared the radio as rfm95 in the gateway and relay sketch which uploads and prints debug messages without any errors. I have not done anything in the sketches regarding radio frequency because i cannot find any documentation on how to do some for the RFM9x boards, only the old rfm69.
    How should i be using the RFM98 with Mysensors? Any advice or pointers to where should be look would be greatly appreciated!
    Cheers! 🙂
    @dsiee you are correct that rfm98 is more similar to rfm98 than to rfm69. I don't think anyone has tried before, but I think you can use the MY_RFM95 configuration parameters for RFM98. They might be a bit improperly named, but they should apply to the entire rfm95 family.
    See https://www.mysensors.org/apidocs/group__RFM95SettingGrpPub.html
    @dsiee You have to set the appropriate center frequency for your modules, i.e. for rfm98 use:
    #define MY_RFM95_FREQUENCY RFM95_434MHZ
    (RFM95_434MHZ = 433.92Mhz center frequency)
  • Thank you both! That looks exctly like what i need; I was looking in the wrong spot.
    Cheers!
