Loosing relays state after OH restart
  • Hi. I connect Arduino with MySensors to server machine with linux by serial gateway. Everything is working fine, but when I restart OH process, or machine, all relays are turning off. When i had only lights it wan snot big problem. But now i have some important things that i really won't turning off. Is there possibility to keep relays status when OH is restarting?
    My codes:
    things
    Bridge mysensors:bridge-ser:gateway3 "Gateway Przekaźniki RelPol" [ serialPort="/dev/ttyACM4", sendDelay=50, networkSanCheckEnabled=true ]
      light relay_0 'przekaźnik_00' [ nodeId=0, childId=0 ]
      light relay_1 'przekaźnik_01' [ nodeId=0, childId=1 ]
      light relay_2 'przekaźnik_02' [ nodeId=0, childId=2 ]
      light relay_3 'przekaźnik_03' [ nodeId=0, childId=3 ]
      light relay_4 'przekaźnik_04' [ nodeId=0, childId=4 ]
      light relay_5 'przekaźnik_05' [ nodeId=0, childId=5 ]
    items
    Switch relay_0 "stan" (relpols) { channel="mysensors:light:gateway3:relay_0:status" }
    Switch relay_1 "stan" (relpols) { channel="mysensors:light:gateway3:relay_1:status" }
    Switch relay_2 "stan" (relpols) { channel="mysensors:light:gateway3:relay_2:status" }
    Switch relay_3 "stan" (relpols) { channel="mysensors:light:gateway3:relay_3:status" }
    Switch relay_4 "stan" (relpols) { channel="mysensors:light:gateway3:relay_4:status" }
    Switch relay_5 "stan" (relpols) { channel="mysensors:light:gateway3:relay_5:status" }
    arduino
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    #define MY_NODE_ID 1
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
    class Relay {
      const int pin;
      int state;
      public:
        Relay(int attachTo) :
          pin(attachTo)
          pinMode(pin, OUTPUT);
        void on() {
          state = 1;
        void off() {
          state = 0;
        void setState() {
          digitalWrite(pin, state);
    Relay relay0(8);
    Relay relay1(9);
    Relay relay2(10);
    Relay relay3(11);
    Relay relay4(12);
    Relay relays[] = {relay0, relay1, relay2, relay3, relay4,};
    void presentation () {
      sendSketchInfo("relays", "0.4");
      for(int i = 0; i < 5; i++){
        present(i, S_BINARY);
    	presentation();
        relays[i].setup();
        relays[i].setState();
      wait(20);
        if(message.type==V_LIGHT && message.getInt() == 0){
          relays[(message.sensor)].off();
        if(message.type==V_LIGHT && message.getInt() == 1){
          relays[(message.sensor)].on();
  • @Dawidi
    Do you persist the relay states? This will make the previous state of the relays known after a restart of OH.
    Check this information: https://www.openhab.org/docs/configuration/persistence.html
  • Thanks. I have just made persist. Looks like that:
    config:
    # configure specific rrd properties for given items in this file.
    # please refer to the documentation available at
    # https://www.openhab.org/addons/persistence/rrd4j/
    # default_numeric and default_other are internally defined defnames and are used as
    # defaults when no other defname applies
    relpols.def=GAUGE,60,U,U,30
    relpols.archives=LAST,0.5,1,365:LAST,0.5,7,300
    relpols.items= relay_leda, relay_ledb, relay_ledc, ... , relay_custom5
    persist:
    Strategies {
        // for rrd charts, we need a cron strategy
        everyMinute : "0 * * * * ?"
    Items {
        // persist items on every change and every minute
        relay_leda, relay_ledb, ... , relay_custom4, relay_custom5 : strategy = everyChange, everyMinute, restoreOnStartup
    And it looks quite good. Because after restart, states are restored, but it looks like MySensors are not connected in time. And logs looks like (pseudocode):
    [log] system start
    [log] some relays state changed from null to ON (restored states)
    [log] some relays state changed from null to OFF
    [log] MySensors bridge is changed from OFFLINE (COMMUNICATION_ERROR)  to OFFLINE
    [log] MySensors bridge is changed from OFFLINE to ONLINE (finnaly)
    [log] all relays changed from OFFLINE to ONLINE
    and then all relays are turning OFF (physicaly) but in OH they have god states. For example relay_ao1 is physicaly off but in OH it is on, so to turn it ON i have to click it 2 time (first time it is switching to OFF).
    Any idea to fix it?
    edit:
    Now i think arduino is restarting after it connect with OH. Can it be true?
  • OK!
    Sorry but I cannot help you there. I don't know enough about the Serial GW. At least it seems OH is doing the right thing.
    In the relay actuator example the methods saveState() and loadState() are used. The current status of the pin (RELAY_ON or RELAY_OFF) is stored in the EEPROM with every change and restored after a restart of the node.
    The node will return to the last known state after a restart.
    BUT: while restarting the state of the pin may change (from on to off to on again while booting up). In case you want the relays to stay activated while booting up you may use an external pull up.
  • 22
  • 19
