Clock Sketch (RTC) modified for 1.8" LCD
  • Just embarking on making the 'Real Time Clock Module, LCD Display and Controller Time' sketch to use with a 1.8" lcd 128x160 ST7735. Problem i have is trying to get it to display the correct format of time.
    eg I would like to display:-
    06:03:09 instead of 6: 3: 9 for the time and equivelant for the date too. This is a problem when the numbers reach double figures as you get false times because it doenst clear.
    I think i need to use something similar to this;
    if (digits < 10)
    myGLCD.printNumI('0');
    I am using the UTFT libraires but cannot work out the correct syntax.
    the pic below is not a great example as the time when i took this was all double digit numbers the date and month are single. but need it to say 06/01/20
    below is my code
      NB uses 1.8inch LCD rememeber to edit the memorysaver.h file and only leave ST7735
       REVISION HISTORY
       Version 1.0 - Henrik Ekblad
       DESCRIPTION
       Example sketch showing how to request time from controller which is stored in RTC module
       The time and temperature (DS3231/DS3232) is shown on an attached Crystal LCD display
       Wiring (radio wiring on www.mysensors.org)
       Arduino   RTC-Module     I2C Display
       GND       GND            GND
       +5V       VCC            VCC
       A4        SDA            SDA
       A5        SCL            SCL
       http://www.mysensors.org/build/display
    #define MY_RADIO_RF24
    #define MY_RF24_PA_LEVEL (RF24_PA_MIN)
    #define MY_NODE_ID 40
    #include <TimeLib.h> //this is where tm.Hour tm.Min comes from
    #include <DS3232RTC.h>  // A  DS3231/DS3232 library
    #include <UTFT.h>
    extern uint8_t BigFont[];
    //extern uint8_t SmallFont[];
    extern uint8_t Grotesk16x32[];
    UTFT myGLCD(ITDB18SP, 5, 4, 8, 7, 6); //remember to edit the memorysaver.h file and only leave ST7735XX
    bool timeReceived = false;
    unsigned long lastUpdate = 0, lastRequest = 0;
      // the function to get the time from the RTC
      setSyncProvider(RTC.get);
      // Request latest time from controller at startup
      requestTime();
      // initialize the lcd fort
      myGLCD.InitLCD(LANDSCAPE);// or PORTRAIT
      myGLCD.clrScr();
    void presentation()  {
      sendSketchInfo("Clock Basic Master", "2.0");
      // Ok, set incoming time
      //Serial.print("Time value received: ");
      //Serial.println(controllerTime);
      RTC.set(controllerTime); // this sets the RTC to the time from controller - which we do want periodically
      timeReceived = true;
      myGLCD.setColor(255, 255, 255);
      unsigned long now = millis();
      // If no time has been received yet, request it every 10 second from controller
      // When time has been received, request update every hour
      if ((!timeReceived && (now - lastRequest) > (10UL * 1000UL))
          || (timeReceived && (now - lastRequest) > (60UL * 1000UL * 60UL))) {
        // Request time from controller.
        //Serial.println("requesting time");
        requestTime();
        lastRequest = now;
      // Update display every second
      if (now - lastUpdate > 1000) {
        updateDisplay();
        lastUpdate = now;
    void updateDisplay() {
      tmElements_t tm;
      RTC.read(tm);
      // Print date and time
      //lcd.home();
      myGLCD.setColor(80, 80, 200);
      myGLCD.setFont(Grotesk16x32);
      myGLCD.printNumI(tm.Hour, 10 , 20);
      myGLCD.print(":", 45, 20);
      myGLCD.printNumI(tm.Minute, CENTER, 20);
      myGLCD.print(":", 100, 20);
      myGLCD.printNumI(tm.Second, 115, 20);
      myGLCD.setFont(BigFont);
      myGLCD.setColor(255, 255, 0);
      myGLCD.printNumI(tm.Day, 15 , 65);
      myGLCD.print("/", 45, 65);
      myGLCD.printNumI(tm.Month, CENTER, 65);
      myGLCD.print("/" , 90, 65);
      myGLCD.printNumI(tmYearToCalendar(tm.Year) - 2000, 110, 65);
      myGLCD.print("T: ", 30, 95);
      myGLCD.printNumI(RTC.temperature() / 4, CENTER, 95 );
      myGLCD.print("o", 95, 90); // Degree-sign
      myGLCD.print("C", 107, 95);
      void print2digits(int number) {
      if (number >= 0 && number < 10) {
        myGLCD.print("0",CENTER, 65 );
      //   myGLCD.print(number);
      void printNumI(int digits) {
      if (digits < 10)
      myGLCD.print(digits);
      original sketch had this below for 16x4 LCD
      void printDigits(int digits) {
      if (digits < 10)
        lcd.print('0');
      lcd.print(digits);
    @palmerfarmer printNumI actually accepts two more parameters:
    UTFT::printNumI(long num, int x, int y, int length, char filler)
    You want the length to be 2 and the filler to be '0'.
    So change
    to
    myGLCD.printNumI(tm.Hour, 10 , 20, 2, '0');
    (And similar for the other calls to printNumI where you want 2 numbers)
  • Thanks for the speedy reply, I owe you a beer! works perfectly.
