Home Assistent + Serial Gateway + Motion Sensor
  • Hi folks,
    I'm sorry for asking, but I'm totally new to mysensors and home assistent, but I've already read a lot and watched youtube videos but in fact I'm right now not aware what I should do next.
    First of all, my setup is home assistent running on a raspberry pi 4 Model B. I've installed MySensors Libarary 2.3.2 and used the SerialGateway Sketch with some modifications to add a motion sensor directly on the Gateway to test the functionality.
    This is what my code looks like on an arduino nano:
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    //#define MY_BAUD_RATE 38400
    #define MY_BAUD_RATE 115200
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
    In the configure.yml File I've added the following lines as described here:
    # Example configuration.yaml entry
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          baud_rate: 115200
    #      baud_rate: 38400
          nodes:
            1:
      persistence: true
      version: 2.0
    At the moment I get the following message:
    Unable to connect to /dev/ttyUSB0
    But as I connect the gateway it I can see, that /dev/ttyUSB0 should be correct.
    Any ideas?
  • I'm not very good with HA but in the GW sketch, to me it seems that you test if the Arduino is running on 8 MHz (#if F_CPU == 8000000L), which I guess it is not. So the #DEFINE MY_BAUD_RATE 115200 is never executed.
    So then the GW runs at what baud rate?
    Try to move the #DEFINE outside of the #if -- #endif and maybe set a lower baud rate, also in the HA .yml
  • @bgunnarb
    Thank you for that hint. I've actually used the default code and just copied the code of motion sensor at the specific functions including all the defines.
    Anyway, I still get the message:
    Gateway /dev/ttyUSB0 not ready after 15.0 secs so continuing with setup
    @ATha1 I have not used Home Assistant myself, but this part of the installation instructions might be relevant:
    If you are using an original Arduino as a serial gateway, the port will be named ttyACM*. The exact number can be determined with the command shown below.
    ls /dev/ttyACM*
  • @mfalkvidd
    Thank you for your reply.
    I’ve seen this but I couldn’t find any device under /dev/ttyACM*
    But I found /dev/ttyUSB0
    @ATha1 ok. Does USB0 disappear when you disconnect the Arduino? If it does, you can be pretty sure you've got the right name.
    It could be a permission problem. The instructions at the "Component could not be set up" section at the end of https://www.home-assistant.io/docs/z-wave/installation/ looks like the same stuff that is often needed for usb devices.
  • @mfalkvidd
    Yes /dev/ttyUSB0 disappiers as I unplug the Arduino Nano Gateway and comes back when I connect it to USB again. So far so good, USB0 should be fine.
    When I do
    ls -l /dev/ttyUSB0
    it shows something equal to the link you gave.
    So owner 'root', group 'dialout'
    Most of the shell commands aren't available, for example no sudo, however I'm root, but also no usermod .
    Here is what the log-file said:
    2020-03-21 19:26:10 ERROR (MainThread) [mysensors] read failed: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
    2020-03-21 19:26:10 ERROR (MainThread) [mysensors.gateway_serial] Unable to connect to /dev/ttyUSB0
    @ATha1 nice work. I'm out of ideas unfortunately. Hopefully someone with HA experience is able to help.
  • @mfalkvidd
    I've enabled debugging:
    1d2840de-1652-47ea-9636-eb896e60502d-image.png ![alt text](image url)
    I've got this also on my Serial Monitor within the Arduino IDE. Is there the problem maybe somewhere else?
  • OK I found the reason.
    I had to disable MY_RADIO_RF24 and MY_RF24_PA_LEVEL
    so I commented out line 44 and 51 and it worked.
    Sketch code:
    * Copyright (C) 2013-2019 Sensnology AB
    * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
    * The gateway accepts input on serial which will be sent out on radio network.
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    //#define MY_RADIO_RF24
    //#if F_CPU == 8000000L
    //#define MY_BAUD_RATE 115200
    //#endif
    I've also changed some lines in my configuration.yml
    mysensors:
      gateways:
          persistence_file: 'mysensors/mysensors.json'
          baud_rate: 38400
      persistence: true
      version: '2.3.2'
    And the motion sensor showed up as Motion Sensor
  • 6
22
