NodeID assignment not working? MY_INCLUSION_MODE_FEATURE enabled
    The myscontroller node does not seem to assign IDs.
    Only nodes with a defined MY_NODE_ID work.
    MY_INCLUSION_MODE_FEATURE is enabled on the gateway.
    Pressing the button does not change the behavior (I see taht the inclusion mode is enabled when I press the button, and resets after 60s)
    When I omit the MY_NODE_ID in my sketch, the node keeps asking for a node id several times.
    On the NodeRED side, I connected a debug msg node at the output of the myscontroller node.
    The debug shows that a different ID is tried but the sqlite base is not populated and the asking node does not receive the ID.
    Do I need to connect the myscontroller output to the input of the gateway to send a message back to the node?
    Here is the node debug messages:
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:FPAR
    38 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2048 !TSM:FPAR:NO REPLY
    2050 TSM:FPAR
    2052 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4060 !TSM:FPAR:NO REPLY
    4062 TSM:FPAR
    4064 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6072 !TSM:FPAR:NO REPLY
    6074 TSM:FPAR
    6076 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8084 !TSM:FPAR:FAIL
    8085 TSM:FAIL:CNT=1
    8087 TSM:FAIL:DIS
    8089 TSF:TDI:TSL
    18091 TSM:FAIL:RE-INIT
    18093 TSM:INIT
    18099 TSM:INIT:TSP OK
    18101 TSM:FPAR
    18104 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    18848 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    18853 TSF:MSG:FPAR OK,ID=0,D=1
    20112 TSM:FPAR:OK
    20113 TSM:ID
    20115 TSM:ID:REQ
    20117 TSF:MSG:SEND,255-255-0-0,s=147,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    22125 TSM:ID
    22126 TSM:ID:REQ
    22129 TSF:MSG:SEND,255-255-0-0,s=110,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    24136 TSM:ID
    24137 TSM:ID:REQ
    24140 TSF:MSG:SEND,255-255-0-0,s=73,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    26147 TSM:ID
    26148 TSM:ID:REQ
    26151 TSF:MSG:SEND,255-255-0-0,s=36,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    28160 !TSM:ID:FAIL
    28161 TSM:FAIL:CNT=2
    28163 TSM:FAIL:DIS
    28165 TSF:TDI:TSL
    38168 TSM:FAIL:RE-INIT
    38170 TSM:INIT
    38176 TSM:INIT:TSP OK
    38178 TSM:FPAR
    38181 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38538 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    38543 TSF:MSG:FPAR OK,ID=0,D=1
    40190 TSM:FPAR:OK
    40192 TSM:ID
    40194 TSM:ID:REQ
    40196 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    42203 TSM:ID
    42204 TSM:ID:REQ
    42207 TSF:MSG:SEND,255-255-0-0,s=220,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    44214 TSM:ID
    44215 TSM:ID:REQ
    44218 TSF:MSG:SEND,255-255-0-0,s=183,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    46225 TSM:ID
    46226 TSM:ID:REQ
    46229 TSF:MSG:SEND,255-255-0-0,s=146,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    48236 !TSM:ID:FAIL
    48237 TSM:FAIL:CNT=3
    48239 TSM:FAIL:DIS
    48241 TSF:TDI:TSL
    58244 TSM:FAIL:RE-INIT
    58246 TSM:INIT
    58252 TSM:INIT:TSP OK
    58254 TSM:FPAR
    58257 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    60265 !TSM:FPAR:NO REPLY
    60267 TSM:FPAR
    60270 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    61234 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    61239 TSF:MSG:FPAR OK,ID=0,D=1
    62277 TSM:FPAR:OK
    62278 TSM:ID
    62280 TSM:ID:REQ
    62282 TSF:MSG:SEND,255-255-0-0,s=71,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    64290 TSM:ID
    64291 TSM:ID:REQ
    64294 TSF:MSG:SEND,255-255-0-0,s=35,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    66302 TSM:ID
    66304 TSM:ID:REQ
    66307 TSF:MSG:SEND,255-255-0-0,s=0,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    68314 TSM:ID
    68315 TSM:ID:REQ
    68318 TSF:MSG:SEND,255-255-0-0,s=219,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    70325 !TSM:ID:FAIL
    And here is the message I get from the output of the myscontroller node:
    {"payload":"255;6;3;0;4;1","port":"/dev/ttyUSB-MysGW","_msgid":"cd1b9bbf.44ae08","nodeId":255,"childSensorId":6,"messageType":3,"ack":0,"subType":4,"origin":1,"messageTypeStr":"C_INTERNAL","subTypeStr":"I_ID_REQUEST","topicRoot":"mys-out"}
    {"payload":"255;225;3;0;4;1","port":"/dev/ttyUSB-MysGW","_msgid":"c0995566.b1b318","nodeId":255,"childSensorId":225,"messageType":3,"ack":0,"subType":4,"origin":1,"messageTypeStr":"C_INTERNAL","subTypeStr":"I_ID_REQUEST","topicRoot":"mys-out"}
    {"payload":"255;188;3;0;4;1","port":"/dev/ttyUSB-MysGW","_msgid":"4a91ca08.1fcce4","nodeId":255,"childSensorId":188,"messageType":3,"ack":0,"subType":4,"origin":1,"messageTypeStr":"C_INTERNAL","subTypeStr":"I_ID_REQUEST","topicRoot":"mys-out"}
    I don't use MQTT, my gateway is a serial one.
    Any clue? thanks a lot.
  • I reply to myself, I succeeded to make it work.
    The \n was missing in the payload before sending it back to the gateway.
    This took me months to see this... 😄
    Works like a charm now, I just need to implement the inclusion feature in NodeRED.
  • 6
