@berkseo Good question. The code seemed good at the time I wrote it, but I can't say that it was extensively tested. I may circle back to it at a future date, and if so, I'll take a closer look. Even with more than 500 downloads of the code, no one has posted any feedback on how well (or not) it has run. Also, I not sure how compatible the posted code is with newer releases of the mysensors library.
You can put 100uf on each even 200uf would not be able to handle only one tx, so..
but you need them at least for coin cells.
you would need more capa to handle tx..but the more capa the more time they take for recharging, and the recharging if big, increase internal res of the coin cell and that's not so good too; to prevent this that would need a current resistor limiter..etc a whole balance!
On mine for instance, I have 100uF for coincell, 100uF for PIR and 86uf on radio. Fresh varta coincell 3.02V, after multiple presentation tx 2.85V if I remember, not so bad. but that's an homemade pcb.
Another notes, it's better to use ceramic capacitor (because of leakage, if you want to optimize), and better smd, but that's not your case I think.
My next issue is the humidity seems to be off. It has read as high as 115% humidity. Is this normal or should I be considering a correction? If so, how would I enter a correction. Its a little odd considering it states that the accuracy is much tighter than that.
