Domoticz/Mysensors
  • interesting schematic. another way of controlling lights is:
    rewire standard light switch to low voltage input of arduino node
    use node's relay to control light, works even if you don't have neutral wire in light switch backbox.
  • Hi
    Thanks. The good thing is that the light circuit is independent from Arduino and Raspberry. That was the main reason behind it. I was supposed to add a description but something went wrong and I only published the schematic. Anyway, I have got a problem with a script for this solution.
    Anybody can help with the programming?
  • @alco plenty people here ready to help
  • #define MY_DEBUG
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_BUTTON_PIN 3
    #define MY_REPEATER_FEATURE
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    #define noLightSwitch 10 //2-11
    int relayPin[] = {2,3,4,5,6,7,8,9,10,11}; // switch around pins to your desire
    int buttonPin[] = {A0,A1,A2,A3,A4,A5,A6,A7,A8,A9}; // switch around pins to your desire
    Bounce debouncer[10];
    MyMessage msg[10];
    void before() {
    //sendHeartbeat();
    wait(100);
    for (int i = 0; i < noLightSwitch; i++){
    // Setup the button.
    pinMode(buttonPin[i], INPUT_PULLUP);
    wait(100);
    pinMode(relayPin[i], OUTPUT);
    wait(100);
    digitalWrite(relayPin[i], RELAY_OFF);
    msg[i].sensor = i; // initialize messages
    msg[i].type = V_LIGHT;
    //send(msg[i].set(loadState(i))); // make controller aware of last status
    //wait(100);
    // setup debouncer.
    debouncer[i] = Bounce(); // initialize debouncer
    debouncer[i].interval(20);
    delay(100);
    presentation();
    boolean inputState;
    sendSketchInfo("Relay", "1.0");
    present(buttonPin[i], S_LIGHT);
    inputState =! digitalRead(buttonPin[i]);
    send(msg[i].set(inputState));
    wait(100);
    if (debouncer[i].update()) {
    wait(100);
    if (message.type==V_LIGHT) {
    for (int i = 0; i < noLightSwitch; i++) {
    if (i == message.sensor){
    digitalWrite(relayPin[i], RELAY_ON);
    wait(100);
    wait(100);
  • put your code in code tags, makes it much easier to read, use bar above text field it's </> icon.
  • hello, am french.
    no answer from Alco ??
    I simplify the code to understand how it works
    and put the diagram too
    code:
    *  Alco_TL_Impuls_Light.ino
    * https://forum.mysensors.org/topic/11263/domoticz-mysensors
    * Version 1.0 - Gateway Serial par Alco
    * Version 0.0 - Node en RS485 par JeeLet
    *LA DESCRIPTION
      * TL :Commande Impulsionnelle de TeLerupteur d'Eclairage
      * TS :Retour d'Etat par un contact auxilaire du TL.
      * L'installation Electrique n'est pas modifier,
      * les bouton poussoir de l'habitat Cmd aussi le TL.
    #define MY_NODE_ID 24           /*pour Node ID static*/
    /* ----- Module RS485 ----*/
     #define MY_RS485
     #define MY_RS485_DE_PIN 2
    // #define MY_RS485_HWSERIAL Serial1 /* Mega2560, port Serial X? */
    #define CHILD_ID 3   /*Id du capteur (enfant)*/
    #define RELAY_PIN  4   // pin Cmd Telerupteur     "TL"
    #define BUTTON_PIN  3  // pin Contact Auxiliaire  "TS"
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();  // initialize debouncer
    MyMessage msg(CHILD_ID,V_STATUS);
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      pinMode(RELAY_PIN , OUTPUT);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(20); // minimum ?
      bool state;
      boolean inputState;
      sendSketchInfo("Cmd TL", "1.a");
      present(BUTTON_PIN, S_LIGHT);
      if (debouncer.update())
       inputState =! digitalRead(BUTTON_PIN);
       send(msg.set(inputState));
      if (message.isAck())
         Serial.println("Ceci est un accusé de réception de la passerelle");
         Serial.println("Cmd TL 1.a");
      if (message.type==V_STATUS) // V_STATUS pour MyS v2.0, annulé V_LIGHT.
          //if (state = message.getBool () == true) {
            //  state = message.getBool();
         digitalWrite(RELAY_PIN, RELAY_ON);
         wait(200);                          //delai On-Off Impuls
       Serial.print("Changement entrant pour le capteur:");
    // ------------ fin Pgm -----------
    the code is not good,dialogue errors :
    error on domoticz
    Error sending switch command, check device/hardware (idx=8) !
    Log:
    Error: MySensors: Repeating previous command (2/2)
    Error: MySensors: Command not received by Node !! (node_id: 24, child_id: 3)
    thank you
  • ...I forgot the terminal debug
    ...set to OFF
    Changement entrant pour le capteur:3, New status: 0
    36376 TSF:MSG:SEND,24-24-0-0,s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    44859 TSF:MSG:READ,0-0-24,s=3,c=1,t=2,pt=0,l=1,sg=0:1
    44864 TSF:MSG:ECHO REQ
    44883 TSF:MSG:SEND,24-24-0-0,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    44890 !MCO:PRO:RC=1
    5080 !MCO:PRO:RC=1
    ....set to ON
    5080 !MCO:PRO:RC=1
    45082 !MCO:PRO:RC=1
    45084 !MCO:PRO:RC=1
    45086 !MCO:PRO:RC=1
    45088 !MCO:PRO:RC=1
    Changement entrant pour le capteur:3, New status: 1
    45127 TSF:MSG:SEND,24-24-0-0,s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
  • @JeeLet Hi. First, you probably should have started another thread rather than hijacking this one since the situation is barely related.
    Looking here, I found that !MCO:PRO:RC=1 is caused mainly by calling send() or wait() inside the receive() function.
    I have not completely understood how things are happening but I think at best you're receiving a message while processing the current one. From several sources on this forum, you should keep your receive() function small. Process the content of the message and do all the work in loop().
    I would probably do something like that, but ⚠ I didn't compile and test the code :
     *LA DESCRIPTION
     * TS :Retour d'Etat par un contact auxiliaire du TL.
     * L'installation Electrique n'est pas modifiee,
     * les boutons poussoir de l'habitat Cmd aussi le TL.
    #define MY_RS485
    #define STATE_CHILD_ID 0   /*Id du capteur (enfant)*/
    #define CONTROL_INPUT_PIN  3  // pin Contact Auxiliaire  "TS"
    #define RELAY_ON 1
    #define RELAY_OFF 0
    MyMessage msg(STATE_CHILD_ID,V_STATUS);
        pinMode(CONTROL_INPUT_PIN, INPUT_PULLUP);
        pinMode(RELAY_PIN, OUTPUT);
        debouncer.attach(CONTROL_INPUT_PIN);
    bool currentState;
    bool controllerState;
        present(STATE_CHILD_ID, S_LIGHT);
        // Send impulse if controller changed state
        if (controllerState != currentState)
            currentState = controllerState;
        // Inform controller if state change from input
            bool newState = !digitalRead(CONTROL_INPUT_PIN);
            if (newState != currentState)
                currentState = newState;
                if (currentState != controllerState)
                    send(msg.set(currentState));
        if (message.isEcho()) // keep message.isAck() for older MySensors version
            return;
            controllerState = message.getBool();
    You may have to tweak the conditions and tests so that your sensor is always in a consistent state, but that should resolve the recursion error message.
  • @boum said in Domoticz/Mysensors:
    Hello
    I just saw your message.
    nothing seen in my mailbox.
    yes that's true for another post, but the quest has the same 🙂
    to see if moderator or alco finds useful, is to do so.
    Thanks for paying attention to my problem, cool.
    I tested the sketch and the errors "MCO: PRO: RC" its part .... bingo
    but as nature hates emptiness, something else happens (nothing serious)
    .... a story of disregard for a local change / command / switchover of the TL
    I look better at your modifications to understand the arduino.
    thank you for the comments in the scketch
    my test model
    Well!! where is the notifications button
  • Yes errors on the commands given through domoticz
    only one in three and taken into account
    terminal copy serial
    ...and the local push button commands are not taken into account
    in the loop something that dies its tail ??
    merci Boum
