OH3 - MySensors Binding
  • @ncollins Thanks, really appreciate it 🙂 Let me know if you need more info, here's the basic config I did:
    • created a mqtt broker (not system broker) This thing is ONLINE
    UID: mqtt:broker:mosquitto
    label: mosquitto
    thingTypeUID: mqtt:broker
    configuration:
      lwtQos: 0
      publickeypin: true
      keepAlive: 60
      clientid: 566e1af2-19c2-4596-904f-18b89c502e53
      qos: 0
      reconnectTime: 60000
      host: localhost
      secure: false
      certificatepin: true
      lwtRetain: true
      enableDiscovery: true
    • created a MySensors MQTT Bridge with default settings (brokername = mosquitto)
    UID: mysensors:bridge-mqtt:01d212b118
    label: MySensors MQTT Gateway
    thingTypeUID: mysensors:bridge-mqtt
    configuration:
      networkSanCheckSendHeartbeat: false
      topicPublish: mygateway1-in
      networkSanCheckInterval: 3
      networkSanCheckSendHeartbeatFailAttempts: 10
      topicSubscribe: mygateway1-out
      networkSanCheckEnabled: false
      networkSanCheckConnectionFailAttempts: 3
      startupCheckEnabled: false
      brokerName: mosquitto
      imperial: false
      sendDelay: 100
    Here's the logs:
    09:59:32.973 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from UNINITIALIZED to INITIALIZING
    09:59:32.980 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
    09:59:32.994 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
    09:59:32.995 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
    09:59:32.997 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    09:59:32.998 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
    09:59:33.011 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
    09:59:33.015 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
    09:59:33.016 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
    09:59:33.022 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
    09:59:33.027 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from INITIALIZING to OFFLINE
    09:59:33.027 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    09:59:33.029 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    I tried different broker names (like mqtt:broker:mosquitto, the clientid, different uid names, but the log always says the broker cannot be found. It maps to the following lines: link
    I can provide more info if needed and try out debug versions of the binding if required.
  • Okay, now i tried to configure the MQTT system broker connection and this seems to work.
    • I set up the system broker and named it 'mosquitto'.
    • in the MySensors MQTT bridge, as before, I used mosquitto as Broker Name. Now the Broker Name could be resolved and the Thing is online.
    10:12:55.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
    10:12:55.089 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
    10:12:55.091 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
    10:12:55.094 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    10:12:55.100 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
    10:12:55.103 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
    10:12:55.106 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
    10:12:55.108 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
    10:12:55.113 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
    10:12:55.117 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
    10:12:55.127 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
    10:12:55.133 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:84dd4a387f' changed from INITIALIZING to ONLINE
    10:12:55.133 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    10:12:55.139 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
    But
    I'm having troubles with the MQTT system broker, it can't connect the broker instance.
    com.hivemq.client.mqtt.exceptions.ConnectionClosedException: java.io.IOException: Connection reset by peer
    Caused by: java.io.IOException: Connection reset by peer
            at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
            at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
            at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
            at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
            at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
            at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
            at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
            at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
            at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
            at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
            at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
            at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
            at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
            at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
            at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
            at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
            at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
            at java.lang.Thread.run(Thread.java:834) [?:?]
    Since this seems more a OpenHAB/mosquitto issue I will dig into it myself.
    Edit
    The MQTT System Broker seems to be a concept from OH2, where a MQTT broker was shipped internally with OpenHAB and it seems to be broken in OH3 (OH Forum).
    This leaves me with the following conclusions:
    1. The MySensors binding configuration references the MQTT system broker connection
    2. With OH3, this MQTT System Broker is not working anymore.
    I suppose the correct way of handling this issue is to make the MySensors binding reference a normal MQTT Broker bridge, not a System Broker bridge.
    Anyone who knows what changes this would require? My guess is that it should be manageable -> Source Code
  • @fabyte this is helpful.
    My intuition says the embedded mqtt broker and the generic mqtt binding create the same "mqtt" connection service behind the scenes. I'm guessing the generic mqtt binding isn't registering its service by name, or it's registering it by some other key.
    I'd like to get the mysensors addon to work with both mqtt brokers if possible.
  • @ncollins Yes, it looks like some resources are blocked or not resolved correctly when using the system broker.
    But the system broker functionality comes with the mqtt binding itself. Here is a screen of the settings when I deleted the mqtt binding:
    Also I never got the system broker working, even without defining a generic mqtt broker thing.
  • After reinstalling the mqtt bindung the MQTT System Broker connection now could be established - strange, that a reinstall was required since I did several OpenHAB system restarts and those didn't fix it.
    Well, now the MySensors binding is working with the system broker:
    Here's a MySensors temperature item:
    To sum up, here's what I did
    1. (manually) installed MySensors binding
    2. uninstalled mqtt binding
    3. installed mqtt binding
    4. set up the MQTT system broker connection
      4.1 set Connection Name to systembroker
      4.2 set Broker Host to localhost (it's running on the same device)
      4.3 Show advanced -> set Broker Port to 1883 since it was always using 8883 but I don't use a secure connection
      (4.4 I didn't set a clientid, no user and no password)
    5. set up the MySensors MQTT Gateway thing
      5.1 set Broker Name to systembroker
  • @fabyte Nice work. I don't use mysensors-mqtt, but I do have a lot of tasmota devices using the generic mqtt binding.
    I followed your directions to create system broker, then changed my existing mqtt broker connection to a "systemBroker" and referenced it by brokerid (Broker Name).
    I had one other issue, the new system broker wouldn't start up. I had to manually add secure="false" to /opt/openhab/userdata/config/org/openhab/mqttbroker.config .
    Maybe you can get away with toggling "Secure Connection?" a couple of times.
    Hey @fabyte and @ncollins!
    I just want you to know, that I'm still there, but out of time at the moment. My third child was born just recently and I don't have any time for the binding at the moment.
    I'm really sorry you had to reverse engineer the binding to add your code. That's awfully wrong.
    We need to create a new common base to continue the work on the binding.
    I was not able to add the binding to the official repo because of the formal requirements from the Openhab Team. I'm sure these requirements are needed, but I'm no professional in java. I struggled mainly at the nonnull annotations that are needed.
  • @TimO Congratulations on your child 👏
    I know it's an exciting time and definitely more important than developing a OH binding 😁
    Spending time with your family should always be number 1 priority and you can't blame anyone for taking time off from a internet community 🙂
  • @TimO Congrats!
    I've been looking some of the other addon-ons and your code actually looks a lot better than most. I think the base is pretty solid.
    I'll take a look at the annotations, and maybe getting some more traditional unit tests in place.
    If we get to a point where a merge is acceptable, maybe we can move the maintenance fork to the MySensors repo.
  • @TimO & @fabyte I took a stab at making all of the classes/interfaces @NonNullByDefault and adding/overriding null checks throughout. It builds fine, seems to be working well with my ethernet gateway.
    I'm going to look at unit testing next.
    https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration/bundles/org.openhab.binding.mysensors
  • @ncollins
    I have been trying to get MySensors working with OH3 for a few days now and have just stumbled upon this thread. How opportune!!!
    I am just trying to get a temp/hum arduino nano with a NRF24L01 hooked up to PI400 with OH3 using this link:
    https://www.smarthomeblog.net/diy-home-automation-sensors-first-node/
    Since I am starting from scratch with a simple proof of concept there might be some easy testing to be done with my setup.
    Do you have any suggestions for me?
  • @haloway13 Glad to see you're diving in.
    Have you set up your gateway yet? If not, try this https://www.mysensors.org/build/raspberry. I find it's easier to build and debug node with a working gateway.
  • @ncollins
    I believe so.
    openhabian@openhabian:~/MySensors $ sudo ./bin/mysgw
    Feb 28 14:28:54 INFO  Starting gateway...
    Feb 28 14:28:54 INFO  Protocol version - 2.4.0-alpha
    Feb 28 14:28:54 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
    Feb 28 14:28:54 DEBUG TSF:LRT:OK
    Feb 28 14:28:54 DEBUG TSM:INIT
    Feb 28 14:28:54 DEBUG TSF:WUR:MS=0
    Feb 28 14:28:54 DEBUG TSM:INIT:TSP OK
    Feb 28 14:28:54 DEBUG TSM:INIT:GW MODE
    Feb 28 14:28:54 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Feb 28 14:28:54 DEBUG MCO:REG:NOT NEEDED
    Feb 28 14:28:54 DEBUG MCO:BGN:STP
    Feb 28 14:28:54 DEBUG MCO:BGN:INIT OK,TSP=1
    Feb 28 14:28:54 DEBUG GWT:RMQ:CONNECTING...
    Feb 28 14:28:54 DEBUG connected to 192.168.1.151
    Feb 28 14:28:54 DEBUG GWT:RMQ:OK
    Feb 28 14:28:54 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    Feb 28 14:28:54 DEBUG TSM:READY:NWD REQ
    Feb 28 14:28:54 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Feb 28 14:29:13 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:31.3
    Feb 28 14:29:13 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Feb 28 14:29:23 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:31.4
    Feb 28 14:29:23 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Feb 28 14:29:43 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:16.1
    Feb 28 14:29:43 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
  • @haloway13 Looks good.
    Next, I would get openhab ready for adding the mysensors addon. https://github.com/tobof/openhab2-addons/wiki/Installation
    Via the openhab console run the following to install/activate the binding dependencies:
    feature:install openhab-transport-serial
    feature:install openhab-core-io-transport-mqtt
    I recommend also setting log:set DEBUG org.openhab.binding.mysensors
    Create a mqtt system connection in OpenHAB. Be sure to check advanced, and set the port.
    Then you can drop the org.openhab.binding.mysensors.jar into the addons folder and it should auto install. You can start with the binding linked above.
    Once all of that is done, you can configure your first thing, which would be a MySensors MQTT Bridge. (you should disable "Enables the startup check", I believe there is a bug)
  • @ncollins I have had some issues getting this going. Am I running the development branch? Can you tell from the output?
  • @haloway13 you have any logs or screenshots of errors you're seeing?
  • @ncollins best I can do is say that it was a java io exception of some sort associated with the bridge or broker. I have since started from scratch several times and have not taken any screenshots.
    I have faithfully followed directions from: https://github.com/tobof/openhab2-addons/wiki/Installation
    Then it is a bit of a mystery to me how to finish up the configuration through the web pages.
    Any help would be greatly appreciated!
  • Hmm, I don't use openhabian, but it looks like there is a log viewer built in: http://openhabian:9001 (maybe change openhabian to the IP of your pi).
    Without logs or screenshots, it'll be impossible to help.
  • @ncollins
    openhab log:tail output
    openhab> log:tail
    20:17:49.861 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Denver'.
    20:17:49.924 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Location set to '39.82834020908714,-105.06875216960907'.
    20:17:49.929 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'.
    20:18:27.583 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
    20:18:33.947 [INFO ] [org.openhab.ui.internal.UIService    ] - Started UI on port 8080
    20:18:35.072 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
    20:18:36.112 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
    20:25:15.958 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'mqtt:systemBroker:mosquitto' to inbox.
    20:25:15.959 [INFO ] [openhab.event.InboxAddedEvent        ] - Discovery Result with UID 'mqtt:systemBroker:mosquitto' has been added.
    20:25:17.970 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
    20:25:28.579 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
    20:25:28.673 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
    20:26:28.685 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
    20:26:28.694 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
    Broker config screen:
    Addition to the Inbox:
    Clicking the inbox. This is where I have no clue as to how to proceed...
  • so to follow up:
    Here is the log after adding the thing systembroker:
    21:28:27.906 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
    21:29:27.913 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
    21:29:27.920 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
    21:30:27.925 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
    21:30:27.933 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
    21:31:05.860 [INFO ] [openhab.event.InboxRemovedEvent      ] - Discovery Result with UID 'mqtt:systemBroker:mosquitto' has been removed.
    21:31:06.015 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from UNINITIALIZED to INITIALIZING
    21:31:06.072 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from INITIALIZING to OFFLINE
    21:31:06.079 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
    21:31:06.130 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
    21:31:06.135 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer
    21:31:27.938 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
    21:31:27.943 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer to OFFLINE
    21:31:27.951 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
    21:31:27.986 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer
    21:32:27.956 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
    21:32:27.967 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
    21:32:27.968 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer to OFFLINE
    21:32:28.014 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer
    Here is how I configured the thing:
  • @fabyte
    Could you post config screens for each of the things above for me?
  • One thing I had to do was explicitly set secure="false" into /opt/openhab/userdata/config/org/openhab/mqttbroker.config.
    Please try that, then restart.
  • also, is your MQTT broker password protected? if not, remove the username and password from your system broker configuration.
  • @ncollins
    I will check tonight.
    I really appreciate all help so far.
    When you refer to the broker password: do you mean when you install the mqtt using the openhabian-config utility from the command line while being logged in with ssh to the Pi?
  • @haloway13 I had exactly the same problem.
    Here is what I did to fix it:
    1. uninstalled the mqtt binding
      1.1 make sure the /opt/openhab/userdata/config/org/openhab/mqttbroker.config is removed
    2. installed the mqtt binding
    3. setup the system broker
    After that, the system broker connection could be established and the Try to restore connection to '192.168.1.151'. Next attempt in 60000ms messaged disappeared.
    Then you can proceed and set up the MySensors MQTT Bridge.
  • @haloway13 yeah, when you did the initial mqtt setup, did you protect it with a password? If not, make sure you clear out the username and password from the OpenHAB broker settings. (I’m not sure if it will fail if you provide credentials to an instance that is not password protected)
  • @fabyte
    I am not showing such a file as mentioned in 1.1
    2 & 3 refer to using the web interface?
  • @haloway13 Yes, everything via the web interface
  • @haloway13 Here are all of my settings in my sandbox environment.
    A couple things to note, NO MQTT BINDING INSTALLED, no special MQTT thing configured, my mqtt install is not password protected.
    Screen Shot 2021-03-05 at 12.49.22 PM.png Screen Shot 2021-03-05 at 12.53.23 PM.png Screen Shot 2021-03-05 at 12.54.34 PM.png Screen Shot 2021-03-05 at 12.55.27 PM.png Screen Shot 2021-03-05 at 12.55.50 PM.png Screen Shot 2021-03-05 at 1.01.14 PM.png
    My Gateway code:
    //#define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_BAUD_RATE 9600
    #define MY_MQTT_CLIENT_ID "MYSGW01"
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "tele/mysgw01-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX  "cmnd/mysgw01-in"
    // Set MQTT client id
    // Enable these if your MQTT broker requires username/password
    // Set WIFI SSID and password
    #define MY_WIFI_SSID "--------"
    #define MY_WIFI_PASSWORD "*********"
    // passed to the DHCP server if not static.
    #define MY_HOSTNAME MY_MQTT_CLIENT_ID
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 62
    //MQTT broker if using URL instead of ip address.
    // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
    #define MY_PORT 1883
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
    #include <ArduinoOTA.h>
      pinMode(LED_BUILTIN, OUTPUT);
     ArduinoOTA.setHostname(MY_HOSTNAME);
      ArduinoOTA.onStart([]() {
        Serial.println("ArduinoOTA start");
      ArduinoOTA.onEnd([]() {
        Serial.println("\nArduinoOTA end");
      ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
        Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
      ArduinoOTA.onError([](ota_error_t error) {
        Serial.printf("Error[%u]: ", error);
        if (error == OTA_AUTH_ERROR) {
          Serial.println("Auth Failed");
        } else if (error == OTA_BEGIN_ERROR) {
          Serial.println("Begin Failed");
        } else if (error == OTA_CONNECT_ERROR) {
          Serial.println("Connect Failed");
        } else if (error == OTA_RECEIVE_ERROR) {
          Serial.println("Receive Failed");
        } else if (error == OTA_END_ERROR) {
          Serial.println("End Failed");
      ArduinoOTA.begin();
      sendSketchInfo("MYSGW01-TEST Gateway","1.0");
      present(0, S_BINARY);
       ArduinoOTA.handle();
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(LED_BUILTIN, message.getBool() ? LOW:HIGH);
            // Store state in eeprom
  • @ncollins
    Thank you so much. This has gotten me so much closer to actually getting the test temp and humidity arduino thing working.
    I am seeing this output from the mysensors gateway:
    Mar 05 22:55:07 DEBUG GWT:RMQ:OK
    Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    Mar 05 22:55:07 DEBUG TSM:READY:NWD REQ
    Mar 05 22:55:07 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Mar 05 22:55:07 DEBUG TSF:MSG:READ,1-1-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
    Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/255/3/0/21,MSG SENT
    Mar 05 22:55:41 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
    Mar 05 22:55:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Mar 05 22:55:51 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
    Mar 05 22:55:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
    Mar 05 22:57:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.1
    Mar 05 22:57:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Mar 05 22:57:11 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
    Mar 05 22:57:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Mar 05 22:57:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
    Mar 05 22:57:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
    Mar 05 22:59:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
    Mar 05 22:59:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Mar 05 22:59:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.9
    Mar 05 22:59:21 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
    Mar 05 22:59:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
    Mar 05 22:59:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
    Mar 05 23:00:51 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
    Mar 05 23:00:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
    Mar 05 23:01:11 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.7
    Mar 05 23:01:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
    Mar 05 23:01:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
    My Sensors Gateway configuration: not letting me upload the image/screenshot, getting an error.
    ![0_1615011411135_SS_2021-03-05_23-09-13.jpg](Uploading 100%)
    Humidity Sensor thing: same problem here.
    ![0_1615011449159_SS_2021-03-05_23-12-48.jpg](Uploading 100%)
    I will try to edit this in the morning
    The short of it is that I am not seeing the values I am expecting from the sensor. I am leaning towards just not identifying the id/node for each of the things/channel.
  • Here is the humidity sensor thing page:
    Here is the temperature:
    Do I have the node and child id right? What should I check?
    Or maybe I need to do a follow on configuration to see the values?
    Thank you!
  • @haloway13 progress!
    Check the channels tab of your temperature sensor thing:
    "Add link to item" then follow the directions to create a new item
  • @ncollins
    I tried just as you describe. However I think something is failing before this should be expected to succeed.
    Thoughts?
    openhab> log:tail
    22:37:44.426 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
    22:37:44.428 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
    22:37:44.434 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
    22:37:44.438 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:3976df7e54' changed from INITIALIZING to ONLINE
    22:37:44.446 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    22:37:44.443 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
    22:37:44.451 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
    22:37:44.454 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
    22:37:44.460 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    22:37:44.464 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
    22:37:44.465 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    22:37:44.467 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
    22:37:44.469 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Merging child map: {1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]} with: {0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}
    22:37:44.472 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
    22:37:44.474 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
    22:37:44.479 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
    22:41:47.918 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
    22:41:47.936 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
    22:41:49.778 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
    22:41:49.786 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    22:41:49.788 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
    22:41:49.791 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
    22:41:49.795 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
    22:41:51.075 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
    22:41:51.090 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
    22:41:51.806 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
    22:41:51.814 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    22:41:51.817 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
    22:41:51.819 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
    22:41:51.825 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
    22:42:06.748 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from ONLINE to UNINITIALIZED
    22:42:06.762 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
    22:42:07.739 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (DISABLED) to INITIALIZING
    22:42:07.749 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    22:42:07.751 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}]
    22:42:07.753 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
    22:42:07.756 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
    22:51:49.195 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-1: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=18, nodeId=1, revertState=true, requestAck=false}
    22:51:49.214 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=18, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    22:51:49.217 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={18=MySensorsChild [childId=18, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
    22:51:49.218 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-18 not registered yet, registering...
    23:01:04.984 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Temperature
    23:01:08.762 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Temperature
    23:04:05.921 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Variable1
    23:05:12.626 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-18: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=0, nodeId=1, revertState=true, requestAck=false}
    23:05:12.636 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
    23:05:12.638 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
    23:05:12.643 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
    22:35:59.095 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
    22:37:44.434 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
  • @haloway13 can you send a screenshot of your item?Screen Shot 2021-03-08 at 9.09.23 AM.png
  • @haloway13 Can you post your sketch?
    Your humidity sensor and your temperature sensor Thing configurations both point to Child Id = 0. I think your humidity sensor should be Child Id = 1.
  • @ncollins
    Fixed the child ID. Good catch. No change.
    Here is the sketch
    #define MY_DEBUG 1
    #define MY_NODE_ID 1
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    /****************** CONSTANTS *********************/
    static const uint64_t UPDATE_INTERVAL = 10000;
    /****************** VARIABLES *********************/
    float lastTemp;
    float lastHum;
    float temperature;
    float humidity;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    /****************** MESSAGES **********************/
    DHT dht;
    present(CHILD_ID_HUM, S_HUM);
    delay(2000); //Wait 2 seconds before starting sequence
    if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
    dht.setup(DHT_DATA_PIN);
    sendTemperatureHumiditySensor();
    wait(UPDATE_INTERVAL);
    /**************** AUX. FUNCTIONS ******************/
    void sendTemperatureHumiditySensor()
    dht.readSensor(true);
    temperature = dht.getTemperature();
    humidity = dht.getHumidity();
    if (isnan(temperature))
    } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
    lastTemp = temperature;
    nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
    Serial.print("T: ");
    } else
    nNoUpdatesTemp++;
    if (isnan(humidity))
    } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
    lastHum = humidity;
    nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
    Serial.print("H: ");
    Serial.println(humidity);
    } else
    nNoUpdatesHum++;
    I am able to see the debug output from the sensors
  • @haloway13 I mean, last suggestion is restarting your openhab instance. If that doesn't work, please post your openhab log.
  • @ncollins
    My sdcard corrupted, had to restart from scratch. Hopefully, I can get back to the same point tonight.
  • @ncollins QQ: Did you install mosquitto through the openhabian-config utility?
  • @haloway13
    I assumed yes since the log was showing no connection to MQTT
    I am now getting this error:
    20:56:49.983 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid cc150d9b-7fcc-45d0-93d2-00ad80ddb9a9
    20:56:50.005 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
  • @haloway13
    @ncollins
    Woot!!! massive success!!!
    in /srv/openhab-userdata/config/org/openhab/mqttbroker.config
    added at the end secure="false"
    as you suggested.
    21:42:04.192 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.1 to 33.3
    21:42:54.224 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.2
    21:42:54.226 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
    21:42:54.228 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.2
    21:42:54.231 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.2
    21:42:54.234 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
    21:42:54.236 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
    21:42:54.238 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.2
    21:42:54.244 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.3 to 33.2
    21:42:54.246 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:42:54.000-0700
    21:43:04.250 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.3
    21:43:04.252 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
    21:43:04.253 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.3
    21:43:04.260 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.3
    21:43:04.262 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
    21:43:04.263 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
    21:43:04.265 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.3
    21:43:04.270 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.2 to 33.3
    21:43:04.271 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:43:04.000-0700
    21:43:14.266 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.2
    21:43:14.268 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
    21:43:14.271 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.2
    21:43:14.276 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.2
    21:43:14.278 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
    21:43:14.280 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
    21:43:14.281 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.2
    21:43:14.285 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.3 to 33.2
    21:43:14.286 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:43:14.000-0700
  • @haloway13 Yes!! Impressive perseverance.
    Somehow I've become emotionally invested in your outcome, so this is extremely satisfying. Great work.
  • @ncollins
    I could not have done it without you! I really appreciate the feedback and continued support. I would not have continued without it.
    Now... to get the darn data to display both in C and F. I am missing something conceptually.
    I should probably do this in another thread after I completely document all the steps I have done for posterity.
    Thanks again!
  • @haloway13 oooof, I found that to be confusing too.
    If your platform settings Settings -> Regional Settings [advanced] -> Metric / Imperial are set,
    and you define your items as Number:Temperature, they should "magically" display in the correct format and auto converted, but I've had a lot of trouble with that.
    There are also settings to have the gateway confirm "isMetric" and have you node respond in the appropriate unit.
    Lastly, in your item definition, you can "Add Metadata" -> State Description, and set a display format that supposedly converts value, but I'm not sure I understand exactly when it's suppose to override platform settings.
    Screen Shot 2021-03-12 at 5.51.47 PM.png Screen Shot 2021-03-12 at 5.52.00 PM.png
    More info here: https://community.openhab.org/t/solved-the-right-place-to-do-temperature-conversion/91233
  • @ncollins
    You are correct about magic supposing to happen when adding an item with:
    Number:Temperature with the correct regional imperial vs metric chosen.
    I think the confusion is that the number gets converted but the units need to be overriden with metadata so that it makes sense.
    Does that jive with what you understand?
    Also, it is interesting that the metadata is defined at item/channel link time?
  • @haloway13 I really don't have an understanding of how it works. I'm not sure how OpenHAB knows when to convert a value from a sensor reading?
    • When you set the platform level metric/imperial setting, is that establishing the assumption that all sensor values are metric/imperial?
    • If the metadata override for a Number:Temperature doesn't match the platform setting, is openhab smart enough to do the conversion?
    • When updating the metadata, does that convert the current value or only updates after setting the metadata?
    In my limited experiments, changing the metadata just seems to change the label suffix to ˚C or ˚F
    I just upgraded Linux Openhab version from "openHAB 3.1.0.M2" to "openHAB 3.1.0.M3". Since upgrade I cannot use / activate MySensors binding anymore (it worked in previous version - M2).
    I cleaned openhab cache, rebooted computer; feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt are properly installed and active. When I place Mysensors.jar to Addons folder the file gets recognized but it is listed only as Installed, not active.
    openhab> bundle:list | grep MySensors
    266 x Installed x  80 x 3.1.0.202012312203      x openHAB Add-ons :: Bundles :: MySensors Binding
    Log shows following error:
     [WARN ] [org.apache.felix.fileinstall         ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.mysensors-3.1.0.jar
    org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [266]
      Unresolved requirement: Import-Package: org.apache.commons.lang; version="[2.6.0,3.0.0)"
            at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
            at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
            at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
            at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
            at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
            at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
            at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
    Does anyone know how to resolve this issue / install missing requirement?
  • @niccodemi
    same problem here
    I've solved the dependency error and the package compiles fine, but I had no time for testing yet.
    If you're willing to test: Download
    I have a problem with the binding. Sometimes it drops the connection to the broker without any error message.
    System: OH 3.0.1 → MySensensors MQTT Bridge → Mosquitto → MySensors MQTT Gateway
    Fresh OpenHab install on debian, system start without any error, running about 1 day, then cannot communicate via MQTT. Messages does not arrive from Mosquitto to OH, also no outgoing messages to the broker. Checked mosquitto with MQTT Explorer, thats seems working, there are messages from the MySensorsGW.
    There aren’t any clue in logs ( working untill ~2021-04-13 10:27:12:757) :
    2021-04-13 10:27:00.947 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/11/5/1/1/2, Message: 0
    2021-04-13 10:27:00.947 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 11/5/1/1/2
    2021-04-13 10:27:00.947 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 11;5;1;1;2;0
    2021-04-13 10:27:00.949 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 11;5;1;1;2;0
    2021-04-13 10:27:00.949 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:00.949 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 11
    2021-04-13 10:27:00.949 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
    2021-04-13 10:27:00.950 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 11/5 to 2021-04-13T10:27:00.000+0200
    2021-04-13 10:27:01.001 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;6;1;1;2;0
    2021-04-13 10:27:01.002 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;6;1;1;2;0
    2021-04-13 10:27:01.026 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/11/6/1/1/2, Message: 0
    2021-04-13 10:27:01.026 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 11/6/1/1/2
    2021-04-13 10:27:01.027 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 11;6;1;1;2;0
    2021-04-13 10:27:01.031 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 11;6;1;1;2;0
    2021-04-13 10:27:01.031 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:01.031 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 6 found in node 11
    2021-04-13 10:27:01.032 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
    2021-04-13 10:27:01.032 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 11/6 to 2021-04-13T10:27:01.000+0200
    2021-04-13 10:27:01.102 [INFO ] [rsAbstractConnection$MySensorsWriter] - ACK received for message: 11;5;1;1;2;0
    2021-04-13 10:27:01.103 [INFO ] [rsAbstractConnection$MySensorsWriter] - ACK received for message: 9;6;1;1;3;0
    2021-04-13 10:27:01.103 [INFO ] [rsAbstractConnection$MySensorsWriter] - ACK received for message: 11;6;1;1;2;0
    2021-04-13 10:27:02.727 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/11/13/1/0/24, Message: 0
    2021-04-13 10:27:02.728 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 11/13/1/0/24
    2021-04-13 10:27:02.728 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 11;13;1;0;24;0
    2021-04-13 10:27:02.732 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 11;13;1;0;24;0
    2021-04-13 10:27:02.733 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:02.733 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 13 found in node 11
    2021-04-13 10:27:02.734 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var1(V_VAR1) value to: 0
    2021-04-13 10:27:02.734 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 11/13 to 2021-04-13T10:27:02.000+0200
    2021-04-13 10:27:02.826 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/11/14/1/0/2, Message: 0
    2021-04-13 10:27:02.826 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 11/14/1/0/2
    2021-04-13 10:27:02.827 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 11;14;1;0;2;0
    2021-04-13 10:27:02.836 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 11;14;1;0;2;0
    2021-04-13 10:27:02.836 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:02.837 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 14 found in node 11
    2021-04-13 10:27:02.837 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
    2021-04-13 10:27:02.838 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 11/14 to 2021-04-13T10:27:02.000+0200
    2021-04-13 10:27:04.050 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/7/255/3/0/22, Message: 1260498882
    2021-04-13 10:27:04.051 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 7/255/3/0/22
    2021-04-13 10:27:04.052 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 7;255;3;0;22;1260498882
    2021-04-13 10:27:04.052 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 7;255;3;0;22;1260498882
    2021-04-13 10:27:04.725 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/9/255/3/0/22, Message: 568774403
    2021-04-13 10:27:04.726 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 9/255/3/0/22
    2021-04-13 10:27:04.726 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 9;255;3;0;22;568774403
    2021-04-13 10:27:12.747 [INFO ] [org.openhab.core.model.script.Info  ] - Hot Water Heating: Off
    2021-04-13 10:27:12.755 [DEBUG] [ensors.handler.MySensorsThingHandler] - Adapter: class org.openhab.binding.mysensors.converter.MySensorsOnOffTypeConverter loaded
    2021-04-13 10:27:12.757 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:12.757 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 6 found in node 11
    2021-04-13 10:27:12.757 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;6;1;1;2;0
    2021-04-13 10:27:12.757 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;6;1;1;2;0
    2021-04-13 10:27:12.858 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;6;1;1;2;0
    2021-04-13 10:27:12.858 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;6;1;1;2;0
    2021-04-13 10:27:12.959 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;6;1;1;2;0
    2021-04-13 10:27:12.960 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;6;1;1;2;0
    2021-04-13 10:27:13.461 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;6;1;1;2;0
    2021-04-13 10:27:13.462 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;6;1;1;2;0
    2021-04-13 10:27:14.464 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;6;1;1;2;0
    2021-04-13 10:27:14.464 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;6;1;1;2;0
    2021-04-13 10:27:15.695 [INFO ] [org.openhab.core.model.script.Info  ] - Nappali Heating Demand : 0
    2021-04-13 10:27:15.697 [INFO ] [org.openhab.core.model.script.Info  ] - Gyerekszoba Heating Demand set to: 0
    2021-04-13 10:27:15.699 [INFO ] [org.openhab.core.model.script.Info  ] - Haloszoba Heating Demand set to: 0
    2021-04-13 10:27:15.703 [DEBUG] [ensors.handler.MySensorsThingHandler] - Adapter: class org.openhab.binding.mysensors.converter.MySensorsOnOffTypeConverter loaded
    2021-04-13 10:27:15.703 [DEBUG] [ensors.handler.MySensorsThingHandler] - Adapter: class org.openhab.binding.mysensors.converter.MySensorsPercentTypeConverter loaded
    2021-04-13 10:27:15.704 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 9 found in gateway
    2021-04-13 10:27:15.704 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:15.704 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 6 found in node 9
    2021-04-13 10:27:15.705 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 5 found in node 11
    2021-04-13 10:27:15.866 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 9;6;1;1;3;0
    2021-04-13 10:27:15.867 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 9;6;1;1;3;0
    2021-04-13 10:27:15.968 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;5;1;1;2;0
    2021-04-13 10:27:15.969 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;5;1;1;2;0
    2021-04-13 10:27:16.170 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 9;6;1;1;3;0
    2021-04-13 10:27:16.171 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 9;6;1;1;3;0
    2021-04-13 10:27:16.274 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;5;1;1;2;0
    2021-04-13 10:27:16.274 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;5;1;1;2;0
    2021-04-13 10:27:16.475 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 9;6;1;1;3;0
    2021-04-13 10:27:16.476 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 9;6;1;1;3;0
    2021-04-13 10:27:16.576 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;5;1;1;2;0
    2021-04-13 10:27:16.577 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;5;1;1;2;0
    2021-04-13 10:27:16.678 [WARN ] [rsAbstractConnection$MySensorsWriter] - NO ACK for message: 11;6;1;1;2;0
    2021-04-13 10:27:16.679 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 11 found in gateway
    2021-04-13 10:27:16.680 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 6 found in node 11
    2021-04-13 10:27:16.680 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Variable MySensorsVariableVStatus found, it will be reverted to last know state
    2021-04-13 10:27:16.681 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: status(V_STATUS) value to: OFF
    2021-04-13 10:27:16.683 [WARN ] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 11/6 BACK (due to revert) to 2021-04-13T10:27:02.000+0200
    2021-04-13 10:27:17.085 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 9;6;1;1;3;0
    2021-04-13 10:27:17.086 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 9;6;1;1;3;0
    2021-04-13 10:27:17.187 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;5;1;1;2;0
    2021-04-13 10:27:17.188 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;5;1;1;2;0
    2021-04-13 10:27:18.090 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 9;6;1;1;3;0
    2021-04-13 10:27:18.091 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 9;6;1;1;3;0
    2021-04-13 10:27:18.191 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 11;5;1;1;2;0
    2021-04-13 10:27:18.192 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mygateway1-in, Message: 11;5;1;1;2;0
    2021-04-13 10:27:20.095 [WARN ] [rsAbstractConnection$MySensorsWriter] - NO ACK for message: 9;6;1;1;3;0
  • @TimO thanks for your time, but I am sorry to say there is another one:
    Unresolved requirement: Import-Package: org.osgi.framework; version="[1.9.0,2.0.0)"
  • @oljo I am very sorry to ask, but how does your post connect to the topic of this thread?
    ....you are not using the mysensors-binding....
  • @oljo as I already mentioned: your posts are 100% off topic, because ypu do not use the OH3-binding for mysensors. you did some text-file thing-definitions with the MQTT-binding... apples and not plums
  • Hi all.
    Did anyone upgrade to OH 3.1.0 stable and managed to get the MySensors Binding 3.1.0 running yet?
    Sind I've upgraded to OH 3.1.0 I'm getting the following error messages in the log when starting the openhab service:
    I'm using a MySensors Ethernet Gateway (no MQTT, although that souldn't really make a difference) and a raspberry pi 4b+ as OH 3 server.
    2021-07-04 10:37:43.376 [ERROR] [Events.Framework                    ] - FrameworkEvent ERROR
    org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [237]
    	at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
    	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
    and then a little further down the log:
    2021-07-04 10:38:04.300 [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.mysensors-3.1.0.jar
    	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:440) ~[org.eclipse.osgi-3.16.200.jar:?]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.8]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.8]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.8]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.8]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.8]
    	at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.8]
    Any help is highly appreciated!
    Thanks and kind regards,
    Ralph...
  • P.S.:
    Prior to upgrading from OH 3.0.2 to OH 3.1.0 everything worked fine...
  • Hi!
    I've upgraded to OH 3.1.0 from OH 3.0.x
    Installed openhab-transport-serial and openhab-core-io-transport-mqtt in Karaf console with:
    Tried to restart mysensors binding:
    openhab> bundle:restart org.openhab.binding.mysensors
    Error executing command: Error restarting bundles:
    	Unable to start bundle 29: Could not resolve module: org.openhab.binding.mysensors [29]
    Checked that only org.apache.commons.lang3 is installed:
    openhab> bundle:list org.apache.commons.lang3
    START LEVEL 100 , List Threshold: 50
    ID │ State  │ Lvl │ Version │ Name
    66 │ Active │  80 │ 3.12.0  │ Apache Commons Lang
  • @Chacha the log says it all: in OH3 the required package org.apache.commons.lang is installed with version 3.12.0
    the (very depreciated) binding does only support up to version 3.0.0
    the bug has been known for several months now.
    there are 2 ways out of that situation:
    a) if possible recode your sensors without mysensors and use Homie instead
    b) get rid of the binding and use plain mqtt
    this also applys to @syntacrsc
  • Thanks @Peter-Loeffler !
    I think I'll dive into mqtt than!
    As I can see Homie is only for sensors. I use mySensors to control my rollershutters.
  • @Chacha
    Same here, I use MySensors to control rollershutters, pool pump, HVAC and solar panels.
    Maybe we should collect some volunteers for a bounty to give to @TimO to enhance his beautiful mySensors binding to work with the recent OH 3.1.0 version??
    @Peter-Loeffler
    I used to use plain MQTT before I found the mySensors binding and don't really want go back to it.
    I'd be willing to throw 100 USD into the bounty pot to enhance MySensors to work with the recent version of OH3...
    (I'd do it myself if I'd know how to 😉 )
  • @Chacha you are wrong: Homie is NOT ONLY for sensors.
  • @syntacrsc well, for me it's no solution to throw Dollars into a pot that a community-based software get's some updates. either the software is state of the art ro it is not. and MySensors turned out to be not 😞
  • @syntacrsc @TimO My system just upgraded and killed all of mySensors, which is probably half of my system... so I would be in for $50 at least
  • i've managed to build new version from the sources found here https://github.com/nikolac/openhab-addons/tree/mysensors-oh3-migration
    So far, so good - working with the latest OH 3.1.0
    please download from https://disk.yandex.ru/d/Yq3gn8N7tXSQxA
  • @vores8 just down loaded it and installed. Showing up online with my serial gateway. Gonna let it run but looks like it’s working now. Nice work, and thank you.
  • @TimO After my system upgrade yesterday the mysensor binding stopt working. after I replaced the binding with your new download, it started working again. Thanks, you are a real hero (at least for me).
  • Hi
    Just tested out the mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8 a few messages above.
    Testing with the serial gateway, openhab 3.2 latest snapshot running pi 4.
    Another detail for new users setting up by following the instruction, in the openhab install wiki (https://github.com/tobof/openhab-addons/wiki/Installation) here. This line does not work
    feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt.
    From other comments I found it is overcome by installing the openhab serial and mqtt bindings .
  • @ncollins said in OH3 - MySensors Binding:
    Just had a whole load of trouble getting the binding working using MQTT - this was the solution in case anyone else hits this!
  • @vores8 said in OH3 - MySensors Binding:
    For anyone interested, I just installed the latest version of OpenHabian on a raspberry pi and it is running OH 3.1.0. The Openhab 3.1 MySensors binding from the Mysensors website was not working (same error as @Chacha).
    I have now installed the version that @vores8 has provided and MySensors is up and running properly.
    Thanks for the help.
    just tested OH3 (3.1.0) on PI3 with mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8.
    feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt. done. It's all up and running . bundle:list shows all active.
    But the "MySensors Serial Gateway" which I intend to use in OH3 will not keep ONLINE.
    It always goes back to offline...
    11:48:29.035 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge mysensors:bridge-ser:6e5dca16a9 DONE!
    11:48:29.035 [DEBUG] [ocol.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB1 [baudRate:115200]
    11:48:29.045 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from OFFLINE to ONLINE
    11:48:29.062 [ERROR] [ocol.serial.MySensorsSerialConnection] - Exception found
    java.lang.IllegalStateException: Serial Port Identifier not found
            at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:59) [bundleFile:?]
            at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:145) [bundleFile:?]
            at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:124) [bundleFile:?]
            at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
            at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
            at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
            at java.lang.Thread.run(Thread.java:829) [?:?]
    11:48:29.073 [DEBUG] [ors.internal.gateway.MySensorsGateway] - MySensorsGateway connection status update -connected: false
    11:48:29.077 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
    11:48:29.080 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from ONLINE to OFFLINE
    11:48:29.081 [DEBUG] [ysensors.internal.event.EventRegister] - Listener org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService@b2d6b0 not present, cannot remove it
    11:48:29.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Connection status mysensors:bridge-ser:6e5dca16a9 updated to false
    11:48:29.090 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,4]
    11:48:29.095 [ERROR] [ocol.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    any ideas?
    @forexsieno Is the device accessible by the user that Openhab is running with?
  • @TimO said in OH3 - MySensors Binding:
    @TimO Yes it is. This behaviour is not reproduceable for me. Sometimes after reboot Serial gateway keeps online. in other cases it switches to OFFLINE. I assume anything is wrong with serial driver.
  • Openhab 3.2 now contains a community marketplace for bindings, perhaps the mysensors binding can be made available there?
  • Someone have working mysensors binding in openhab 3.3 ?
  • @Jarosław-Narbut Yes, I have.
  • @CyborgAndy could you please share?
  • Im receiving following error in openhab:
    [protocol.mqtt.MySensorsMqttConnection] - Can't send message, connection writer is null
    Did you have the same? What did you do to resolve this?
    Using addon: org.openhab.binding.mysensors-3.2.0-SNAPSHOT.jar
  • @daanjjansen I'm using OpenHAB 3.3.0
    Information from OpenHAB 3.3.0 release notes:
    Support for the MQTT System Broker has been removed. Replace 'mqtt:systemBroker' things with 'mqtt:broker' things.
    I fixed this error with MqttConnection. Your need remove MQTT System Broker and create new MQTT Broker.
    Download fixed org.openhab.binding.mysensors-3.3.0-SNAPSHOT.jar from my Google Disk
  • It seems that still some people are interested in this MySensors binding being updated further.
    I'm currently using in openHAB 3.2 the version that @vores8 kindly provided in post #109 on 21/07/2022, based on the source fork from @ncollins (https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration).
    Now I noticed that there seems to be a bug in the ethernet gateway with reconnecting after the TCP connection is lost. The loss of the connection is detected, but it is not disconnected and re-established afterwards.
    I would like to look at this in the " current" source code and if possible develop a fix and provide it.
    Therefore the question to the community and especially to @vores8 and @ncollins, if the source code adapted to OH 3.2 or now to OH 3.3 has been uploaded by you to GitHub. If so, under which repository and branch? If not, please catch up on it for us so that we can merge the adaption you have made to the source and possibly bundle and ensure further development.
    Thanks a lot in advance! 🤠
  • @mbedarff good question. Seems @CyborgAndy is keeping the addon alive? If so, @CyborgAndy are you publishing your changes to a public branch/fork?
  • @forexsieno Did you solve this one?
    I'm still getting the same error.
    Using 3.3.0-SNAPSHOT
    2022-08-08 02:21:23.200 [ERROR] [col.serial.MySensorsSerialConnection] - Exception found
  • Hi.
    @mbedarff I fix gateway connection checking issue.
    You can download the fixed version from my Google Disk
    @mbedarff @ncollins I published all changes to GitHub, "mysensors-binding-addon" branch.
    @forexsieno I tested my 3.3.0-SNAPSHOT in different environments (Arduino Nano as serial gateway, OH 3.3 installed on Windows 10 and Ubuntu Server 20.04) and did not find such a problem.
  • @CyborgAndy Glad to hear, that you have published all your fixes and upgrades to GitHub! So we have a current source code base to continue development or for debugging. 👍
    Thank you for the gateway connection fix! I just upgrade my OH instance from 3.2 to 3.3 and successfully tested your snapshot. 😃
    Have a nice weekend!
  • After upgrading OH from 3.2.0 to 3.3.0 and placing latest Mysensors binding (3.3.0-SNAPSHOT) into addon folder I can only get it to "Installed" status but not "active".
    Any advise how to remove following issues?
    openhab> feature:install openhab-transport-serial
    openhab> feature:install openhab-core-io-transport-mqtt
    openhab> diag 291
    openHAB Add-ons :: Bundles :: MySensors Binding (291)
    Status: Installed
    Unsatisfied Requirements:
    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mqtt.handler)"
    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.action)"
    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.config)"
    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.factory)"
    Declarative Services
  • @CyborgAndy work perfectly here.
    Thanks for you effort!
  • @CyborgAndy @vores8 and @TimO and everyone else that worked on getting this binding to work on OH3, you guys are rockstars. I fubar'd my OH2 installation and decided that i might as well upgrade to OH3. I'm so glad that the mysensors binding works with it. I'm running a Raspberry Pi Serial Gateway which amazingly also installed with only a few minor hick-ups. Thank you all so much!
  • @CyborgAndy said in OH3 - MySensors Binding:
    Is it normal than the add-on is not displayed on the official listing available through the UI of openHAB 3.3.0?
  • I've upgraded to OH4 and tried Mysensors binding 3.3.0-SNAPSHOT. It fails to load with error:
    Unresolved requirement: Import-Package: org.openhab.binding.mqtt.handler
    However 3.2.0-SNAPSHOT works perfectly with OH4!!!
    You can download it from this post:
    Install instructions: https://github.com/tobof/openhab-addons/wiki/Installation
  • Hi @Chacha
    Download org.openhab.binding.mysensors-4.0.4-SNAPSHOT.jar from my Google Disk and try it.
    I only tested as a MySensors MQTT Gateway
  • Hi @CyborgAndy
    many thanks for providing the binding update for MySensors 4.0.4! I upgrade my OpenHAB 3.4.4 a few minutes ago to 4.0.4 successfully with your binding update. I use a USB connected serial-gateway. The OpenHAB manual installation upgrade works perfect. I need to do afterwards the following steps in the Karaf console, to get the gateway online again, after the update:
    feature:install openhab-core-io-transport-serial-javacomm
    Many thanks again!
    kerberos
  • 22
  • 19
