while (!sensor.begin()) error
    I'm sorry, this must be a really stupid question to most of you but I failed to get a solution elsewhere:(
    I try to run this sketch
     * Version 1.0: Yveaux
     * sensor using a HTU21D sensor.
    // Enable debug prints
    // Enable REPORT_BATTERY_LEVEL to measure battery level and send changes to gateway
    //#define REPORT_BATTERY_LEVEL
    #define MY_RADIO_RF24
    //#define MY_RS485
    #define CHILD_ID_HUM  0
    #define CHILD_ID_TEMP 1
    static bool metric = true;
    //static const uint64_t UPDATE_INTERVAL = 60000;
    //for debugging:
    static const uint64_t UPDATE_INTERVAL = 5000;
    #include <SparkFunHTU21D.h>
    static HTU21D sensor;
    #ifdef REPORT_BATTERY_LEVEL
    #include <Vcc.h>
    static uint8_t oldBatteryPcnt = 200;  // Initialize to 200 to assure first time value will be sent.
    const float VccMin        = 1.8;      // Minimum expected Vcc level, in Volts: Brownout at 1.8V    -> 0%
    const float VccMax        = 2.0*1.6;  // Maximum expected Vcc level, in Volts: 2xAA fresh Alkaline -> 100%
    const float VccCorrection = 1.0;      // Measured Vcc by multimeter divided by reported Vcc
    static Vcc vcc(VccCorrection);
      // Send the sketch info to the gateway
      sendSketchInfo("TemperatureAndHumidity", "1.0");
      // Present sensors as children to gateway
      present(CHILD_ID_HUM, S_HUM,   "Humidity");
      present(CHILD_ID_TEMP, S_TEMP, "Temperature");
      //metric = getControllerConfig().isMetric; //Erase later
        Serial.println(F("Sensor not detected!"));
        delay(5000);
      // Read temperature & humidity from sensor.
      const float temperature = float( sensor.readTemperature() ) / 100.0;
      const float humidity    = float( sensor.readHumidity() ) / 100.0;
    #ifdef MY_DEBUG
      Serial.print(F("Temp "));
      Serial.print(temperature);
      Serial.print(metric ? 'C' : 'F');
      Serial.print(F("\tHum "));
      Serial.println(humidity);
      static MyMessage msgHum( CHILD_ID_HUM,  V_HUM );
      static MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
      send(msgTemp.set(temperature, 2));
      send(msgHum.set(humidity, 2));
      const uint8_t batteryPcnt = static_cast<uint8_t>(0.5 + vcc.Read_Perc(VccMin, VccMax));
    #ifdef MY_DEBUG
      Serial.print(F("Vbat "));
      Serial.print(vcc.Read_Volts());
      Serial.print(F("\tPerc "));
      Serial.println(batteryPcnt);
      // Battery readout should only go down. So report only when new value is smaller than previous one.
      if ( batteryPcnt < oldBatteryPcnt )
          oldBatteryPcnt = batteryPcnt;
      // Sleep until next update to save energy
      sleep(UPDATE_INTERVAL);
    but the compiler always complains about this line:
        delay(5000);
    it says:
    D:\XX\Mysensors\TempSen_HTU21D\TempSen_HTU21D.ino: In function 'void setup()':
    TempSen_HTU21D:89:24: error: could not convert 'sensor.HTU21D::begin((* & Wire))' from 'void' to 'bool'
    TempSen_HTU21D:89:24: error: in argument to unary !
    Does anybody know where the problem is? I also tried IF and all kinds of other stuff but it seems the problem is actually not this line but some other issue...
    I'd be super glad if anybody can point me in the right direction...
  • It looks like sensor.begin() doesn't return a value
    @maddhin you need to pass a Wire instance in the call to begin(). Search the net for an example.
    Edit: never mind; answered too quickly 😉 It doesn't return a bool indeed so you cannot use it in a while loop.
  • @Yveaux said in while (!sensor.begin()) error:
    I did some rearching but I think the problem is that I don't really understand what that means 🙂
    I tried adjusting the code close to the official Sparkfun example code with include wire.h etc. but that didn't work either.
    #include "SparkFunHTU21D.h"
    HTU21D myHumidity;
      Serial.begin(9600);
      Serial.println("HTU21D Example!");
      myHumidity.begin();
    I'll search some more tomorrow but, I guess, I leave out the while/if as this seems to be too complicated for a "simple" error handler 🙂
  • @maddhin The while / if won't work here, since SparkFun's implementation of the begin() function doesn't return a value, as both the compile error and @electrik suggest.
    Take a look at the SparkFunHTU21D.h header, where the function is defined:
    void begin(TwoWire &wirePort = Wire); //If user doesn't specificy then Wire will be used
    Its return type is void. It returns nothing. While and if conditions need something to compare, so the function would need to be a bool begin(...) or some other simple numeric type. Only then can a while or if clause determine if a condition is true (non-zero) or false (zero).
    In other words: SparkFun doesn't test if the sensor has been initialized properly, so you can't either.
  • @BearWithBeard said in while (!sensor.begin()) error:
    awesome answer, @BearWithBeard!! This explains everything and this makes a whole lot of sense. I guess I need to further up my programming skills/understanding 😉 Thank you so much!
  • @maddhin FWIW I always use the adafruit library for htu21D and it has a similar test in setup that does not give me any errors - might be worth a try?
  • 15
