1.5.1 to 2.3.2 issues
    Today I migrated my gateway from 1.5.1 to 2.3.2, tested it fine.
    Then I started trying to reprogram my sensors to 2.3.2 and none works. No wiring changed, previously fine working (CO2, DSM dust sensor)
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSF:SID:OK,ID=20
    38 TSM:FPAR
    41 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2050 !TSM:FPAR:NO REPLY
    2052 TSM:FPAR
    2056 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3899 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    3904 TSF:MSG:BC
    4063 !TSM:FPAR:NO REPLY
    4065 TSM:FPAR
    4069 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    5923 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    5928 TSF:MSG:BC
    6076 !TSM:FPAR:NO REPLY
    6078 TSM:FPAR
    6082 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    7947 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    7952 TSF:MSG:BC
    8089 !TSM:FPAR:FAIL
    8090 TSM:FAIL:CNT=1
    8092 TSM:FAIL:DIS
    8094 TSF:TDI:TSL
    @epierre what does the log from the gateway say? Preferably for the same time, so the node side and the gateway side can be compared.
    will try to put it in debug mode. now I've added a 1u and 100u with no result
    intermediary result: I have started a second gateway and now the nodes do communicate... puzzled...
    I remove the extra gateway... same situation...
    so reprogram gateway with:
    so it seems this was the responsible for this !
    thanks !
  • 15
  • 24
