Sensebender Gateway 1.0 - Init weirdness...
  • My setup is :
    • Raspberry Pi Zero2 running 'mysgw 2.3.2' connected via USB serial to
    • Sensebender Gateway running 'MySensors core version : 2.3.2' and a default sketch customised for an RFM69HW.
    When I view the Arduino Serial Monitor on init, with the Sensebender gateway hooked directly to laptop USB, everything looks OK :
    09:27:09.544 -> 0;255;3;0;9;1150 MCO:BGN:INIT GW,CP=RRNGS---,FQ=48,REL=255,VER=2.3.2
    09:27:09.578 -> 0;255;3;0;9;1179 TSF:LRT:OK
    09:27:09.578 -> 0;255;3;0;9;1179 TSM:INIT
    09:27:09.578 -> 0;255;3;0;9;1180 TSF:WUR:MS=0
    09:27:09.578 -> 0;255;3;0;9;1182 TSM:INIT:TSP OK
    09:27:09.578 -> 0;255;3;0;9;1182 TSM:INIT:GW MODE
    09:27:09.578 -> 0;255;3;0;9;1182 TSM:READY:ID=0,PAR=0,DIS=0
    09:27:09.578 -> 0;255;3;0;9;1182 MCO:REG:NOT NEEDED
    09:27:09.578 -> 0;255;3;0;14;Gateway startup complete.
    09:27:09.578 -> 0;255;0;0;18;2.3.2
    09:27:09.578 -> 0;255;3;0;9;1183 MCO:BGN:STP
    09:27:09.578 -> 0;255;3;0;9;1183 MCO:BGN:INIT OK,TSP=1
    09:27:09.578 -> 0;255;3;0;9;1183 TSM:READY:NWD REQ
    09:27:09.578 -> 0;255;3;0;9;1187 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    But if I short SWC2, it appears there's an EEPROM problem?
    09:28:00.951 -> Sensebender GateWay test routine
    09:28:00.951 -> MySensors core version : 2.3.2
    09:28:00.951 -> GateWay sketch version : 0.3trcm
    09:28:00.951 -> ----------------------------------
    09:28:00.951 ->
    09:28:00.951 -> - > SHA204 Ok (serial : 01234DAE97196D83EE)
    09:28:01.021 -> - > SD CARD SD Card initialized correct! - type detected : SDHC
    09:28:01.125 ->  -> EEPROM
    ... hangs here indefinitely ...
    And if I connect the Sensebender Gateway to the Pi Zero with mysgw, it looks like the radio then fails to init? :
    pi@raspberrypi:~/MySensors $ ./configure --my-gateway=serial --my-serial-port=/dev/ttyACM0 --my-transport=rfm69 --my-rfm69-frequency=433 --my-serial-is-pty --my-is-rfm69hw
      [OK] SPI driver detected:BCM.
    [SECTION] Gateway configuration.
      [OK] Type: serial.
      [OK] Transport: rfm69.
      [OK] Signing: Disabled.
      [OK] Encryption: Disabled.
      [OK] CPPFLAGS: -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_IS_RFM69HW -DMY_LINUX_SERIAL_IS_PTY -DMY_RFM69_FREQUENCY=RFM69_433MHZ -DMY_LINUX_SERIAL_PORT="/dev/ttyACM0"
      [OK] CXXFLAGS:  -std=c++11
      [OK] Init system detected: systemd.
      [OK] Saved.
      [OK] Finished.
    pi@raspberrypi:~/MySensors $ make && sudo make install
    And then...
    pi@raspberrypi:~ $ sudo mysgw
    May 30 09:40:45 INFO  Starting gateway...
    May 30 09:40:45 INFO  Protocol version - 2.3.2
    May 30 09:40:45 DEBUG Serial port /dev/ttyACM0 (115200 baud) created
    May 30 09:40:45 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=255,VER=2.3.2
    May 30 09:40:45 DEBUG TSF:LRT:OK
    May 30 09:40:45 DEBUG TSM:INIT
    May 30 09:40:45 DEBUG TSF:WUR:MS=0
    May 30 09:40:45 DEBUG !TSM:INIT:TSP FAIL
    May 30 09:40:45 DEBUG TSM:FAIL:CNT=1
    May 30 09:40:45 DEBUG TSM:FAIL:DIS
    May 30 09:40:45 DEBUG TSF:TDI:TSL
    May 30 09:40:55 DEBUG TSM:FAIL:RE-INIT
    May 30 09:40:55 DEBUG TSM:INIT
    May 30 09:40:55 DEBUG !TSM:INIT:TSP FAIL
    May 30 09:40:55 DEBUG TSM:FAIL:CNT=2
    May 30 09:40:55 DEBUG TSM:FAIL:DIS
    May 30 09:40:55 DEBUG TSF:TDI:TSL
    ^CMay 30 09:40:58 NOTICE Received SIGINT
    Though serial output seems to show TSM (this is the radio portion?) inits OK :
    pi@raspberrypi:~/MySensors $ cat /dev/ttyACM0
    0;255;3;0;9;7573 MCO:BGN:INIT GW,CP=RRNGS---,FQ=48,REL=255,VER=2.3.2
    0;255;3;0;9;7602 TSF:LRT:OK
    0;255;3;0;9;7602 TSM:INIT
    0;255;3;0;9;7603 TSF:WUR:MS=0
    0;255;3;0;9;7604 TSM:INIT:TSP OK
    0;255;3;0;9;7605 TSM:INIT:GW MODE
    0;255;3;0;9;7605 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;7605 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;7606 MCO:BGN:STP
    0;255;3;0;9;7606 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;7606 TSM:READY:NWD REQ
    0;255;3;0;9;7610 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    What am I not understanding here, have I specified the options incorrectly in the ./configure step ?
    Is something wrong with the EEPROM ?
  • Hmm, I wasn't clear on what the mysgw software did, I don't need to run that at all do I!
    It seems there's still an issue with the EEPROM test routine though?
  • @tomtastic
    Hi, I had similar problems in the last year. There is definitely a issue with the clear eeprom sketch, I ended up having to make changes myself, in order to correctly wipe it. When I'm next on my pc I'll post the sketch.
    Regards Nigel
  • Hi all,
    This is what I Simply ended up with to clear the eeprom,
    // load core modules only
    #define MY_CORE_ONLY
    void before(){
      for (uint16_t i=0; i<EEPROM_LOCAL_CONFIG_ADDRESS; i++) {
        hwWriteConfig(i,0xFF);
      Serial.println("Clearing done.");
        Serial.println(i);
    	// Nothing to do here...
  • 24
  • 15
