A little Halloween fun. I've added LED strip lights to an old Halloween plastic ghost and jack-o-lantern and automated switching them off/on using a MySensors node.
The output of the display could also be sent over serial, but the whole idea is you can walk around with the doctor and improve your results as you go.
@pbw a gateway's function is to act as a gateway between the nodes and a controller. I don't think you will have all of the needed memory available to add logic to the gateway and you will make your solution very static.
You can implemented your own lightway controller, just have a look at the Serial API. But controllers like Domoticz are lightweight and the already over a browser based interface. And most of them are easy to setup creating a much more versatile and dynamic solution.
We are of like minds, Don't like the cloud based controls (that's another discussion).
In my case I have a Bryant/Connex system, heat pump, variable speed fan and 4 zones. There's a lot going on: the 4 zones creates 16 profiles. The fan speed for a profile will depend on the indoor and outdoor temperature. The thermal fluid pump also has to be controlled. A profile will have an optimal air pressure, so there's a sensor there.
The controller works just fine not being connected to the cloud. But I want to set the parameters remotely, Bryant/Connex can do this. I also wnat the status of the various actuators and sensors to show up in Home Assistant.
The signals sent over the RS422 are proprietary. My plan was to reverse-engineer the signals. After doing this I'll have to experiment to get the right mix of air pressue, fan speed and thermal fluid flow for each profile.
I'd like to do the same for my AO Smith heat pump water heater.
I'd like to follow your progress.
OSD
