Humidity / Temperature Sensor
    I've build a sensor to measure humidity and temperature in my living room. It is now working for about 7 weeks.
    The sensor consists of the following components:
    • DHT22 Hum/Temp Sensor
    • MCP 1702 LDO Regulator (3.3V)
    • Atmega328P-PU PDIP-28
    • holder for batteries (4 x AAA)
    • NRF24L01+
    Here are the schematics:
    And here is a screenshot from my OpenHab-View:
    (I'm logging the last update to ensure the sensor is still alive)
    The DHT22 needs at least 3 V to operate stable, so I thought about using a booster or a regulator and took the regulator.
    Currently I'm using rechargeable AAA, which will be switched soon, as the sensor is working fine. The Voltage has dropped 0,1 V (from 5.3V to 5.2V) in 7 weeks and the AAAs were only precharged. My multimeter is able to measure the current, but in case of this sensor it is to low, I need a better multimeter.
    The Atmega328p is running with 8 MHz internal clock and brown out detection is disabled.
    Finally the sketch:
    https://codebender.cc/sketch:67176
  • A little mistake in your schematic: R2 must be 4,7k!
    @doesel33: You're right, thanks!
  • Cool!
    Perhaps a noob question, but how do you program the Atmega?
    Why would you switch the batteries?
    5.2V / 4 = 1,3V so still quite full.
    These batteries are low-leakage batteries so provided the initial charge is fine and current consumption the lifespan should be good and at least 50% of that of good alkaline batteries
    @gadu I'm using a MySmartUSB MK3.
    @daulagari I'm using rechargeable ones as long as I'm not sure how good my device is working.
    I power DHT22 from arduino pin. It help make economy battery. When controller sleep, power pin set to low.
    If using 3.3 power - no needed R2
    If you use CR123A accomulator. You will not need Regulator and the device will be smaller
    Does the DHT22 work with 3v? I thought it needs at least 3.3v. I will test that!
  • Can't remember the specs. "Normally" 3.3v is something like 3.0-3.6v..
    Just did the google thingy.. 3v-5v:)
    My devices
  • I think the comment in the routine
    void measureBattery() {
    // R1 = 1MOhm, R2 = 220 kOhm
    Should be
    // R3 = 1MOhm, R2 = 220 kOhm
    (R3)
    Is it possible to add (comment out) some lines how to calculate the battery percentage and send this via gw.sendBatteryLevel (batteryPcnt)
    Great sketch!
