Temp/Humidity/Light Sensor on battery
    After a long time tried making a node with temperature, relative humidity and light sensors. 2015-04-03 13.00.18.jpg
    Running sensor node on 9v battery..actually i have bought ample of 9v batteries. sensor node is running for last 15 days.. ignore the dip in the battery levels due to non-battery mode .
    upload-cd163fd8-f48d-4e84-95f6-8d340f725709
    LDR and DHT11 sensors connected on PCB..
    upload-99d006c0-7a49-49f8-953d-964c221803be
  • @Dheeraj Very nice. Do you mind sharing your sketch?
    @Dwalt
    actually the sketch is simple.
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define BATTERY_SENSE_PIN  A0  // select the input pin for the battery sense point
    #define LIGHT_SENSOR_ANALOG_PIN A1
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int oldBatteryPcnt = 0;
    int battLoop =0;
    int lightLevel =0;
    int lastLightLevel =0;
      gw.begin(NULL,15);
      gw.sendSketchInfo("Temp Humidity Light", "1.0");
      check_batt();
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      lightLevel = (analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
          Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      battLoop++;
      if (battLoop > 10)
          check_batt();
          battLoop=0;
    void check_batt()
      // get the battery Voltage
      Serial.println(sensorValue);
      // vout = (sensorvalue x 3.3) / 1023
      //vin = vout /  (R2/(R1+R2));
      float batteryV  = ( sensorValue * 0.003225806 ) / 0.3; // divide R2/(R1+R2)
      int batteryPcnt = sensorValue / 10 ;
      if ( batteryPcnt > 100 )
      batteryPcnt = 100;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      if (oldBatteryPcnt != batteryPcnt)
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
  • 87
  • 7
