spying a repeater
    I am new with MySensors and Domoticz.
    My problem is having to cover a fairly large area, with repeaters.
    My question is: is it possible to send to the serial monitor the contents of that node, to find out what repeator is required for each sensor?
    In other words, how to send to the serial monitor the content of messages transmitted by the repeater?
    If someone has an idea, THANK YOU in advance 😃
    Alain
  • Perhaps this is the best way to spy a location :
    sniffer
    If you have DEBUG enabled for the repeater you can see what is passing the node in serial monitor.
    Thank you for the answers.
    I wanted to display local information of the serial monitor, when the repeater is far from a PC, but eventually I will directly and separately adress sensors repeaters, two by two.
    This is less optimized but i can not display this info locally.
    THANK YOU
    Alain
