Just for completeness: the right way to do this is to add the json under ~/.platformio/boards and the other files as described in https://community.platformio.org/t/how-use-a-same-chip-but-with-different-environment/18082/4
I found procedure gatewayTransportInit(), it works great. However, I cannot find a procedure that will enable detection of a network connection at level mysensors. I noticed that disconnecting the network plug or resetting the W5500 (37 pin to ground) changes the device's IP address to 0.0.0.0 - then I call gatewayTransportInit() - but mysensor's library must have such procedures - please tell me how to diagnose ethernet connection.
@tekka
Is there any changelog to it also or it was just made officially available again?
although last online status was 22 AUG 2020, so anyone else can confirm anything about it?
I'd just be cautious without confirmation.
@eiten said in Saving last known good state, but not in EEPROM:
utility meter in home assistant
This is exactly what I am seeking! Thank you!
PS I truly enjoy reverse translating! It teaches me how to better understand my first language and it gives me alternate words to use in searches. So a second thank you!
"Regelmässiges Zurücksetzen" would be best translated to English in this context as "Periodic Reset". In the English version of Home Assistant it is called "Meter reset cycle" (I remember seeing "keep dry" translated as "do not take in shower with you"
