Motion (PIR), actuator and Temp sensor
    I'm trying to make and sensor, as subject says. I've got temp (DS18B20) and actuator working, but not the PIR (HC-SR501).
    PINs as follow:
    RADIO IRQ = PIN2
    Temp = PIN3
    PIR data = PIN4
    Actuator = PIN 5,6
    My question is now, does a PIR require an Interrupt PIN on the arduino (PIN 2,3) , or can I use any PIN?
  • Thats unfortunate question, as it all depends on the code you write..
    If you want to sleep the node, then using pin-interrrupt is a great way of waking the node when motion is detected.
    You can use use the radio-irq pin for you sensors. It is currently not used by the mysensors library.
  • Ok, so basicly you are saying, that the PIR DOESN'T require an irq pin on the arduino?
    So, not need to wire the radio IRQ PIN at all?
    No
    No, you can poll it yourself if you stay awake.
  • Ok, finally got it to work with this:
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
    #include <OneWire.h>
    int numSensors=0;
    //boolean receivedConfig = false;
    boolean metric = true;
    #define RELAY_1 5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2 6
    // Motion sensor defs
    unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 4   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    //#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define CHILD_ID 3   // Id of the sensor child
    boolean lastTrippedState;
    MyMessage msgTemp(0, V_TEMP);
    MyMessage msgRelay2(2, V_LIGHT);
    MyMessage msgMotion(3, V_TRIPPED);
      gw.sendSketchInfo("Temp/Relay/Motion Sensor", "1.0");
      gw.present(1, S_LIGHT);
      pinMode(RELAY_1, OUTPUT);
      gw.present(2, S_LIGHT);
      pinMode(RELAY_2, OUTPUT);
      digitalWrite(RELAY_1, gw.loadState(1)? RELAY_ON : RELAY_OFF);
      digitalWrite(RELAY_2, gw.loadState(1)? RELAY_ON : RELAY_OFF);
      gw.present(CHILD_ID, S_MOTION);
      //numSensors = sensors.getDeviceCount();
      //for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
         gw.present(0, S_TEMP);
      if (tripped != lastTrippedState)
        Serial.println(tripped? "tripped" : "not tripped");
        gw.send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw//
        //digitalWrite(RELAY_1, tripped? 1 : 0);
      lastTrippedState = tripped;
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
        // Only send data if temperature has changed more then 1 degC and no error
        if (int(lastTemperature[0]) != int(temperature) && temperature != -127.00) { //added integer
          gw.send(msgTemp.setSensor(0).set(temperature,1));
          lastTemperature[0]=temperature;
      if (message.type==V_LIGHT && message.sensor == 2)
        // Change relay state
        digitalWrite(RELAY_2, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
  • 87
