resend if st=fail
  • Hello everybody,
    has anyone built a function that resend the signal, if "st=fail" is detected?
    I've already looked at the API and ACK. But have become not really smart of it.
    This would be great for some devices like relay, alarm, ....
    Best Regards,
    n3ro
    @n3ro you can use and catch the Ack value yourself and make sure the message arrives.
  • @AWI do you have code example for me?
    gw.send() returns false when no ack was received.
  • Hey ๐Ÿ™‚
    I have just build this test function to resend a signal if failed.
    But i don't know how to execute the ge.send in the string ("// execute code").
    #define SENSOR_INFO "Test sensor"
    #define NODE_ID 200
    #define CHILD_ID 1
    #define OPEN 1
    #define CLOSE 0
      gw.begin(NULL, NODE_ID, false);
      gw.sendSketchInfo(SENSOR_INFO, "1.0");
      gw.present(CHILD_ID, S_DOOR);
      gwack("gw.send(msg.set(OPEN));");
      delay(500);
    void gwack(char code[])
      int repeat = 0;
      boolean sendOK = false;
      Serial.println(code); // string to execute
      while ((sendOK == false) or (repeat <= 10))
        if (code) // execute code
          Serial.println("OK");
          sendOK = true;
          Serial.println("NOT OK!!");
          sendOK = false;
        repeat++;
    Any ideas? ๐Ÿ™‚
  • That's not going to work the way you wrote it. That would require the Arduino to be able to compile code, which is asking a bit much of the little micro. ๐Ÿ™‚
    I would either do the retry-on-fail logic directly inline in your loop() function, or put the gw.send() call in gwack() and pass the msg value as a reference/pointer to gwack.
    What do you mean? ๐Ÿ™‚
    Like this?
    //gw.send(msg.set(OPEN));
      gwresend("msg.set","OPEN");
      delay(500);
    void gwresend(char msgcode[],char option[])
      int repeat = 0;
        if (gw.send(msgcode(option)) // execute code
          sendOK = true;
          sendOK = false;
        repeat++;
    (code is not working ๐Ÿ˜‰ )
    I'm very surprised that there is not already such a function.
  • I'd be surprised if that even compiles. (Does it?)
    I meant you should set up the message in loop, then pass the completed message to gwresend like:
    msg.set(OPEN);
    gwresend(msg);
    The signature for gwresend will be something like:
    void gwresend(MyMessage &msg)
    The execute code line would then just be:
    if (gw.send(msg)) { ...
    Don't take this the wrong way, but this is more of a basic C++ language question. You might want to poke around on StackOverflow for examples to better understand the language (like the pass by reference that I suggested above, which, being from a C background, I've always found a bit scary.)
  • Jeah now its working ๐Ÿ™‚
    #define NODE_ID 200
    #define CHILD_ID 1
    #define OPEN 1
    #define CLOSE 0
    int repeat = 0;
    int repeatdelay = 0;
      resend((msg.set(OPEN)), 5);
    delay(500);
    void resend(MyMessage &msg, int repeats)
      int repeat = 1;
      while ((sendOK == false) and (repeat < repeats)) {
        if (gw.send(msg)) {
          sendOK = true;
          sendOK = false;
          Serial.print("FEHLER ");
          Serial.println(repeat);
          repeatdelay += 250;
        } repeat++; delay(repeatdelay);
  • 198
