Hi @edoardoo
I actually stumbled on your post a couple of weeks ago! Great writeup!
We certainly need contributors. We need help with everything from the visualisation of sensordata in the frontend (considering using d3.js) to mqtt/node.js backend for receiving and processing sensor data.
Please contact me or Johan for further discussions.
@monte said in Best choise for a controller:
@neverdie but isn't Docker more efficient and simple solution compared to a VM? Considering it will be used for single process anyway.
Yes, I think you're right.
@David-Dawson
great idea for that translation from homie to mysensors and back.
but I think it would be a better approach, if mysensors would have the ability to "speak" homie-convention in MQTT optionally (e.g. #MY_GATEWAY_MQTT_HOMIE)
that would eliminate the need of tweaking on an extra binding and let mysensors talk an IOT-standard
@OldSurferDude use a host name for the broker in the configure command (--my-controller-url-address=). Add the host name to /etc/hosts on the rpi where the gateway is. Start the MySensors gatway.
When you want to switch brokers, modify /etc/hosts again and restart the MySensors gateway.
Hi dzairo,
Just wondering if you still monitor this thread. If so would love to know how to install the ComPort component so I can modify and use your terminal code. For some reason I don't have any luck with adding it to the IDE.
thanks, Andy.
