Trying to combine Temp + Battery level-sketch, What is wrong?
  • Hi I tried to combine The temperature & battery-level sketch into one but it does not work. I can see the sensor getting detected in the domoticz log but it does not show up under devices.
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    int oldBatteryPcnt = 0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
      sensors.begin();
      // Startup and initialize MySensors library. Set callback for incoming messages.
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor+Battery", "1.1");
         gw.present(i, S_TEMP);
      // Process incoming messages (like config from server)
      gw.sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
          gw.send(msg.setSensor(i).set(temperature,1));
        // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      gw.sleep(SLEEP_TIME);
    What does domotizcs log say?
  • @Cliff-Karlsson said:
    int numSensors=0;
    It seems that you have 0 temp sensors
    treb0r
  • I am definitly no expert but I guess that is only a setup value. This part I think sets the proper value of sensors:
