Can't program Arduino Nano Compatible modules
  • I purchased 5 Arduino Nano Compatibles, and can not get my Mac to recognize their presence. I am running a late 2012 mac mini and El Capitan Beta.
    My problem is that the Arduino programmer, and my xBee programmer do not even respond to them. I get a steady bright red POW(er) light and the L light next to it blinks about once per second.
    I have tried connecting three different units and used two known good usb cables.to no avail. I have 5 other serial/USB ports in use, all of which work fine.
    Is there a trick to these that I'm missing? As I would be surprised if I got three bad units out of the box.
    A lot of the clones use a ch340g usb interface chip. Have you downloaded drivers for it: http://sparks.gogo.co.nz/ch340.html.
    Al
  • I have the same problem. Did Al's tip work?
  • @ndiwan you can check what kind of usb interface chip your nano clone uses: look at the bottom side of your nano, there should be only one chip. If it is a ch340 you will need the drivers given by Al.
