[solved] switch and dimmer gone after update
  • Hi all,
    the todays update of the Mysensors modul in FHEM caused my switches and dimmer to not work anymore:
    error: "switch1 not defined: no mapping for reading switch1"
    and the same with the dimmer:
    "dimmer1 not defined: no mapping for reading dimmer1"
    did this also happen to some of you?
    thanks
    @jeti I haven't updated, but it looks like there were some updates of constants: github-link
    It's just a guess from looking at the github code and changes, but I would try to edit the fhem.cfg and replace
    attr <device_name> mapReading_switch1 <child_id> switch
    with
    attr <device_name> mapReading_switch1 <child_id> status
    and replace your
    attr <device_name> mapReading_dimmer1 <child_id> dimmer
    with
    attr <device_name> mapReading_dimmer1 <child_id> percentage
  • @m26872: Ithink you are right, that would have helped too, or just deleting the device and getting it autoincluded again help too 😃
    thanks
  • FHEM
