Humidity, temperature, motion and bunch of relays...
  • Hi everybody,
    I'm trying to have a sketch for my leaving room which should have 8 relays, humidity, temperature and motion sensors.
    I was able to merge few sketches to one and it works fine with 4 relays but i have problem with second "array" or sensors
    this is my working sketch
    #include <SimpleTimer.h>
    #define CHILD_ID_HUM 20
    #define CHILD_ID_TEMP 21
    #define CHILD_ID_MOTION 22
    #define RELAY_1  14  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define HUMIDITY_SENSOR_DIGITAL_PIN 19
    #define MOTION_SENSOR_DIGITAL_PIN 3
    #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
    DHT dht;
    SimpleTimer timer;
    float lastTemp;
    float lastHum;
    boolean lastTripped;
    boolean metric = true;
    MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
      gw.sendSketchInfo("HumTempRelayMotion", "1.4");
       // Register all sensors to gw
        gw.present(CHILD_ID_MOTION, S_MOTION);
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      //Serial.begin(9600);
      timer.setInterval(30000, getMeasure);
      timer.run();
      boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
      if (tripped != lastTripped) {
        lastTripped = tripped;
        Serial.print("M: ");
        Serial.println(tripped);
        gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    void getMeasure() {
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
  • @Tomasz-Pazio
    What is not working? The sensors (DHT & PIR) or the relays?
    You have a function "void getMeasure' but you don't specifically call for it in your main loop.
    What is the timer for?
  • Sorry I was to fast. I have problem with second "array" or sensors, first is working on pins 14-17 so analog. Second part should work on pins 5-8 but I have no idea how to make this. All works fine now but on 4 relays, I need to add 4 more.
  • @Tomasz-Pazio I read too fast as well, did not see 'timer.setInterval(30000, getMeasure);
    You could use an Array to link the relay pins to Relay 1-8.
  • @Dwalt think that I undersand the idea but no idea how to write this in code, google gives a lot of examples but hard for me to code this 😞
    @Tomasz-Pazio
    an approach with the relays would be like this bit of (untested) code:
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define NUMBER_OF_RELAYS 8
    const int relayPin[NUMBER_OF_RELAYS] = {5,6,7,8,14,15,16,17};  //<<<<<<<pin numbers
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.sendSketchInfo("multiRelay", "1.0");
      for (int i = 0; i < NUMBER_OF_RELAYS; i++)
        gw.present(i, S_LIGHT);
        pinMode(relayPin[i], OUTPUT);
        digitalWrite(relayPin[i], LOW);
      if (message.type == V_LIGHT)
         digitalWrite(relayPin[message.sensor], message.getBool()? RELAY_ON : RELAY_OFF);
  • @BulldogLowell works fine with this 🙂 thanks for support.
  • Hey !
    I'm trying to use your code to do a Motion/temp/humidity sensor, but I dont know why the motion sensor is sending 0/1/0/1... if there is nothing moving ?!
    Here is my code :
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2
    //#define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2
    DHT dht;
    SimpleTimer timer;
    float lastTemp;
    float lastHum;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
      gw.begin();
      gw.sendSketchInfo("Humidity/Motion", "1.0");
      pinMode(MOTION_SENSOR_DIGITAL_PIN, INPUT);
      gw.present(CHILD_ID_MOT, S_MOTION);
      timer.run();
        gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
    void getMeasure()
          lastHum = humidity;
    Do you have any idea what could be causing that ?
    Regards !
    @petoulachi it looks like your input pin for the sensor is floating. You can enable the internal pull-up to check ( INPUT_PULLUP i.s.o. INPUT)
  • I'm sorry I'm a newbie with arduino so I don't understand what you want me to test ?
  • If you were meaning that I have to do
    pinMode(MOTION_SENSOR_DIGITAL_PIN, INPUT_PULLUP);
    instead of
    It changes nothing !
  • I found where was the problem, I'm really a newbee... The motion sensor was plugged to the 3.3VCC, not 5V, doing this strange behaviour !
  • 15
