Energy Monitoring
  • I want to use the LM393 sketch to monitor the pulses of my Power meter. But how do I make it register every blink? I still have not figured out how to make a sensor wake up instead of just using sleep.
    This is the sketch:
     * Version 1.0 - Henrik EKblad
     * Example sketch showing how to measue light level using a LM393 photo-resistor
     * http://www.mysensors.org/build/light
    #include <MyTransportRFM69.h>
    #define CHILD_ID_LIGHT 0
    MyTransportRFM69 transport(RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, false, RF69_IRQ_NUM);
    MySensor gw(transport);
    int lastLightLevel;
      gw.begin();
      gw.sendSketchInfo("Light Sensor", "1.0");
      int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      gw.sleep(SLEEP_TIME);
  • Ah, don't know how I could have missed it.
    [http://www.mysensors.org/build/pulse_power](Power meter pulse sensor)
  • Can't get it to work. The sensor detects the power meter blinks and is presented as Energy monitor in the domoticz log. But it does not show under devices.
     * This sketch provides an example how to implement a distance sensor using HC-SR04
     * Use this sensor to measure KWH and Watt of your house meeter
     * You need to set the correct pulsefactor of your meeter (blinks per KWH).
     * The sensor starts by fetching current KWH value from gateway.
     * Reports both KWH and Watt back to gateway.
     * Unfortunately millis() won't increment when the Arduino is in
     * sleepmode. So we cannot make this sensor sleep if we also want
     * to calculate/report watt-number.
     * http://www.mysensors.org/build/pulse_power
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    boolean pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
      gw.begin(incomingMessage);
      gw.sendSketchInfo("Energy Meter", "1.0");
      gw.present(CHILD_ID, S_POWER);
      gw.request(CHILD_ID, V_VAR1);
      attachInterrupt(INTERRUPT, onPulse, RISING);
      lastSend=millis();
      unsigned long now = millis();
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        if (!SLEEP_MODE && watt != oldWatt) {
          if (watt<((unsigned long)MAX_WATT)) {
            gw.send(wattMsg.set(watt));  // Send watt value to gw
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // Pulse cout has changed
        if (pulseCount != oldPulseCount) {
          gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        gw.sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh;
        lastBlink = newBlink;
      pulseCount++;
  • I found a post at the domoticz forum where the same problem was described. He managed to solve it by doing this:
    "To have my software send something I removed those parts which check for sending frequency and also identity of values.
    I now send whenever a pulse occurs (which is every 20 to 120 seconds, depending). My network is rather small so far and
    my energy meter is using a power adapter so that should be no problem. How often do others update their Watt values?"
    But what parts do I need to delete? I tried to remove most stuff regarding to frequenzy but could not get it to complie after my tests.
    When running the "stock" sketch from mysensors.org I get this in my domotic log:
    2015-10-07 20:47:26.030 Hardware Monitor: Fetching data (System sensors)
    2015-10-07 20:47:56.166 Hardware Monitor: Fetching data (System sensors)
    2015-10-07 20:48:26.302 Hardware Monitor: Fetching data (System sensors)
    2015-10-07 20:48:56.437 Hardware Monitor: Fetching data (System sensors)
    2015-10-07 20:49:26.571 Hardware Monitor: Fetching data (System sensors)
    2015-10-07 20:49:48.781 MySensors: Node: 7, Sketch Name: Energy Meter
    2015-10-07 20:49:48.825 MySensors: Node: 7, Sketch Name: Energy Meter
    2015-10-07 20:49:48.870 MySensors: Node: 7, Sketch Name: Energy Meter
    2015-10-07 20:49:48.919 MySensors: Node: 7, Sketch Version: 1.0
    2015-10-07 20:49:48.963 MySensors: Node: 7, Sketch Version: 1.0
    2015-10-07 20:49:49.007 MySensors: Node: 7, Sketch Version: 1.0
    2015-10-07 20:49:56.783 Hardware Monitor: Fetching data (System sensors)
    2015-10-07 20:50:26.917 Hardware Monitor: Fetching data (System sensors)
    It looks a little bit weird that it presents itself three times in a row.
  • Sorry for spamming but I solved the problem. The Original sketch was fine. I removed the radio and resoldered it (RFM69W) And then everything was Ok. There must have been some bad connecton as the sketch sent 3x greeting message.
  • 24
