Ultrasonic Sensor+1 Relay node does not work
    I am trying to build a node with Ultrasonic sensor and 1 relay. I used the sample code and tried to build one. I am facing issues. The Domoticz will detect the ultrasonic sensor using the provided example code but when I merge them it gives error and does not detect. My sketch is as below:
    #include <NewPing.h>
    #define CHILD_ID_DISTANCE 1
    #define CHILD_ID_RELAY 10
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msg(CHILD_ID_DISTANCE, V_DISTANCE);
    int lastDist;
    boolean metric = true;
      gw.begin(incomingMessage, AUTO,false);
      gw.sendSketchInfo("Distance Sensor", "1.0");
        gw.present(CHILD_ID_DISTANCE, S_DISTANCE);
        boolean metric = gw.getConfig().isMetric;
        gw.sendSketchInfo("Relay", "1.0");
        gw.present(CHILD_ID_RELAY, S_LIGHT);
        pinMode(RELAY_1, OUTPUT);
        digitalWrite(RELAY_1, gw.loadState(CHILD_ID_RELAY)?RELAY_ON:RELAY_OFF);
    	int dist = metric?sonar.ping_cm():sonar.ping_in();
    	Serial.print("Ping: ");
    	Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
    	Serial.println(metric?" cm":" in");
    	  if (dist != lastDist) {
    		  gw.send(msg.set(dist));
    		  lastDist = dist;
      //gw.sleep(SLEEP_TIME);
      if (message.type==V_LIGHT) {
         // Change relay state
         digitalWrite(RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
         // Store state in eeprom
    I am unable to figure out why it is not working.
    The log file from Domoticz shows the below:
    2015-05-26 07:05:52.585 MySensors: Using serial port: /dev/ttyUSB0
    2015-05-26 07:05:57.410 Error: MySensors: Unhandled sensor (sub-type=13), please report with log!
    2015-05-26 07:05:57.429 Error: MySensors: Unhandled sensor (sub-type=13), please report with log!
    2015-05-26 07:05:57.440 Error: MySensors: Unhandled sensor (sub-type=13), please report with log!
    and it keeps on going.
    Below is the output when Node is connected to serial port.
    Ping: 11 cm
    send: 5-5-0-0 s=1,c=1,t=13,pt=2,l=2,st=ok:11
    read: 5-1-0 s=10,c=0,t=3,pt=0,l=5:1.4.1
    Ping: 9 cm
    send: 5-5-0-0 s=1,c=1,t=13,pt=2,l=2,st=ok:9
    Ping: 9 cm
    Ping: 11 cm
    I am using Raspberry pi as gateway with Arduino Uno. Arduino Mini Pro as node.
    Please help me figure out what could be the issue. Any help is really appreciated. Thanks.!😃
  • The distance sensor is supported in the beta version of Domoticz
  • 20
  • 7
