esp8266 gateway keeps resetting on keepalive
  • Hey guys, I've set up esp8266 gateway and one of the opensource controllers. esp8266 keeps restarting with the errors below. If I disable the controller then esp seems to work fine.
    The software has keepalive set and I believe that might be triggering this error. Has anyone seen anything like that?
    ESP8266 MySensors Gateway
    Connecting to vhome
    .......Connected!
    IP: 192.168.0.51
    Client 0 connected
    Client 0: 0;255;3;0;2;
    Exception (28):
    epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
    ctx: cont
    sp: 3ffeaca0 end: 3ffeaf20 offset: 01a0
    >>>stack>>>
    3ffeae40:  00000000 3fffdc20 3ffe97c7 40203ac0
    3ffeae50:  3ffeaf80 00000001 3ffe8fc9 4020b73c
    3ffeae60:  3ffeaf80 0000000b 3ffe98bf 00000000
    3ffeae70:  00000003 00000000 3ffe98a8 4020ae11
    3ffeae80:  00000001 3ffe98b4 3ffeaf80 4020ae11
    3ffeae90:  3ffe98b4 3ffe98b4 3ffeaf80 3ffeaf80
    3ffeaea0:  3ffe98b4 3ffe97c0 3ffe97c7 402024b4
    3ffeaeb0:  3ffe9ab8 3ffe98b4 00000000 40202784
    3ffeaec0:  3ffe8e48 00000000 000003e8 3ffe9c4c
    3ffeaed0:  00000000 3fff4c88 3fff4c18 3ffeaf4c
    3ffeaee0:  00000000 0000000a 00000000 00000000
    3ffeaef0:  40201c35 3300a8c0 00000000 3ffeaf4c
    3ffeaf00:  3fffdc20 00000000 3ffeaf44 40201c92
    3ffeaf10:  00000000 00000000 3ffe9f00 40100378
    <<<stack<<<
     ets Jan  8 2013,rst cause:1, boot mode:(3,7)
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    Connecting to vhome
    .....Connected!
    IP: 192.168.0.51
  • It looks like the problem that I also have with my gateway described in my topic
  • Snap here too.
  • It does look like the same issue. Mine does not restart on a sensor connection (I have one node with 4 reed switches) but totally restarts on keepalive call.
  • On further inspection it looks like a different issue since I don't get reboots unless connected to Mycontroller. If I shut down the software reboots stop. Sensors send things to the gateway just fine.
    If I set keepalive to very long then things are good and there are no reboots all the time(assuming it will reboot once that timer lapses). If I start mycontroller while esp is running then esp will reboot for sure.
    This has something to do with tcp sockets and keepalive.
    Are you guys getting the same resets when using dev-branch?
  • Can't get dev branch to build -
    GatewayESP8266.ino:131:27: fatal error: ESP8266WiFi.h: No such file or directory
    Did you change board type to NodeMCU?
  • Very sorry, I got past that point but forgot about it. I ended up having to remove all of the libraries and then extract dev branch, otherwise merging the two didn't work.
    I think this issue is now gone, I can keep controller running and the gateway doesn't reboot. I do have a new issue though, sensors now crash the controller (was not the case in 1.5)
    I just used a simple trigger example from dev branch and that crashes the gateway in some scenarios. It crashed it when I turned off the sensor node, it crashed when I opened serial monitor for sensor node, it crashes mid way, etc
    Seems like any client communication has a high chance to crash it.
    âm+ÿ¡šóÿ0;0;3;0;9;Starting gateway (1.6.0-beta)
    0;0;3;0;9;Radio init successful.
    scandone
    f 0, scandone
    .add 0
    aid 1
    pm open phy_2,type:2 0 0
    cnt
    connected with vhome, channel 6
    dhcp client start...
    .........ip:192.168.0.51,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.51
    0;0;3;0;9;Init complete, id=0, parent=0, distance=0
    0;0;3;0;9;Client 0 connected
    0;0;3;0;9;read: 20-20-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
    0;0;3;0;9;read: 20-20-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    0;0;3;0;9;Client 0: 20;255;3;0;6;M
    0;0;3;0;9;send: 0-0-20-20 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
    0;0;3;0;9;read: 20-20-0 s=3,c=0,t=0,pt=0,l=0,sg=0:
    0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1
    0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0
    0;0;3;0;9;Client 0: 0;255;3;0;2;
    Fatal exception (28):
    epc1=0x4000bf80, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x0
    0000000
    Exception (28):
    000
    ctx: cont
    sp: 3ffea5f0 end: 3ffea8a0 offset: 01a0
    >>>stack>>>
    3ffea790:  3fff1c88 40219430 3ffea980 402039e4
    3ffea7a0:  40213751 3fff4b78 00000001 3ffea7d0
    3ffea7b0:  3ffea7c0 00000004 3ffeabfc 00000000
    3ffea7c0:  00000003 00000000 00000001 00000000
    3ffea7d0:  3ffeaa68 3ffeaa74 0000000a 3ffeaac8
    3ffea7e0:  00000001 3ffeab98 00000000 40203f34
    3ffea7f0:  00000000 3ffeaa68 3ffeab98 40203624
    3ffea800:  3fffdc20 00000000 3ffeaa58 3ffeabfb
    3ffea810:  00000000 00000003 00000000 402042f3
    3ffea820:  3ffea8cc 3ffea924 00000014 4020217e
    3ffea830:  00000000 3fff4bc8 3ffea950 00000000
    3ffea840:  00000010 00000000 00000014 00000002
    3ffea850:  00000003 00000012 00000000 3ffeaa60
    3ffea860:  3fffdc20 00000000 3ffeaa58 40204a1c
    3ffea870:  40203c55 00000000 3ffeaa58 4020435f
    3ffea880:  00000000 00000000 3ffeaa58 4020496a
    3ffea890:  00000000 00000000 3ffe9880 40100118
    <<<stack<<<
    òm+ÿ(æz=0;0;3;0;9;Starting gateway (1.6.0-beta)
    scandone
    f 0, scandone
    .add 0
    aid 1
    cnt
    .IP: 192.168.0.51
  • Removed the sensor completely and gateway still reboots, it just takes much longer now
    scandone
    f 0, ....scandone
    .add 0
    aid 1
    cnt
    .IP: 192.168.0.51
    epc1=0x4000bf80, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
    Exception (28):
    ctx: cont
    >>>stack>>>
    3ffea790:  3fff1c28 40219388 3ffea980 402039e4
    3ffea7a0:  402136a9 3fff4b68 3ffeaa58 3ffea7d0
    3ffea7b0:  3ffea7c0 00000004 3ffeabf4 00000000
    3ffea7d0:  3ffeaa60 3ffeaa6c 0000000a 3ffeaac0
    3ffea7e0:  00000001 3ffeab90 00000000 40203ec8
    3ffea7f0:  00000000 3ffeaa60 3fff4bb8 40206a0a
    3ffea800:  3fffdc20 00000000 3ffeaa50 3ffeabf3
    3ffea810:  00000000 00000003 00000000 4020428b
    3ffea820:  3ffe8f20 00000000 000003e8 402024f1
    3ffea830:  00000000 3fff4bb8 3ffea950 3ffea860
    3ffea840:  00000000 00000004 3ffea950 40202d34
    3ffea850:  3fffdc20 00000000 00000000 3ffeaa58
    3ffea860:  3fffdc20 00000000 3ffeaa50 40204994
    3ffea870:  40203be9 00000000 3ffeaa50 402042e3
    3ffea880:  00000000 00000000 3ffeaa50 402048e6
    <<<stack<<<
    òm+ÿP9<áÿ0;0;3;0;9;Starting gateway (1.6.0-beta)
    scandone
    f 0, ....scandone
    .reconnect
    f -240, ....scandone
    .reconnect
    f 0, ....scandone
    .add 0
    aid 1
    cnt
    .IP: 192.168.0.51
    What do you mean by:
    Did you alter the esp-gateway sketch? If so, you might wanna post it here.
  • Other than login/password and commenting out static ip part nothing was changed.
    I wonder if it's power even though I'm powering from one of those breadboard power sources that's connected to 9v and is feeding 3.3v to esp/radio.
  • Looks like I might have jumped the gun on dev being better than release branch. I changed the keepalive timeout to a long time and constant reboots stopped.
    So this is the same issue then, it might just get exacerbated when node has something to say to the gateway/controller.
    By removed sensor I meant I turned it off completely (it is the only sensor node in the network). Gateway was still rebooting even with no nodes on the network.
    I took apart my ethernet gateway so I think I'll just stick with this one and set keepalive to a long time. Gateway will still reboot but it won't be every minute and that should be ok until the fix is found.
  • @vlad I am having the same issue. Where did you change keepalive timeout to a long time?
    Essentially, what file did you edit, what parameter and to how long?
  • 15
  • 6
  • 6
