1.4 Beta
  • Code Contributor
    @hek
    I just tried to send myself a picture over the network. real ugly code but it worked.. thought if I put a small cam and someone rings on the doorbell or something.. 🙂 (Right now I just read the data from SPI flash)
    @Damme
    great
  • Code Contributor
    I've tried the lib for a while now and found the following:
    Then using ack=1 the returned message is exacly the one I sent. No way of knowing if its a request or an ACK.
    example:
    Client sends
    3;255;3;6;0 (Give me configuration 0 (btw, why not leave config as a byte 0-255 instead of hardcoing it? I could have plenty of uses for configuration-values.)
    Gateway responds: 3;255;3;6;M and requests ack
    client sends
    3;255;3;6;M
    my software tried to lookup config id 'M' (Not a big deal for letter, but what if its a number?)
    maybe ACK should be some sort of incremental number in return in special message type. I dont really know what is best.
    It would be great if GW resends the messsage automatically a couple of times (configurable) if ACK = 1.
    I've also noticed during DEBUG enabled that the message gets overwritten by old one, i.e.
    send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=15,st=fail:1.4b1 (18848a2)
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=4,st=ok:test1 (18848a2)
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:2.0t1 (18848a2)
    (message 2: test1, message 3: 2.0)
    Edit; One more thing
    Do I really need one gw.process(); before each gw.send(..); in the loop? I seam to loose messages if I dont do like that.
    // gw.sleep(SLEEP_TIME); //Seems to break recieing message, loosing ~75%
    @Damme Other wireless protocols usually have a counter which is increased with each message. Returning the counter as an ack would be sufficient to correlate the ack and the original message.
    Returning the whole message seems like overkill indeed...
    The send-methods could e.g. return the Id counter of the message sent, and an app waiting for an ack on that message should check for this value in any ack received (using some timeout)
  • Code Contributor
    Additional comment on config;
    I think it should be request config, response config messages.
    I also think its a bit odd that the actuator reports as
    gw.present(2, S_LIGHT);
    but requests as
    if (message.type==V_LIGHT) {
    V_LIGHT != S_LIGHT (2 vs 3)
    I think the def should follow as much as possible.
    hope any of my thoughts are somewhat useful
    @Damme there's a lot of Vera legacy in there... This forum had a discussion going on about decoupling from Vera, but I'm afraid that got lost in the crash...
  • Code Contributor
    me just dumb here, delay(SLEEP_TIME); works. gw.sleep puts radio in sleep I guess.
    gw.sleep() puts both Arduino and radio to sleep.
    That mean you might have to rememeber the original message. The idea is to have all the information necessary in the callback.
    In my example sketches (e.g. RelayActuator) the ack message actually changes the relay status when the ack comes back from gateway. If not full message came in you would have to keep buffers with sent messages and start matching counter-values. Much more complicated.
    But a message counter will probably be necessary if/when we start encrypting messages to prohibit replay attacks.
    @Damme
    I actually thought about having a bit in the message header which says if the message is an ack or not. With that implemented you would just call a msg.isAck() to determine if the incoming message is an ack message. Would that be ok?
    You shouldn't need to call gw.process() after each send. It is only necessary in the loop() section if you expect incoming messages or have enabled repeater mode.
    I don't understand what you mean with messages getting overwritten with DEBUG enabled. Could you explain it a bit more (with an example?).
    @Yveaux
    To pick up the discussions about existence or not of getTemp().
    A better solution would probably be to create a MySensorsATMega328-subclass of the library which contains AtMega specific stuff such as sleep() and potentially getTemp().
    This class should also implement the EEPROM specifics.
    You have to remember it anyway when you regard the message as lost after some time without an ack and you decide to send the message again. Only for a simple sensor node which sends a sensor value with ack, waits for an ack reply and then continues with the next sensor value this wouldn't be necessary. When a single node has multiple messages with ack 'in flight', you definately need message buffering.
    This is independent from the ack message format IMHO.
    I also think message buffering and retrying, when implemented, should be part of the MySensors library.
    This improves realiability even more than with the NRF24 ack's enabled and avoids putting the retry-burden on the clients of the library.
  • Code Contributor
    here is a serial output from one of my nodes
    repeater started, id 3
    send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=4,st=fail:test1 (18848a2)
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:2.0t1 (18848a2)
    send: 3-3-0-0 s=0,c=0,t=7,pt=0,l=15,st=fail:1.4b1 (18848a2)
    send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=15,st=fail:1.4b1 (18848a2)
    send: 3-3-0-0 s=2,c=0,t=3,pt=0,l=15,st=fail:1.4b1 (18848a2)
    send: 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:1.4b1 (18848a2)
    and the sketch has: gw.sendSketchInfo("test", "2.0");
    yes, I know they all failed, I'm using the microwave oven atm, it kills the channel 76 (usually uses 21 but forgot to change last time, works better for me here..)
    Ahh.. The strings-payloads don't seem to be terminated correctly.
    I wouldn't restrict to the Atmega328. Quite some AVR's have this or simular behaviour and it would be nice to have a single library usable for all (e.g. using #ifdef's if absolutely necessary).
    Seems like you're trying to move towards board- and cpu-support packages, like Linux does...
    Another way to tackle it is to create a separate library to read the AVR's internal 'sensors' like the temperature sensor and e.g. the VCC voltage (as I did in https://github.com/Yveaux/arduino_vcc) and another one for persistent storage (EEPROM), and one for power management (sleep). This approach seems to follow the Arduino-way of creating a library for every 'function'.
    It all depends on whether you think big and target different hardware (MPU) platforms or if you want to stick with the Arduino (or even only the ATmega328). When porting MySensors to the RPi it would be very nice if the MySensors library and examples would directly compile on both platforms.
    This requires libraries to have a clear interface which doesn't limit portability to one platform or architecture.
  • Code Contributor
    Hello
    I was looking in the nrf24l01 datasheet and found "Setup of Automatic Retransmission"
    Is this something that mysensors use?
    @Damme at least in the 1.4beta release. I think it's disabled in 1.3
    Yep, as @Yveaux says we use it it 1.4.
  • Hi guys,
    I just got relays working with but struggling requesting a variable value on Beta 1.4.
    My set variable commands looks as follow.
    Switching On - > 1;1;1;0;2;1 (work as expected)
    Off -> 1;1;1;0;2;0 (work as expected)
    Request variable for the same relay -> 1;1;2;0;2; (sets the relay to 0 ???)
    Can someone confirm if my request variable command is correct and if not what should it be?
  • Code Contributor
    @lodewyk I use this:
    void incomingMessage(const MyMessage &msg) {
    if (msg.type==V_LIGHT) {
    if (strlen(msg.getString())==0) {
    gw.send(message.setSensor(msg.sensor).setType(V_LIGHT).set(digitalRead(msg.sensor-1+RELAY_1)?RELAY_ON:RELAY_OFF));
    digitalWrite(msg.sensor-1+RELAY_1, msg.getBool()?RELAY_ON:RELAY_OFF);
    gw.saveState(msg.sensor, msg.getBool());
    (How do i use [code] ?? I start to hate this forum :P)
    @lodewyk
    The relay example does not support requesting state. You must add some code in incomingMessage() to handle incoming request-messages (and reply to them).
    To reply incoming request-command in incomingMessage for the RelayActuator-example do something like this (note I have not compiled/tested this)
    if (mGetCommand(msg) == C_REQ) {
         mSetCommand(msg, C_SET);
         msg.setDestination(msg.getSender());
         msg.set(gw.loadState(msg.getSensor());
         gw.send(msg);
    } else (
        // Do the normal stuff here
  • @DAMME and @HEK
    Thanks , very helpful.
    I got so occupied with the commands and never thought about the sensor code.
    This forum uses markdown. If you need help, press the little questionmark-icon in the compose window. http://daringfireball.net/projects/markdown/syntax
    To decorate your codeblock use 4 spaces or one tab character first on each line.
    @lodewyk hey man, you've got -2 posts.... How's that possible?
    Pushed a few new changes/bugfixes. Sorry for the slow progress. Had to wait until we got home and had the chance to do some verification.
    • Ack bit in header indicating if message is an ack (see RelayWithButton for an example how to read it out).
    • Sleep functions now takes unsigned long. This allows sensor to sleep for than 30 sec 😉
    • Corrected string termination
    https://github.com/mysensors/Arduino/commits/development
    A major code drop coming from @ToSa has now been merged into 1.4. It contains:
    • The new MySensors Bootloader supporting Over-the-air sketch updates ("client"-side).
    • A simple NodeJs Controller to test the OTA stuff ("server"-side).
    • Changes to cope with new sketch meta data stored in EEPROM and conversion between serial protocol/binary data and some new STREAM command types added.
    • A new internal command has also been added to allow resetting a node remotely.
    A more detailed change log can be found here:
    https://github.com/ToSa27/Arduino/commits/development
    I haven't had time to test myself yet but everything has been verified by @ToSa and is reported working. He is on a business trip right now so advanced bootloader questions have to wait until he's back.
    @hek Sounds like a good step forward!
    Only one boot loader question: does this mean we can use an external boot loader or do we have to use an external boot loader now?
    @marceltrapman
    The OTA stuff is optional. But if you want to be able to hot deploy sketches over the air, you have to install the MySensors bootloader.
  • Code Contributor
    @hek There are still some problem with string termination,
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=9,st=fail:Relaytest848a2)
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0aytest848a2)
    read: 5-5-0 s=11,c=1,t=1,pt=0,l=4:58.4
    send: 5-3-0-0 s=11,c=1,t=1,pt=0,l=4,st=fail:58.4
    send: 3-3-0-0 s=10,c=1,t=0,pt=0,l=5,st=fail:26.20
  • Code Contributor
    @Damme My bad wrong working directory! sorry
    Thank you 🙂
    And thanks again!!!
  • How do I request information from a node from the gateway?
    I have a relayactuator node with 2 relays that is transmitting its initial state at the startup of the node. This is also received by the gw.
    But after that I cant seem to request the current relay status from the node by sending a message from the gateway.
    I tried lots of combinations, nothing worked.
    I thought this would be correct:
    1;2;2;1;2;0\n
    1=node number
    2=sensor (relay number 2)
    2=request
    1=ack message
    2=light
    0=string??
    Can anyone point me in the correct location?
    maybe a new API page for 1.4 would be handy
    edit: also I can't find anywhere what the debug letters mean
    what is s=,c=,t=,pt=,l=,st= ??
    @timminater
    You cannot request state from a node without programming a little . I answered exactly this question a couple of posts back in this thread.
    http://forum.mysensors.org/topic/168/1-4-beta/34
  • @hek
    Could u plz help me
    getting in eth GW. Vera and Libs updated.
    **0;0;3;9;Arduino startup complete.
    0;0;3;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
    0;0;3;9;version mismatch0;0;3;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
    @mitekg
    All the zeroes indicates that something is wrong in radio communication. Check wires.
        Is any instructions, how to use this?
        thx.
  • Code Contributor
    @hek
    I think BASE_RADIO_ID should be declared in MyCofig.h
    @hek @ToSa
    Could we get a description of how the OTA programming works?
    (Terminology: the program flash is divided into a bootloader section and an application section; compile sketches go in the application section)
    One approach is to have a separate flash or eeprom chip which one somehow fills (this could even happen at the application level). When booting, check this flash or eeprom and if valid - load into internal program flash, clear the vallidity of the external flash or eeprom (so you won't loop loading it again) and reboot. When you reboot there will be no valid image to copy from external memory, so you jump to the start of internal application flash. This takes external flash as large or larger than application flash (eg: >= 32 KiB for the 328p)
    I think you are taking a different route, where the bootloader is somehow given control, after which it receives nRF packets to RAM, periodically writing another page from RAM to the application section of internal flash. When done, reboot.
    If booting and there is no valid image in external memory and the CRC of the internal application flash section is valid, jump to it as usual.
    I'm not sure if you can also still use serial programming.
    This could be all wrong. It implies keeping (at least part of) the nRF library in bootload program flash, to receive packets. I'm putting it out as a hypotheis to help elicit the real description.
    How big is the OTA bootloader?
    Yes, that's a better place for it.
    @Zeph, @mitekg
    Right now the OTA works without any need for external flash. @ToSa will have to answer the details when he's back (like size, building, serial programming).
    Yes it uses a VERY stripped down rf24 library.
    https://github.com/mysensors/Arduino/blob/development/Bootloader/MyOtaBootloaderRF24.h
    Not much of the MySensors library is needed.
    https://github.com/mysensors/Arduino/blob/development/Bootloader/MyOtaBootloader.c
  • I am in process of upgrading to 1.4b1 - have most things working. I noticed that my status consistently fails during setup() when presenting sensors AND also never receive a return message from controller after a time request. It's always the same two failures.
    Everything works after adding a 100ms delay between calls. Not sure if there's a timing problem somewhere.
    Hek - as always thanks for ALL your contributions. 🙂
    Joe K.
    SERIAL CONSOLE OUTPUT:
    sensor started, id 4
    send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=15,st=ok:1.4b1 (18848a2)
    send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=11,st=ok:LCD Display
    send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=15,st=ok:1.4b1 (18848a2)
    send: 4-4-0-0 s=1,c=0,t=6,pt=0,l=15,st=fail:1.4b1 (18848a2)
    send: 4-4-0-0 s=2,c=0,t=8,pt=0,l=15,st=ok:1.4b1 (18848a2)
    send: 4-4-0-0 s=255,c=3,t=1,pt=0,l=15,st=fail:1.4b1 (18848a2)
    CODE in setup():
    gw.sendSketchInfo("LCD Display", "1.0");
    gw.present(CHILD_ID_DHT_HUM, S_HUM, true);
    delay(100); // needed otherwise status may come back as failed
    gw.present(CHILD_ID_DHT_TEMP, S_TEMP, true);
    gw.present(CHILD_ID_BMP085_BARO, S_BARO, true);
    delay(100); // needed otherwise status may come back as failed & time request doesn't work
    // request time
    gw.requestTime(receiveTime);
  • Code Contributor
    @hek Does the gateway use any eeprom?
    @Damme
    Yes, it uses eeprom for storing routing information.
  • Code Contributor
    @hek ok, how many bytes does it use?
    @Damme
    If you want to store you own data in EEPROM you can use the provided saveState(), loadState(). It makes sure you won't overwrite anything important. If 256 bytes isn't enough you can start writing at position EEPROM_LOCAL_CONFIG_ADDRESS defined in MySensors.h.
  • Code Contributor
    @hek I just cant figure this out:
    0;0;3;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=2,st=fail:42
    the last one isn't sent.What have I missed?
    I have also tried 42 as int (no "")
    	msg.destination = 255; 		//NodeID
    	msg.sender = GATEWAY_ADDRESS;
    	msg.sensor = 255;	  				//SensorID
    	msg.type = I_ID_RESPONSE;			//MsgType
    	mSetCommand(msg,C_INTERNAL); 		//Subtype
    	mSetRequestAck(msg,true);			//Request ack
    	mSetAck(msg,false);
    	msg.set("42");					//Payload
    	sendRoute(msg);
    @hek Do you know if the ota is something initiated by the controller or do we update the gateway with a new version and will the gateway be responsible?
    @marceltrapman
    The controller will be responsible for initiating and serving the new sketch version. There is basically no changes in gateway except being able to handle binary data.
    @Damme
    You should probably not request ack back on a id-response. But I doubt that is the cause for transmission error. What is happening in the sensor node?
  • Code Contributor
    @hek Tried with no ack also. And the node doesn't recieve anything. I'm out of components to build myself a sniffer right now.. Might have to kill something.. 💥 I can recieve From the node though.. but the node does not read from gateway..
    @Damme
    You only live 190 km from me. Come and get some 😄
    What kind of antenna on your gateway? Have you tried lowering transmit power of gateway?
  • Code Contributor
    @hek I fixed the problem , it was the RF24_PA_LEVEL_GW .. needed to be low.
    You are correct with the ack on id-response, it gets all fucked up. Stuck in loop requesting ID 10+times/second. And doesnt register the id.. Too bad. would be really good for me to know if the sensor actually got the id_response or not... (and if it's sent as node 255 or node newid doesnt really matter..)
    edit:
    I changed my aproach to checking if sendRoute(msg) is true. But I still have a problem that the node actually recieves the packagt but just ignored is. sometimes I need to reset the node for it to get accept the new ID.. example;
    0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:20
    0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:21
    0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:22
    0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:23
    I'll try to look at the debug output on the node tomorrow..
    btw: \n missing line 278 mysensor.cpp debug(PSTR("version mismatch"));
    How do I get this started Henrik?
    @marceltrapman
    Until @ToSa is back, I suggest you have a look at how the NodeJSController serves hex-files.
    https://github.com/mysensors/Arduino/blob/development/NodeJsController/NodeJsController.js
    @hek I wanted to update my MQTT gateway to 1.4beta state but run into a problem with the serial message format.
    If I interpret the code right, the messages sent (in serial message format) to the ethernet gateway (over ethernet, so from my linux system running the MQTT gateway) contain 6 fields, of which the 4th is the ack flag.
    Messages received from the ethernet gateway contain 5 fields, with no ack indication.
    Shouldn't the message format be identical in both directions, as it is for the 1.3 version?
    @Yveaux
    Yes, It might be interesting (for the controller side) to use the 4th field to flag if the received message is an ack or regular message.
    ...so for outgoing you enable receiver to send ack back. And incoming the flag indicates if this as an ack or regular message.
    Make sense?
    @hek said:
    Make sense?
    Makes sense 😉
    Short question. I'm browsing the 1.4 code and is there a replacement for waitForMessage? I've looked into the code online but can't seem to find it. And if not, is it possible to attach the radio to an interrupt to call an interrupt routine on incoming message?
    The last question is a definite yes, see for example https://github.com/Yveaux/NRF24_Sniffer/blob/master/Arduino/NRF24_sniff/NRF24_sniff.ino function handleNrfIrq. Connect the NRF24 IRQ to pin 2 and call attachInterrupt to register the interrup handler.
    Be very careful what you do in this interrupt handler, though. Don't try to receive any message for example, as the SPI access to the NRF24 is not interrupt-proof, as is the MySensors library!
    @John
    Yep, as @Yveaux says, be careful what you do inside interrupt handler.
    Not sure what you try to archive here.. but in 1.4 you should usually just call process() in your loop(). The callback you registered a in begin(callback) will be called on incoming messages.
    See RelayActuator for an example.
    @Yveaux
    Darn, i hoped it could.
    @hek
    I'm averaging sensor results, so i read sensors every second an send them every minute, also this setup has an 16x2 display attached to show the values. But i would like it to be bi-directional with the server so it can display the server send data. Thus if i would use waitForMessage i can let it wait about a second for a message read sensor values, and let it wait for a second again. (because i understood it blocks?)
    @John You can obtain the same result as the old waitForMessage by registering a callback. Have this callback set a flag and call process() in the loop, as hek suggests.
    You could also turn things around and read and average your sensors from a (timer)interrupt handler.
    But when you're not completely confident with using interrupts then its better to avoid them and just process everything from your loop(). Interrupts can introduce lots of nasty problems if you don't know exactly what you're doing!
    @Yveaux
    Well, that was my first try and hoped it was interrupt based because of one wire connected on arduino pin 2 to IRQ on the NRF. The reason i asked it because i saw an example from an other library: http://maniacbug.github.io/RF24/pingpair_irq_8pde-example.html .
    I will have to investigate if any of the components is using which timer and what will be influenced by it. I'm using an HD44780 alike as display so i'm not sure because never dived deep into the used library.
    about 90%?
    @hek
    It would be nice if a waitForMessage like functionality would be included in 1.4.
    @hek Any idea when 1.4 will become the production version?
    @clippermiami
    We're still making small changes in the protocol and serial API which we need to stabilize before release.
    I also need time to update the main site to reflect the new version before its "released" .
    Added few small changes:
    • Add dimmable LED actuator example (converted @blacey 1.3 example)
    • Rename PING to the more suitable FIND_PARENT
    • Float values sent in binary format over the air
    • Move base-radio-id to MyConfig.h
  • Code Contributor
    @hek another suggestion for addition
    RelayWithButtonActuator
    incomingMessage should check if there is any payload or not. (could be bad package)
    I use empty payload as a request for latest state (Yes I could do this some other way but I think it is logical..)
      if (msg.type==V_LIGHT && strlen(msg.getString())!=0) {
    Because of the use of custom variables and the possibility of receiving and sending and of many sensor type possibilities is it possible to add a "sensor" type of S_OTHER (or alike)? I think this then would be in line of having var types V_VAR1, etc.. of which then would be something else then defined.
    This will add the possibility to send other then sensor related data. This is of course possible but could semantic wise be more applicable.
    @John
    Yes
    A small serial protocol breaking change was just checked in. @John and @marceltrapman you might want to have a look at this.
    Serial protocol changed to allowing controller to know if an incoming message is an ack. Outgoing and incoming serial messages now also have the same parameter count.
    radioId;childId;messageType;ack;subType;payload\n
    Where ack parameter means the following:
    outgoing: 0 = unacknowledged message, 1 = request ack from destination node
    Incoming: 0 = normal message, 1 = this is an ack message
    (previously only outging messages had the ack-flag)
    @hek
    Thanks for the heads up. This will give a good way of tracking messages send controller wise. I can take a look at it tomorrow evening if you would like a third party ack this works ok.
    @hek Thanks for the quick response!
  • Code Contributor
    @hek I have a couple of questions:
    Have not tested it yet, but that now ack's are possible i would like to implement a retry queue next to a normal send queue. The questions then would be:
    • How long does it take for the longest possible message to be send?
    • Is there a delay needed between each send?
    • Is there an ack timeout?
    John.
    @Damme Yeah, so header changed again... Madness 👊
    I'll have to update the dissector then...
    @John
    The send time depends on how many hops the message need to make. But on the controller side you could perhaps wait for a couple of second before trying again.
    There is no ack timeout but each hop on the way to the destination will only be tried once (using the build in retry functionality of the nrf-chip).
  • @hek Any tips on upgrading the June 1.4b1 to the August 1.4b1. I just attempted it with disastrous results. 🙂
    I started off.
    1. Uploading the Vera files
    2. Re-compiled the new gateway (after changing the my IP Address and such)
    3. Re-complied the Repeaters
    Just to get going. Both repeaters failed at startup with the standard FAIL in the debug logs. Wiping the Eeprom and trying again did not work. Dropping the repeaters for vera and re-including did not work? Finally went back to the June build and restored the vera from last night and then two other units failed to come back online. Had to replace the antennas on those two units to get them back on-line – BIZARRE.
    1. Do all the sensors have to be updated at once?
    2. Will existing sensors under the June 1.4b1 build co-exist with the August 1.4b1 Gateway build?
    3. Can we just recompile our existing June sketches under the new mySensors library as long as no compile errors show?
    @lininger
    Yes, you'll have to recompile/update them all as message format has changed. No need for wiping eeprom or re-include sensors. Also update Vera plugin.
    Replacing antenna should not be necessary and I don't understand why that would change anything..
    @hek I had a look at the latest state of the 1.4 header format and saw the sender/last/destination have moved to the front position.
    This means the protocol version is, once again, located at a different position w.r.t. 1.3 and earlier 1.4 version.
    For software trying to interpret any MySensors message (e.g. my sniffer or a (future) MySensors version supporting different protocol versions) or software that checks the library version to match with its own version it becomes nearly impossible to detect which library version a message was sent with.
    I propose to start any message, now and in the future, with a protocol version (use a full byte or use some remaining bits for protocol independent data) and stick to that. This makes life for sugested applications a lot easier.
    Adding a version which has a different offset every time makes no sense...
    @Yveaux
    Sorry.. the sniffer slipped my mind. The purpose was to prepare for future encryption (keeping the changing "last"-field first) and potential split of the routing information and payload. Which would be necessary for supporting other transportation layers (like RadioHead). They might not be interested in any MySensors version-specifics first in the radio message.
    Do you have any suggestion?
    It's in my post hek 😉
    @hek I have another question: when sending from a sensor to a gateway the data can have all kinds of formats (text, byte, float etc) which comes out the gateway through the serial protocol. When sending the other way, I guess the serial data is always sent as text by the gateway to the sensor, right?
    Too bad we can't also use different formats when sending through the serial api... Did you think about this?
    @Yveaux said:
    It's in my post hek
    Yes, you suggest to always have but that might not be possible if we choose some other transportation layer (which most probably will use the first bytes for it's own routing).
    Yes, I've thought about it. We have a couple of options here. Start type:ing variables through the serial protocol (controller must send datatype) or have a hard coded variable->type map on arduino side. Both of these are valid options.
    A binary serial protocol is also an option (could be an option when building gateway).. But that makes it harder to debug e.g. Arduino Serial Monitor.
    Then the transportation layer data is not part of mysensors protocol. It's that simple!
    IMHO This again boils down to nested protocol headers which we talked about before.
    The routing info is part of transportation layer (it could even have its own version info) followed by the mysensors header ( starting with a version number) which tells us what's in the message. Then come the actual data, be it a value, presentation info or whatever. I can make a sketch of this structure if that helps in the discussion.
    @Yveaux
    I think we agree. Only problem is that I haven't split up the structure in mysensors-transportation/mysensors-header/mysensors-payload yet but if you look from the sniffer side this would not matter.
    Please post you suggested structure (but in a new thread).
  • Code Contributor
    I got this question from a friend and since I dont know the answer either;
    I'm trying to figure out the sleep mode and if the radio module wakes up or not (via INT pin 2) .. but for me it does not seam to do this. Which sleep-modes does 1.4b have and how do I see if the message is for me, and if not continue sleep?
    @Damme
    The radio interrupts is not used at the moment.
    It uses the following sleep modes
    LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
    or
    LowPower.powerDown(SLEEP_XXXXS, ADC_OFF, BOD_OFF);
    Depending on if you want timer to wake up or not. Radio is always put to sleep.
    For more details, check out MySensor.cpp.
  • I'm trying to create my own controller in Node-Red.
    My setup is as followed:
    Motion Sensor arduino with standard example sketch <--> SerialGateway arduino with standard example sketch <--> USB <--> Node-Red (installed on Raspberry PI)
    My SerialGateway receives the request for a node ID (255;255;3;0;3;)
    I then return a serial command: 255;255;3;0;4;1
    You can see my Node-Red output below:
    For some reason my SerialGateway is not broadcasting my command. It's only repeating the above commands sevral times;
    Am i using the correct protocol values or is there something else I should do?
    @warawara
    Did you remember sending a newline?
  • @hek
    Yes I did.
    My Node-Red is configured to send a newline after every command.
    But just to make sure I also tried adding it to the string.
    Same result.
  • @hek
    I assume sending de command in ascii is good or do I need to send a binary buffer?
    @warawara
    If it's working from your gateway Serial Monitor in IDE you must be doing something wrong in your program.
  • @hek
    Not working in IDE.
  • @hek
    Got it working, but my solution is not very satisfying.
    I swapt the sketches on my 2 arduino's.
    Original arduino setup was:
    SerialGatway - Arduino pro mini 3.3v (including Decoupling-Capacitor)
    Motion Sensor - Arduino Uno (including Decoupling-Capacitor)
    Now the sketches are switched and it works.
    Eventually I will be working with only Arduino pro mini's but still the original setup should have worked.
  • Code Contributor
    @warawara did you try clearing using clear eeprom? That helped me some times. Dont really know why some nodes just wont want to recieve packages..
  • @Damme
    Thanks for the tip.
    I will try that in the future. But I don't think it was a problem of not receiving on the sensor part. I think it was a problem with not sending on the Serial Gateway part.
    But I got it working now!
    Ok, So I took the plunge and upgraded to 1.4.b1, and everything went "OK" with one glaring exception...... All temperatures display in Celsius. No matter what I do, I can't seem to get it to display in Fahrenheit..
    Any Idea's?
