@gohan said in Arduino Pro Mini Shield for RFM69(H)W:
If I remeber right that pin is used as input so the RFM69 is not receiving any 5v signal. In addition there are people claming they have the RFM69 module working on 5v on data pins and 3.3v on vcc, but I hardly suggest to do it.
thank you just what i thought .
about direct 5v on data...well... i seen a big red sign saying n :DONT do it! lol
Level converters are so cheap...that i ordered 5 or 10 thoguether with rfm69 board.
sorry about hijack this topic, i though i was on general discussion
Hi all,
Should anyone face the same problem, I found the root cause: brownout threshold. I burned a new bootloader (Optiboot 8.0) without such trigger and the node has been working with used batteries (~2.7V) since May.
Hope this helps.
This should work with Domoticz, it's what I intend to use with it. I've received the boards from China and I'm currently working on a version 2 of this board. There are some errors in the design of version 1 that I need to get out. New version will be up shortly.
@JahFyahh - I still haven't managed to et round to it. I've been really busy since this project and its still hectic here. I'm sure i read a few reviews somewhere, here or google. Not sure.
@nekitoss
I used 3.3V pro mini with regulator removed and powered by Vin pin. Also removed leds from the pro mini.
I used minicore bootloader.
I used the small pir sensors and again removed the regulator to power directly from the pro mini outputs.
After that sleep the node and trigger on interrupt.
Send battery level once a day.
Use inbuilt battery level monitor and not external components that constantly drain power to get battery level.
1.8V is 0% on the graph (not visible yet!) but I have had nodes working below 1.7V It's a matter of luck with that it seems.
Hope this helps you on the right track. I'll try and help if you want.
This is the latest image and still going strong after 18 months. Voltage is at 2.903V
Here is photo of the test example - I need to make a case and produce more of them over winter.....
Here is the same build/code of a window sensor. Similar time frame but hardly triggered.....
