"Sketch Config" (I_CONFIG) Handler
  • This flow takes care of the challenge/response for when a sensor asks what config to use (Metric or imperial).
    By default, the code returns M for metric. I don't believe Imperial is used anywhere, but it can be changed to I... if you support it in your code. (Honestly, no clue, but some sketches do make use of the call getConfig() .)
    [{"id":"8e3e8f02.7fd0c","type":"mqtt-broker","z":"63842e72.893f78","broker":"localhost","port":"8883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"15","cleansession":true,"willTopic":"","willQos":"0","willRetain":null,"willPayload":"","birthTopic":"","birthQos":"0","birthRetain":null,"birthPayload":""},{"id":"57ad0c01.895c9c","type":"mqtt in","z":"63842e72.893f78","name":"Sensor Requests Config","topic":"MySensors/+/255/3/0/6","broker":"8e3e8f02.7fd0c","x":105,"y":993,"wires":[["cd60b38.ef7405"]]},{"id":"86a8016b.bd47a","type":"mqtt out","z":"63842e72.893f78","name":"","topic":"","qos":"","retain":"","broker":"8e3e8f02.7fd0c","x":672,"y":993,"wires":[]},{"id":"65a6cc53.392ccc","type":"function","z":"63842e72.893f78","name":"Metric/Imperial definition","func":"var config = \"M\" ; //M for metric, and I for imperial\n\nmsg.payload = config + \"\\n\";\nreturn msg;","outputs":1,"noerr":0,"x":488,"y":993,"wires":[["86a8016b.bd47a","165c11cd.40adbe"]]},{"id":"165c11cd.40adbe","type":"debug","z":"63842e72.893f78","name":"","active":true,"console":"false","complete":"false","x":692,"y":952,"wires":[]},{"id":"cd60b38.ef7405","type":"delay","z":"63842e72.893f78","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":295,"y":993,"wires":[["65a6cc53.392ccc"]]},{"id":"9687065f.28c08","type":"comment","z":"63842e72.893f78","name":"I_CONFIG handler ([0-255];255;3;0;6;[M or I])","info":"Whenever a sensor announces itself to the network as [any];255;3;0;6;(null),\n\nThe cntroller returns a M for metric or I for imperial. \nTo my understanding, imperial measurement reportings aren't used.\n\n\nA rate limiter was required as to keep NR and the sensor from a spam-loop","x":298,"y":1030,"wires":[]}]```
  • @cranky ,
    do you have a git repository where we can download all the stuff?
  • Not yet, but that was my goal tomorrow.
    My GH account is https://github.com/jwcrawley
    It'll be obvious when I add in the repo 🙂 I'll also mention it here.
    Sincerely,
    Cranky
