Help work out correct MQTT message to activate relay
  • I'm trying to active a relay but not sure exactly what the full message should be.
    This is what I'm trying...
    MyMQTT/24/1/1/0/2
    In the serial monitor I can see "read" messages coming in but the relay is not doing anything.
    This is what I see in the serial monitor when I boot up the relay, maybe someone can help me make sense of it?
    send: 24-24-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
    send: 24-24-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 24-24-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
  • Can you please post your GW sketch ?
    Check this also.
    http://forum.mysensors.org/topic/2378/how-can-i-set-the-payload-for-mqtt-v1-6
    Another note regarding the above link. Some replies are talking about a bug which was fixed. But in all cases check the first replies concerning setting the message structure.
  • As far as I know I am just using the default MySensors relay sketch with 1 relay.
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
    #define RELAY_1  6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      gw.sendSketchInfo("Relay 1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
  • @ahmedadelhosni
    Ahhh by GW sketch I guess you mean gateway sketch? I set that up well over a year ago and I actually wouldn't even have a clue where the original sketch is... My temp/humidity sensors have been working perfectly for over a year now. So just diving back into the arduino stuff to see if I can get the relay going.
    I'm even using a different PC to compile and upload the sketches so I might not even have the original GW sketch....
  • @TommySharp Yeah I mean the gateway.
    You say your gateway is running for a year now, but now you want to use MQTT so you have to set this MQTT gateway. I am not familiar with MYsensor library 1.5 or previous versions. I am using the development branch ( https://github.com/mysensors/Arduino )
    It has a sketch for setting MQTT gateway and you can test sending a payload data using mosquitto as explained in my first link in the previous reply. Also there is a new sketch for relayactuator example.
    It works okay and I have tested it.
  • @ahmedadelhosni
    Yes my gateway is the MQTT gateway and it has been running for well over a year. It happily posts temp/humidity which my OpenHAB server subscribes to and reads in the sensor readings.
    I just need to work out now how to activate a relay 🙂
    @TommySharp
    Hi!
    According to the mqtt gateway sketch in 1.5.3, topic structure is:
    Topicprefix/node_id/child_id/v_type
    Mysensors payload is mqtt payload.
  • So when my relay sensor announces itself to the gateway below.... Does it announce the child ID anywhere so I can be sure I'm using the right one?
    The last line shows s=1, so child id is 1.
    Read this post for details on topic structure:
    http://forum.mysensors.org/topic/303/mqtt-broker-gateway/17
    Also read the text at the top of the mqtt gateway sketch for more info.
    I think you should test with this topic:
    prefix/24/1/V_LIGHT
    Replace prefix with your set topic prefix.
    You can set payload with the -m option if you're using mosquitto.
    Be aware though, that the mqtt broker gateway sketch will me removed in the next release, so if you want the best support I would think about changing to the mqtt client gateway. This is currently only available in the dev branch at github, but there is a sticky guide in the forum, on how to set it up.
  • Awesome! I'd much rather use a client gateway so might just hold off until the next release of MySensors and then use the MQTT Client Gateway.
  • 14
  • 20
