Problem with Ardunio Ethernet as gateway
  • Hi !
    Trying to make my first gateway to work with no success.
    I found out (by adding some Serial.println() statements) it fails in rf24.isPVariant().
    Output (shown by the serial monitor) from MySensors is "0;0;3;0;9;radio init fail"
    I am rather sure I have wired my NRF24L01+ wrong since the Arduino Ethernet board does not have the exact same pin markings as listen in MySenbors,org.
    (Ethernet is correctly setup since in my sketch I can ping the Arduino from my PC without problem)
    My setup : Arduino Ethernet
    Arduino IDE : 1.6.5
    OS : Windows 10 Prof.
    MySensors library version : 1.5.4
    NRF devices are clearly the Plus version, chip is marked as
    NRF M
    24L01+
    1452AB
    Wiring (based on info I found here:
    Arduino NRF24
    GND GND
    3.3V Vcc
    Digital pin 7 CE
    Digital pin 8 CSN/CS
    SCK SCK
    MOSI MOSI
    MISO MISO
    IRQ Not connected
    Changes in the EthernetGateway sketch :
    #define RADIO_CE_PIN 7 // radio chip enable
    #define RADIO_SPI_SS_PIN 8 // radio SPI serial select
    Changes in MyConfig.h :
    #define DEBUG (obviously... 🙂 )
    #define RF24_CE_PIN 7
    #define RF24_CS_PIN 8
    const uint8_t SOFT_SPI_MISO_PIN = 12;
    const uint8_t SOFT_SPI_MOSI_PIN = 11;
    const uint8_t SOFT_SPI_SCK_PIN = 13;
    Has anyone else been successful using the Arduino Ethernet as a MySensor gateway ? If so, what am I doing wrong here... ?
    Cheers & TIA !
    /T
  • @Tias
    Hi
    I am not sure
    But for CE you wrote 7 and in sketch it is 5?
    Try to change sketch to 7.
    Same about SPI, you wrote 8 and in sketch it is 4.
  • Hi !
    Sorry, I tried both version 5 & 4 and then 7 & 😎 so that's why I messed it up in my post.
    It is 7 & 8 (now corrected in my OP) based on the info for the Arduino Ethernet I linked to in tho OP.
    Cheers !
  • @Tias
    Can you please copy your sketch here
    Easier for everyone to help you, maybe it can be something with soft pins?
  • @Tias
    Hi, I'am using :
    in my application
    #define RADIO_CE_PIN 5 // radio chip enable
    #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
    in MyConfig.h
    #define SOFTSPI
    #ifdef SOFTSPI
    const uint8_t SOFT_SPI_MISO_PIN =   12;          //A2
    const uint8_t SOFT_SPI_MOSI_PIN = 11;            //A1
    const uint8_t SOFT_SPI_SCK_PIN =  13;            //A0
    the connection NRF24l01 with Uno, MISO->A2
    MOSI->A1
    SCK ->A0
    CE -> D5
    CS-> D6
  • @flopp
    No Problem, here's my EthernetGateway.ino and below MyConfig.h :
    EthernetGateway.ino :
    #include <MyConfig.h>
    #include <MyHw.h>
    #include <MyHwATMega328.h>
    #include <MyHwESP8266.h>
    #include <MyMessage.h>
    #include <MyParser.h>
    #include <MyParserSerial.h>
    #include <MySigning.h>
    #include <MySigningNone.h>
    #include <MyTransport.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <Version.h>
    #include <MyHw.h>
    #include <MyHw.h>
    #include <NewPing.h>
    #include <MyHw.h>
    #include <MyHw.h>
    * Version 1.0 - Henrik EKblad
    * COMPILING WIZNET (W5100) ETHERNET MODULE
    * > Edit MyConfig.h in (libraries\MySensors\) to enable softspi (remove // before "#define SOFTSPI").
    * COMPILING ENC28J60 ETHERNET MODULE
    * > Use Arduino IDE 1.5.7 (or later)
    * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
    * > Remove Ethernet.h include below and include UIPEthernet.h
    * > Remove DigitalIO include
    * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
    * VERA CONFIGURATION:
    * LED purposes:
    #define DEBUG 1
    #define NO_PORTB_PINCHANGES
    #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
    #include <stdarg.h>
    #include <PinChangeInt.h>
    #include "GatewayUtil.h"
    // Use this if you have attached a Ethernet ENC28J60 shields
    // #include <UIPEthernet.h>
    // Use this for WizNET W5100 module and Arduino Ethernet Shield
    #include <Ethernet.h>
    #define RADIO_ERROR_LED_PIN 7  // Error led pin
    #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
    //MyTransportRFM69 transport;
    //MySigningNone signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    #ifdef WITH_LEDS_BLINKING
    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    #define IP_PORT 5003        // The port you want to open
    IPAddress myIp (192, 168, 1, 89);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
    byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x45, 0x5F };  // DEAD BEEF FEED
    // a R/W server on the port
    EthernetServer server = EthernetServer(IP_PORT);
    // handle to open connection
    EthernetClient client = EthernetClient();
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    bool sentReady = false;
    void output(const char *fmt, ... )
      va_list args;
      va_start (args, fmt );
      va_end (args);
      Serial.print(serialBuffer);
      server.write(serialBuffer);
     Serial.begin(115200);//MT: Without this, I don't get any debug msgs on the serial port.
     Ethernet.begin(mac, myIp);
     // Add interrupt for inclusion button to pin
     PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
     // give the Ethernet interface a second to initialize
     delay(1000);
     server.begin();
     checkInclusionFinished();
     // if an incoming client connects, there will be
     // bytes available to read via the client object
     EthernetClient newclient = server.available();
     // if a new client connects make sure to dispose any previous existing sockets
     if (newclient)
         if (client != newclient)
          client.stop();
          client = newclient;
          output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
      if (client)
        if (!client.connected())
          client.stop();
        else if (client.available())
          // read the bytes incoming from the client
          char inChar = client.read();
          if (inputPos<MAX_RECEIVE_LENGTH-1)
            // if newline then command is complete
            if (inChar == '\n')
              Serial.println("Finished");
               // a command was issued by the client
               // we will now try to send it to the actuator
               inputString[inputPos] = 0;
               // echo the string to the serial port
               Serial.print(inputString);
               parseAndSend(gw, inputString);
               // clear the string:
               inputPos = 0;
              // add it to the inputString:
              inputString[inputPos] = inChar;
              inputPos++;
            inputPos = 0;
    MyConfig.h :
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    #define DEBUG
    // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
    #define ENABLED_SERIAL
    #define BAUD_RATE 115200
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    *  Information LEDs blinking
    // disabled in the gateway.
    //#define WITH_LEDS_BLINKING
    // off when blinking
    // The RX LED default pin
    #define DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #define DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #define DEFAULT_ERR_LED_PIN 4
    *  Message Signing Settings
    //#define MY_SIGNING_FEATURE
    #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
    #define MY_RANDOMSEED_PIN 6 // A7 - Pin used for random generation (do not connect anything to this)
    *  NRF24L01 Driver Defaults
    #define RF24_CHANNEL	   76
    #define SOFTSPI
    #ifdef SOFTSPI
    *  RFM69 Driver Defaults
  • @Tias
    Your Arduino is Mega?????
  • @anibaldiniz
    Nope, it's an Arduino Ethernet (there's a link to it in my OP above).
  • @Tias
    Right, I gave up and got an Arduino Nano to use as a Serial gateway instead.
    It's initializing ok and entering the loop() but presents other issues, however, that's for another thread.
    Cheers & thanks !
    /T
  • 24
