Air Quality Sensor
    @Heinz so bad I don't have a MQ135 running anymore to compare, here are the MH-Z14 curves I have near my desk.
    @bhavika said:
    IN MiCS 2614 , sensitivity factor is defined by "Rs at 100 ppb of O3 divided by Rs at 50 ppb of O3". From where you measured Rs at 100 ppb or 50 ppb.???
    this is just to tell you how much a double concentration scales up, here they just say it is somehow linear at ratio 2
  • @Heinz very nice work πŸ‘ (wie heisst du im FHEM Forum?)
    Does someone have the values a MQ-07 needs to perform properly? I rally don't know how to gather the right values from the description.... πŸ™‚
    Thank you
    @Rasenheizung if you base yourself on my template here https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino
    H2
    1.3 50
    0.8 100
    0.28 400
    0.16 1000
    0.05 4000
    y = 73.59123879 x-1.355617483
    Residual Sum of Squares: rss = 87393.44418
    H2Curve[3] = {73.5912, -1.355617};
    CO
    1.6 50
    1 100
    0.39 400
    0.21 1000
    0.09 4000
    y = 99.27731641 x-1.513643469
    Residual Sum of Squares: rss = 43168.87424
    COCurve[3] = {99.27731, -1.51364};
    CO is a dangerous gas, the MQ7 is very sensitive to many things and no calibration too... for a serious work please think about using the MICS-6814 that is calibrated, includes 3 gases out of the box, and is very low consumption (can run on battery !)
    https://github.com/empierre/arduino/blob/master/AirQuality-CO-NO2-NH3.ino
  • What is the pre-heating time for TGS2442???
    from datasheet: "the sensor’s resistance reaches to 90% of its final value in less than one minute"
  • So what is the conditioning period for testing in it??? It is two days.. What does it mean??
    on this kind maybe to have it powered for a full two days to burn out the production "dusts" that may remain in.
    those sensors are not good science, see the correlation of gases they are reported for in the datasheet
  • I have a question for the MQ135. Do not always be above 500 ppm, the measured values? I also get values of 0. I suspect that it is due to the conversion. The values vary greatly. Is that normal? I get the values with an ordinary power supply. mq135 werte.PNG
    Looks strange, could you supply your code?
    Btw the sensor draws a lot of current, the power supply should be able to deliver 1A. Did you burn in the sensor for 12-24 hours?
  • I have used the code from epiere. Baking I have not done. I use different power supplies (USB, Samsung and a large controllable power supply). I sometimes feel that contacts do not function properly. But the sensor draws but only about 100 mA = 0.1 A? Then it seems to be on branding. I have three new sensors. Mostly we read that it is only an attempt here is to measure the CO2 content. When I check the values with a measuring instrument with which agree the details here https://olimex.wordpress.com/2015/05/26/experimenting-with-gas-sensors-and-arduino/ Branding should work outdoors? Can you show me a chart or values?
    I used this library:
    https://github.com/GeorgK/MQ135
    Together with this description:
    https://hackaday.io/project/3475-sniffing-trinket/log/12363-mq135-arduino-library
    Simple to use and very good explanations.
  • I've read about. It sounds interesting.
    I stand a little hard with the development. Is there a skit for MQ135.h and MYSENSORS?
    I will test this afternoon.
    Hi @paqor,
    I wrote a little sketch which you could use as a start, it uses the MQ135 library.
    I also used a timer library, but this could be replaced by a simple sleep, too.
    RZERO should be changed when calibrating the sensor, this can be done at compile-time or during runtime by sending the value to the sensor via the gateway.
    Unfortunately I could not test the sketch yet, but it should help you getting started.
    If you have a second sensor which provides humidity and temperature then you can also get the corrected ppm from the library,...
    good luck!
    MQ135 MySensor
    A0      white
    D0      black
    GND     brown
    5V      red
    #include <MQ135.h>
    #include "Timer.h"
    Timer timer;
    // 30 seconds
    #define TEMP_UPDATE_INTERVAL 30000
    // MQ135
    #define CHILD_ID_CO2 0
    #define CHILD_ID_R0 1
    #define CO2_SENSOR_ANALOG_PIN 0
    /// Calibration resistance at atmospheric CO2 level
    #define RZERO 300.0
    #define EEPROM_R0 0
    MQ135 gasSensor = MQ135(CO2_SENSOR_ANALOG_PIN, RZERO);
    int lastC02;
    float lastR0;
    // MySensor
    MyMessage msgCO2(CHILD_ID_CO2, V_VAR1);
    MyMessage msgR0(CHILD_ID_R0, V_VAR1);
        gw.sendSketchInfo("MQ135 Sensor", "1.0");
        gw.present(CHILD_ID_CO2, S_AIR_QUALITY);
        gw.present(CHILD_ID_R0, S_CUSTOM);
        uint8_t R02 = gw.loadState(EEPROM_R0);
        // get R0 from EEPROM
        float R0 = R02 * 2;
    	// do a plausibility check
        if (R0 > 1.0 && R0 < 400.0)
            Serial.print(F("Setting R0 from EEPROM: "));
            Serial.print(F("Setting default R0: "));
            R0 = RZERO;
        Serial.print(R0);
        Serial.println(F(""));
        gasSensor.setR0(R0);
        timer.every(TEMP_UPDATE_INTERVAL, timerHandler);
    bool MQ135Changed()
        bool changed = false;
        lastR0 = gasSensor.getRZero();
        Serial.print(F("R0: "));
        Serial.println(lastR0);
            float ppm = gasSensor.getPPM();
            Serial.print(F("CO2 ppm: "));
            Serial.print(ppm);
            int roundedPpm = (int)ppm;
            Serial.print(F(" --> "));
            Serial.println(roundedPpm);
            if (roundedPpm != lastC02)
                lastC02 = roundedPpm;
                changed = true;
        return changed;
    void timerHandler()
        bool airQualityChanged = MQ135Changed();
        if (airQualityChanged)
            gw.send(msgCO2.set(lastC02));
            gw.send(msgR0.set(lastR0, 2));
        timer.update();
    // Gets the R0 value from the gw passes ot to the lib and stores it into the EEPROM.
    void incomingMessage(const MyMessage& message)
        Serial.println(F("Incoming Message:"));
        if (message.isAck())
        uint8_t sensor = message.sensor;
        if (sensor == CHILD_ID_R0)
            float R0 = message.getFloat();
            Serial.print(F("Incoming R0: "));
            Serial.print(R0);
            gw.saveState(EEPROM_R0, (uint8_t)(R0/2));
            gw.send(msgR0.set(R0, 2));
  • I have compiled from various sources themselves something. The result is https://gleisnetze.de/2015/12/25/das-erste-kleine-programm/ described herein. The most plausible values I received with the MQ135.h library. For that I have then added the transfer after MySensors / FHEM.
  • Hello
    In MiCS 2614 or in any gas sensor. what should be the value of R0... Because in datasheet they mentioned that value is measured in ambient condition. Any default value for that??
    @bhavika said:
    Hello
    The datasheed propose the "clean air calibration": "Sensing resistance in air R0 is measured under controlled ambient conditions, i.e. synthetic air at 23 Β±5Β°C and 50 Β± 10% RH. Sampling test."
    so you should go outside and mesure the defautl R0 value in your environment.
    MQ-135 with 10k results in a R0 of around 360 in my environment. So you could start experimenting with values around 300-500. I had to use a voltage regulator to get reliable values from the sensor.
    a little update on the MICS-6814:
    NO2: sensible
    CO: flat
    NH3 flat
    For the HCHO:
    sorry for the flat part, some arduino issues at this time
    Welcome @betthorn, great to have you here.
    I have had some questions about converting from mg/m3 to ppm gases, here are the weight values and a proposed method:
    NH3 17.03 g/mol
    CO2 44.01
    CO 28.01
    H2S 34.08
    NO2 46.01
    NO 30.01
    O3 48.00
    C6H6 78.11
    C7H8 92.14
    you have:
    NO2 50 ΞΌg/m3 gives 26,5868821 ppm
    O3 27 ΞΌg/m3 = 0.027 mg/m3 -> (8,31441298,15)/(48101,325)*27=13,7617025 ppm
    correct me if I'm wrong
    2016 is where IoT for gas sensors are moving to more maturity, Cooking Hacks / Libellium proposed so far Fibaro sensors, but are now proposing more pricey one that are calibrated.
    See https://www.cooking-hacks.com/shop/sensors/gas
    CO2 with MH-Z14
    NO2 MICS-6814
    HCHO sensor
  • In MQ135 sensor's datasheet , which line on the curve is used to find out the concentration of benzene?
    MQ135 is sensitive to particle size, benzene is one of these. I rememer someone who used the chinese datasheet and found a chinese to translate it.
  • @epierre I am testing a stripped-down version of your code from your AirQuality-MQ135.ino. I stripped it to make it run just stand-alone.
    What I don't understand is how to do the calibration. When I run it in outside environment (with 10k resistor), I get these values:
    valr 223
    Vrl / Rs / ratio:13387 / 20875.00 / 0.00
    What would be the next step for calibration?
    @supersjimmie replace MQ135_DEFAULTRO by your value 20875 in the sketch
  • @epierre Thanks, I thought it would be something like that, but that didn't work.
    I then got
    valr 242
    Vrl / Rs / ratio:5464 / 8520.00 / 0.00
    Nothing like around 400ppm.
    yes for the code must be updated, the value is the CO2 (or something else) detected above the 399 in atmosphere
      gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
  • Thanks, but when calibrating something strange happens when I put the module outside:
    valr 270
    Vrl   / Rs       / ratio  / ppm
    61355 / 95673.00 / 0.00 / 399.00
    valr 265
    62928 / 98126.00 / 0.00 / 399.00
    valr 260
    64561 / 100673.00 / 0.00 / 399.00
    valr 256
    378 / 589.00 / 0.00 / 399.00
    valr 252
    1773 / 2764.00 / 0.00 / 399.00
    As you can see, the valr decreases slowly, but suddenly Vlr and Rs jump over.
    Vlr is the value of 'val', which is: uint16_t val = ((float)22000*(1023-valr)/valr);
    uint16_t is 16bit, so max 65535. It looks like my environment needs more than that?
    (in fact, your code defines the defaultro as 68550, which is also too much for a uint16?)
    yes and this is why I did rewrite it to https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino but did not updated this one...
  • @epierre I striped-down that AirQuality-Multiple_Gas_Sensor1_4.ino to use only MQ135.
    When used inside, the analogRead is 473, so a reasonble value.
    But the MQCalibration function returns 0. Which means the MQResistanceCalculation also returns 0.
    MQResistenceCalculation only does one calc:
    return (long)((long)(1024 * 1000 * (long)rl_value)/raw_adc-(long)rl_value);
    rl_value = float RL4 = 0.990
    raw_adc = 473 (measured as said above)
    (1024 * 1000 * 0.990) / 473 - 0.990 = 2142.266
    I checked that raw_adc is filled with the correct value (to be sure it is not lost somewhere).
    What looks to fix this, I changed everything to float . So:
    return (float)((float)(1024 .* 1000. * (float)rl_value)/raw_adc-(float)rl_value);
    Which can be simplyfied as:
    return ((1024 * 1000*rl_value)/raw_adc-rl_value);
    I went to float, because the function is created as float MQResistenceCalculation.
    This now gives some ppm values that are within a reasonable range (about 2000 here).
    Now I have to figure out how to do calibration on this method again...
    looks like I have to rework something... but not in the todo list right now... Imperihome is now back on top, and Particle on lipo/solar also...
    I don't know how to calculate 3 numbers of LPGCurve[]. Can you explain clearly for me? Thank you so much !!!
    @tantt2810 as explained above, if the datasheet has a logarithmic scale, you can use the power regression to approximate the curve. One tool for example to do this calculus:http://www.xuru.org/rt/powr.asp
    for a sensor discussed above I read this on the datasheet:
    H2
    1.3 50
    0.8 100
    0.28 400
    0.16 1000
    0.05 4000
    The xuru website gives me this:
    and thus I have::
  • @epierre Thank you so much !!!
    Have a nice day =)) !!!
  • @epierre
    hi
    i am new here.
    sorry i am a little confused by with these new formulate.
    is it the key for module?
    I'm don't understand the recipe below. Why RL_Value(Load Resistance)(1023-raw_adc)/raw_adc)? Can you explain for me?
    ***************** MQResistanceCalculation ****************************************
    Input: raw_adc - raw value read from adc, which represents the voltage
    Output: the calculated sensor resistance
    Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
    across the load resistor and its resistance, the resistance of the sensor
    could be derived.
    float MQ2::MQResistanceCalculation(int raw_adc)
    return ( ((float)RL_VALUE
    (1023-raw_adc)/raw_adc));
    if you have a module the datasheet gives you the values, yes. Remember this is their """""generic"""" calibration, in fact they all copy the other so don't expect your MQ** would follow this by the letter...
    could be derived.
    RL_VALUE
    in fact it is above described, you have a voltage, you want a resistance.
    https://learn.sparkfun.com/tutorials/voltage-dividers
    datasheet needs a value which is the Rs/Ro (called here RL) where
    Ro: sensor resistance at 100ppm of NH3 in the clean air.
    Rs:sensor resistance at various concentrations of gases
    here the formula is a simplification of this:
    float Vrl = val * ( 5.00 / 1024.0 ); // V
    float Rs = 20000 * ( 5.00 - Vrl) / Vrl ; // Ohm
    int ratio = Rs/Ro;
    ppm = 37143 * pow (ratio, -3.178);
  • @epierre Hi you,
    I think the Rs/Ro is not RL. In the datasheet RL=5kOhm. As I know it is a resistance on board Arduino, and we set it 5kOhm. Is it right? I also don't know why we set it equal 5kOhm. =))
    And why 20000 is in "float Rs = 20000 * ( 5.00 - Vrl) / Vrl ; // Ohm" ?
    Please help me clearly. Thank you so much !!!
    I have read the sensitivity characteristics curve in datasheet of MQ135 and I don't know AL R, 3/4, 1/4* and +- mean? Can you help me, please !!!
    NH4 represent for NH3, doesn't it ?
  • Hi everyone,
    I have an CO2 MG811 sensor. I don't know where tcm pin connect with ?
    Please help me. Thank you so much !!!!
    0_1457101257425_F08406-CO2-Carbon-Dioxide-Sensor-Module-font-b-MG811-b-font-Voltage-0-2V-Voltage-Output.jpg
  • Hello, I'm working with an MQ-136 sensor, and am interested in measuring H2S and/or SO2 concentrations. I've got a simple sketch written which gives me a fairly consistent value on the serial monitor, but I've tried to run the multiple gas sensor sketch both complete and I also tried picking apart the sketch just to include MQ-136 related variables and algorithms, but I can't get it to work. It's showing too many errors to list here. Does anyone have simple conversions from the serial outputs to usable values for various gases that this sensor can measure?
  • hello, how i read co2 ppm with my mq135?
    helpme please
    @tantt2810 said:
    Hi everyone,
    this is an analogic sensor, so VCC/Gnd to power it, and readings on analogic Aout
    @tantt2810 sorry for not being more responsive, I left MQ/TGS behind me but I've not kept all my notes on mesuring this and that, that would require me to search for it again. But I appreciate if you can spot me some float/type error conversion in sketches !
    I was a bit disappointed when a project I contributed to on Kickstarter showed the inside of their boxes, I wonder how they will manage to satisfy customers with calibration... or their home made index as netatmo did
  • Used the air quality script for MQ7 but throwed out all the conversions and calibrations. Just reading the plain input from the analogue pin.
    I targeted this as a smoke detector but it seems this sensor highly depends on the humidity of the surrounding air. Are there any existing formulas to correct for the humidity of the surounding air?
    And on one sensor i have some irratical data as shown below (blue). I wonder if it's a power supply (black and green is DHT) or a broken sensor?
    @moskovskiy82 well looks like a strange sensor... try averaging several samples/// always remember to have it running several days before measuring for there are chemical left from china factories...
  • Hey all,
    I've got a question regarding the calibration function in https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino :
    $ grep MQCalibr *
    AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro0 = MQCalibration(MQ2_SENSOR,10,RL0,SmokeCurve);
    AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro1 = MQCalibration(MQ6_SENSOR,10,RL1,LPGCurve);
    AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro2 = MQCalibration(MQ131_SENSOR,10,RL2,O3Curve);
    AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro3 = MQCalibration(TGS2600_SENSOR,10,RL3,C2H5OH_terCurve);
    AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro4 = MQCalibration(MQ135_SENSOR,10,RL4,CO_secCurve);
    AirQuality-Multiple_Gas_Sensor1_4.ino:  Ro6 = MQCalibration(TGS2602_SENSOR,1,RL6,C7H8Curve);
    AirQuality-Multiple_Gas_Sensor1_4.ino:float MQCalibration(int mq_pin, double ppm, double rl_value,float *pcurve )
    Th function MQCalibration should calibrate the sensor in clean air, the calibration function uses the PPM concentration of the gas in a clean air environment.
    You already use the appropriate value for i.e. CO2 (around 399 PPM) in the MQ135 sketch - but why are you using those obscure values in the calibration (1, 10) here?
    Thanks in advance!
    Well, I didn't know the concentration in clean air so I had to put in a value even random... I took the hypothesis there are very few in the air so low value.
  • @epierre
    Thank you. Your mean is Vcc->5V, GND->GND, Dout->Digital pin, Aout->Analog pin. Is it right?
    But I don't know the tcm pin connect with ? I have read datasheet but I don't find any info about tcm pin. Please help me. Thank you so much !!!
  • @epierre
    Readings of my MQ135 are going up and down like a yo-yo. Not sure how to read them really?
    What do you think?
  • I am confused with MiCS 4514 sensor. What I had done is :
    using MiCS quick start evaluation board, measured ADC value
    calculated Vout and from that calculated R0.
    Rs/R0 concentration gives me high value, which is not possible, My data is as follows
    clean air file is used for the purpose of R0 value
    https://drive.google.com/file/d/0B8sF8a6FHoseWjhWOHRoYzIxakk/view?usp=sharing
    and Polluted file is used to calculate the actual pollution
    https://drive.google.com/file/d/0B8sF8a6FHoseR1BnclhCUHdibEU/view?usp=sharing
    I am confused. Please help me
    @tantt2810 said:
    @epierre
    do not use the digital pin !!! it only reacts with the potentiometer in on/off mode, so useless... you need to power the device with Vcc/Gnd, and read the output with Aout (A stands for analog). The last one forget it.
    @alexsh1 is that raw ADC output or with a calculation ? normaly this should go up or down but not in sucha drastic way
  • @epierre
    This is a value gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ))) reported to Domoticz.
    It does not make any sense to me at all.
  • @epierre
    Thanks you so much !!! Good job, Good boy =)).
    @alexsh1 said:
    @epierre
    same for mle, sometime it is good to have two piece to compare their behavior... I have 3 o them ...
  • @epierre do you think it is a faulty sensor though?
    Can I use pinMode(digitalpin, OUTPUT) to turn off sensor? Or Is there any way to wirte a function that turn off sensor?
    I want to remote it on web to turn on or off it.
  • For those who are trying to use an MQ135 module from e-bay or other sellers, on a small pcb with a chip, LED and potmeter:
    It took me a while until I figured out that the little chip has a very big influence on the value that you read on the A-out pin.
    Only after removing the connection between the A-out pin and the little chip, I got normal measurements.
    I also replaced the small resistor marked "102" with a 10k resistor, to make measurements more compatible with code that uses a 10k pull down resistor. But that was already a known issue, found on many other places.
    well no, powering is through Vcc/GND, so you whould use a switch on this. Digital pins do not gives enough power for such sensors.
    coud be, hard to know without possibility to compare to another one.
  • @epierre
    This is what I discovered. When nobody is around the sensor 'settles' on a particular value. However, when there is anyone around in the room, the sensor reading goes up and down - see the snapshot attached. Any idea what the problem may be?
    @alexsh1 hard to say, could be something moving inside if someone makes vibration around and thus this strange reaction... the down curve at the end is correct, the in between not
    Can you check the reception level?
    I had same behaviour with an old temperature/humidity module; need to move it to another place in the room, and works perfectly now πŸ™‚
    temp/hum are "less" sensitive on environment, here the sensors heats up to 40-60Β° (or more) so temp/hum is not the most impacting (I can be wrong anyway πŸ˜‰
  • @epierre I wonder if you looked at this sensor Figaro TGS8100:
    http://www.figarosensor.com/products/entry/tgs8100.html
    Looks like it is perfect for a low-powered platform.
    as a replacement for MQ in low power yes could be... the bad part is how to get one ?
    How about http://www.soselectronic.com/?str=371&artnum=170939&name=figaro-tgs8100 ?
  • Hi, It all make sense, I am just confused that in your code once your multiply and once you divide...
    case CO:
    if(ratio1 < 0.01) ratio1 = 0.01;
    if(ratio1 > 3) ratio1 = 3;
    //c = pow(10, 0.6) / pow(ratio1, 1.2);
    ** c = pow(ratio1, -1.179)4.385; //mod by jack*
    case NO2:
    if(ratio2 < 0.07) ratio2 = 0.07;
    if(ratio2 > 40) ratio2 = 40;
    //c = ratio2 / pow(10, 0.8);
    ** c = pow(ratio2, 1.007)/6.855; //mod by jack**
    SO, what is the actual formula?
    Vir
    @epierre said:
    I'm now testing the MICS-6814 (3 sensors in one) given for :
    Carbon monoxide CO 1 -1000ppm
    **Nitrogen dioxide NO2 0.05 –10ppm **
    Ethanol C2H5OH 10 –500ppm
    Hydrogen H2 1 –1000ppm
    Ammonia NH3 1 –500ppm
    Methane CH4 >1000ppm
    Propane C3H8 >1000ppm
    Iso-butane C4H10 >1000ppm
    Datasheet maionly speaks on CO, NO2 and NH3:
    http://www.seeedstudio.com/wiki/images/1/10/MiCS-6814_Datasheet.pdf
    Here is are scripts:
    http://www.seeedstudio.com/wiki/Grove_-_Multichannel_Gas_Sensor
    Some readings:
    The concentration of NH3 is 0.99 ppm
    The concentration of CO is 1.20 ppm
    The concentration of NO2 is 0.15 ppm
    The concentration of C3H8 is 1000.04 ppm
    The concentration of C4H10 is 999.98 ppm
    The concentration of CH4 is 2991.14 ppm
    The concentration of H2 is 1.09 ppm
    The concentration of C2H5OH is 1.40 ppm
    I guess I'll make a script soon...
  • What does 37143 represents, Rs? and -3.178 is a second value from your regression method, but what about the first value?
    Can you elaborate on ppm line, please
    Vir
    int ratio = Rs/Ro;
    I am confused by the formula you are using, could you please explain?
    Pollution NO2 = (POWER((RS/R0)*(1/POWER(10,0.8068)),(1/1.01)))
    Pollution CO = POWER((RS/R0)*(1/POWER(10 , 0.5476)),(1/-0.8497)))
    is the actual formula like this?:
    pollution = POWER((ratio *(1/POWER(10, curve[0])),(1/[curve[1])))
    This is different than any other formulas discussed in this thread...
    Vir
  • so does 37164 represents the scaling factor and -3.178 the exponent?
    Vir
    Vir
    int ratio = Rs/Ro;
  • @epierre I have the problem with the dust sketch (shinyei ppd42ns). The following code does not work in MySensors 1.5
    gw.send(msgPM10.set("ppm"));
    gw.send(msgPM25.set("ppm"));
    2016-04-24 14:44:19.438 Error: MySensors: Unknown/Invalid sensor type (43)
    So far both PM10 and PM25 are showing zero. However, if I upload the following code, it works fine (one channel though):
    // Watch video here: https://www.youtube.com/watch?v=a8r4CeQopfY
     Connection:
     JST Pin 1 (Black Wire)  => Arduino GND
     JST Pin 3 (Red wire)    => Arduino 5VDC
     JST Pin 4 (Yellow wire) => Arduino Digital Pin 8
     Green Led connected to Arduino D7
     Yellow Led connected to Arduino D6
     Red Led connected to Arduino D5
    Dust Sensor possible application:
    - Applications of customer
    - Air quality sensor
    - Dustlessness workshop
    - Cigarette detector
    Sensor is to create Digital (Lo Pulse) output to Particulate Matters (PM). Lo Pulse Occupancy time (LPO time) is in proportion
    to PM concentration. The output is for PM whose size is around 1 micro meter or larger. We can use the sensor to detect the dust in clean room.
    Minimum detect particle: 1um
    http://www.seeedstudio.com/wiki/Grove_-_Dust_Sensor
     Grove - Dust Sensor Demo v1.0
     Interface to Shinyei Model PPD42NS Particle Sensor
     Program by Christopher Nafis
     Written April 2012
     http://www.seeedstudio.com/depot/grove-dust-sensor-p-1050.html
     http://www.sca-shinyei.com/pdf/PPD42NS.pdf
    int pin = 8;
    unsigned long duration;
    unsigned long starttime;
    unsigned long sampletime_ms = 1000;//sampe 1s ;
    unsigned long lowpulseoccupancy = 0;
    float ratio = 0;
    float concentration = 0;
    int gLed = 7;
    int yLed = 6;
    int rLed = 5;
      Serial.begin(9600);
      pinMode(8,INPUT);
      pinMode(gLed,OUTPUT);
      pinMode(yLed,OUTPUT);
      pinMode(rLed,OUTPUT);
      starttime = millis();//get the current time;
      duration = pulseIn(pin, LOW);
      lowpulseoccupancy = lowpulseoccupancy+duration;
      if ((millis()-starttime) > sampletime_ms)//if the sampel time == 30s
        ratio = lowpulseoccupancy/(sampletime_ms*10.0);  // Integer percentage 0=>100
        concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
        Serial.print("concentration = ");
        Serial.print(concentration);
        Serial.print(" pcs/0.01cf  -  ");
        if (concentration < 1.0) {
         Serial.println("It's a smokeless and dustless environment");
         digitalWrite(gLed, HIGH);
         digitalWrite(yLed, LOW);
         digitalWrite(rLed, LOW);
        if (concentration > 1.0 && concentration < 20000) {
         Serial.println("It's probably only you blowing air to the sensor :)");
        if (concentration > 20000 && concentration < 315000) {
         Serial.println("Smokes from matches detected!");
         digitalWrite(gLed, LOW);
         digitalWrite(yLed, HIGH);
          if (concentration > 315000) {
         Serial.println("Smokes from cigarettes detected! Or It might be a huge fire! Beware!");
         digitalWrite(rLed, HIGH);
  • @epierre hi, could remove some doubts regarding the mq131 sensor?
    thanks,
    Anne
    @alexsh1 said:
    (shinyei ppd42ns)
    I corrected the following sketch which had bad yg/m3 to ppm conversion thanks to LouiS22 from Domoticz forum remark (type conversion errors leading to 0 values).
    https://github.com/empierre/arduino/blob/master/DustSensor_SamYoung_DSM501.ino
    I guess I'll have to do the same here (but I lack time...):
    DustSensor_Shinyei_PPD42NS.ino
  • @epierre Thanks - I'll have another go at Shinyei PPD42NS sketch once I have time. Ideally, I'd like to combine it with MH-Z14A sketch.
    @alexsh1 which is a good idea, also a temp/him is quite usefull though I didn't added the impact in the formulas so far.
  • @epierre I have combined the two sketches - works just fine, but need to find a spare temp sensor.The hardware setup looks messy so adding an extra i2c sensor will complicate it even more. I'll come back with the combined three-in-one sketch shortly.
    BTW, this
    still throws the following error. What version MySensors are you using?
  • @epierre I started looking at the formula you have used in ppmv calculation. Why do you need ppmv? All values in EPA or Europe are in ΞΌg/m3.
    The ppmv equation is:
    ppmv = mg/m^3 * (0.08205*T)/M
    T = atmospheric temperature in kelvins = 273.15 + Β°C
    M = molecular weight of the air pollutant = 28.97
    (http://www.engineeringtoolbox.com/molecular-mass-air-d_679.html - this is a good link)
    0.08205 = Universal Gas Law constant in atmΒ·l/(molΒ·K)
    Your code for this equation is:
    ppmv=(float)(((concentrationPM25*0.0283168)/100) * ((0.08205*temp)/0.01))/1000;
    Now, I think it should be as follows:
    1. temp = Β°C + 273.15
    int temp=273.15 + 22;
    22C - is a typical temp inside though the intention is to use a sensor
    1. The amended ppmv equation is going to be:
    ppmv=(((concentrationPM25*0.0283168)/100) * ((0.08205*temp)/28.97))/1000;
    I have not changed 0.0283168 /100 - not sure that this is. And the whole thing is divided by 1000? why?
    IMPORTANT UPDATE:
    I have just received the following result:
    PM10: 7373
    send: 11-11-0-0 s=0,c=1,t=37,pt=7,l=5,sg=0,st=ok:1.744
    If I use the following web-site http://www.herramientasingenieria.com/onlinecalc/ppm-mg_m3.php and the result is
    mg/m3 = 7373 * 0.283168/100 = 2.08 mg/m3
    The molecular weight is 28.97 for dry air
    2.08 mg/m3 is equivalent to 1.74ppm for a gas with molecular weight=28.97 Pressure=1013.25, Temperature=22C
    Success!
    Now I have found a spare BMP280 (temp and pressure sensor) which I can use here.
    Additionally, I need to use 24-h and 1 year averages - https://www3.epa.gov/airquality/particlepollution/2012/decfsstandards.pdf
    Stay tuned!
    because domoticz only knows ppm... and many AIQ like use only that except for particles.
    not for me πŸ˜‰
      ppmv=(((concentrationPM250.0283168)/100) * ((0.08205temp)/28.97))/1000;
    was a volume conversion
    Success!
    success for the mysensors value ?
    Domoticz doesn't recognize this command... I use 1.5.x but I have my own gateway to domoticz
  • @epierre Yes, all works fine now. I modified the combined sketch and here is the final result.
  • Which one to use for detection of fire smoke? Currently have got several MQ-7 but they don't seem so good at it
    as discussed just above, a particle sensor could be good for smoke is a particle concentration, coupled with heat this would be a good indicator
  • What about mq2 or mq135? Any experience? As a gas sensor will be more suitable detecting early fire
    please see what it does, this is not a gas sensor this only detect particle size whatever the gas...
  • @epierre
    It still detects concentration. Both state CO detection. So in case of fire won't they detect the increase in concentration much faster that the particle sensor like Sharp’s GP2Y1010AU0F or alternative?
  • @moskovskiy82 For a fire smoke, you can use pretty much any gas or particle sensor - there are a quite few gases formed during the burning process. MQ2 is highly sensitivity and has a fast response time. I can recommend it for a fire detection usage. However, I have been disappointed in MQ* sensors in general - there are not accurate, require 24h heat-up time, consume a lot of power etc. The only advantage is the price.
    To detect fire to can use a flame sensor - http://www.instructables.com/id/Flame-detection-using-Arduino-and-flame-sensor/
  • Can someone tell me how to read this line?
    float mq135_ro = 10000.0;    // this has to be tuned 10K Ohm
    Do I have to messure the sensor and adjust the variable or do I have to tune the resistance? If I have to do the first thing, when do I have to messure it? In warm state and clean air with a multimeter?
  • @epierre Did you check out the airbeam, which is based on a more expensive sensor Shinyei PPD60PV?
    http://www.takingspace.org/airbeam-technical-specifications-operation-performance/
    They made a step-by-step manual about building the same on Shinyei PPD42NS. I took their code and stripped a few parts and this is what I am left with:
    #include  <SoftwareSerial.h>
    #include  <FlexiTimer2.h>
    int pin = 3;
    volatile  double  rawParticalCount;
    volatile  double  totalParticles  = 0;
    volatile  double  particleCountToDisplay  = 0;
    volatile  double  ratio = 0;
    volatile  uint16_t  timeCounter = 0;
    #define         numberOfPeaksRecording                            5
    volatile        uint32_t        previousPeaks[numberOfPeaksRecording];
    volatile        uint32_t        sumOfPreviousPeaks          = 0;
    volatile        uint32_t        instantGoal                         = 0;
    volatile        int32_t         delta                                     = 0;
    volatile        uint32_t        slowMovingAverage             = 0;
    volatile  boolean readyToSendData = false;
    void  setup() {
        pinMode(pin,INPUT);
        FlexiTimer2::set(1,1.0/10000,readPin);
        FlexiTimer2::start();
    void  loop()  {
        if(readyToSendData){
                    Serial.print(rawParticalCount,  DEC);
                    Serial.print("  Raw Particle  Count (0-10000) ");
                    Serial.print(ratio, DEC);
                    Serial.print("  Ratio (0-100%)  ");
                    Serial.print(particleCountToDisplay,  DEC);
                    Serial.print("  Particle  Count");
                    Serial.println("");
    void  readPin(){
        if(digitalRead(pin) ==  LOW){
            rawParticalCount++;
        timeCounter++;
        if  (timeCounter  ==  10000)
            timeCounter=0;
            //Changes are made  here  based on  Chris Nafis's code: http://www.howmuchsnow.com/arduino/airquality/grovedust/
            ratio = rawParticalCount/100.0;
            //Convert to  percentage, the shinyei reads 10milliseconds  to  90milliseconds  duration  for particles.  Basing on 10milliseconds, smallest  particle  assumingly  from  specification sheet.
            //FlexiTimer2,  reads 10,000  readings  per second, which would be  1 reading per 100 microseconds. 100 readings  would be  10  milliseconds. Since Shinyei runs  at minimal 10  millisecond range.  I divided 10,000  readings  by  100 to  get 100.
            //Good  example would be  rawPArticalCount  is  5000  half  of  the 10,000  readings were  active. 5000/100  would be  50  which translate to  50% low pulse occupancy.
            totalParticles  = (1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62);
            rawParticalCount  = 0;
                    //  shift counters  over, code  adapted from  template  provided  by  Mike  Taylor  and Joshua  Schapiro  from  Carnegie  Mellon  University's  CREATE  Lab
                    for (uint8_t  i = 0;  i < (numberOfPeaksRecording-1); i++)  {
                            previousPeaks[i]  = previousPeaks[i+1];
                    previousPeaks[numberOfPeaksRecording  - 1]  = totalParticles;
                    for (uint8_t  i = 0;  i < numberOfPeaksRecording; i++)  {
                            sumOfPreviousPeaks  +=  previousPeaks[i];
                    instantGoal = 2*sumOfPreviousPeaks;
                    delta = instantGoal - slowMovingAverage;
                    if  (delta  < -5000){
                            slowMovingAverage = slowMovingAverage - 250;
                    } else  if  (delta  < -2500){
                            slowMovingAverage = slowMovingAverage - 120;
                    } else  if(delta  < -1200){
                            slowMovingAverage = slowMovingAverage - 60;
                    } else  if(delta  < -500){
                            slowMovingAverage = slowMovingAverage - 25;
                    } else  if(delta  < -5){
                            slowMovingAverage = slowMovingAverage - 5;
                    } else  if(delta  < -1){
                            slowMovingAverage = slowMovingAverage - 1;
                    } else  if(delta  > 5000) {
                            slowMovingAverage = slowMovingAverage + 500;
                    } else  if(delta  > 2500){
                            slowMovingAverage = slowMovingAverage + 250;
                    } else  if(delta  > 1200){
                            slowMovingAverage = slowMovingAverage + 120;
                    } else  if(delta  > 500){
                            slowMovingAverage = slowMovingAverage + 50;
                    } else  if(delta  > 5){
                            slowMovingAverage = slowMovingAverage + 5;
                    } else  if(delta  > 1){
                            slowMovingAverage = slowMovingAverage + 1;
                    particleCountToDisplay  = slowMovingAverage;
            readyToSendData = true;
    I have not adopted it for MySensors yet.
    I like moving average they use, but the values do not make sense to me:
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  53470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 27.0000000000  Ratio (0-100%)  53970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  54470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 21.6200008392  Ratio (0-100%)  54970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  55470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 24.2800006866  Ratio (0-100%)  55970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  56470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 24.1200008392  Ratio (0-100%)  56970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  57470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 22.3199996948  Ratio (0-100%)  57970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  58470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 20.3600006103  Ratio (0-100%)  58970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  59470.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 17.6299991607  Ratio (0-100%)  59970.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  60220.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 19.0499992370  Ratio (0-100%)  60720.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  60715.0000000000  Particle  Count
    0.0000000000  Raw Particle  Count (0-10000) 20.6599998474  Ratio (0-100%)  61215.0000000000  Particle  Count
    @alexsh1 the PPDN42 is for 1 micron and 2.5 micron , this one is for 0.5 micron
    airbeam has standard code: https://github.com/HabitatMap/AirCastingAndroidClient/blob/master/arduino/aircasting/aircasting_shinyeiPPD42NS.ino
    or I've not seen ?
  • @epierre this is not the air beam code. They introduced "do it yourself" consept similar to the airbeam but with a different sensor (shinyei ppd42ns)
  • Hey guys, I am struggeling to get the MQ135 to work. Is there a step by step howto? Or can someone answer my question from 3 days ago?
    I would appreciate it very much.
  • @rollercontainer I followed David Gironi method to calibrate - it is described as follows:
    Before you can use the sensor, it has to be calibrated. For this, connect the sensor to your circuit and leave it powered on for 12-24 h to burn it in. Then put it into outside air, preferably at 20Β°C/35% rel. hum. (humidity is not so crucial). Read out the calibration value as such
    float rzero = gasSensor.getRZero();
    Wait until the value has somewhat settled (30min-1h). Remember, this is an ADC measurement so you might not want to wait some time between reading the sensor and also do some averaging. Once you have determined your RZero, put it into the MQ135.h. Note: Different sensors will likely have different RZero!
    #define RZERO 76.63
    Congrats, you have calibrated the sensor and can now read the CO2 ppm value in your sketch
