Hi @berkseo. Thanks for the suggestion, but could you describe in more detail? As for my TODO list, there is already a task to add 485 interface to the gateway. My latest device "xRoom" have this interface.
ps/ Where have you gone?
I have been working on "xRoom" shield. A small announce:
Do you remember the discussion about multinode? So, it will be available soon))
@Ron said in Capacitive Soil Moisture Sensor:
@Puneit-Thukral Thanks. I am not quite sure, so correct me please if I am wrong, but I think I am already using the MiniCore bootloader with platformIO. Or do I need to configure to explicitly use the MiniCore bootloaders? Also I have set BOD to disabled as I read somewhere that no BOD can also save battery.
hi
I'm not sure, but I believe I'm already using the MiniCore bootloader with platformIO. Please tell me if I'm incorrect. Is it necessary to set the MiniCore bootloaders explicitly?
@bisschopsr I now have the schematics posted for all of my boards. I also posted another board for my in-wall scene controller line. Is there any other pics or information that you think might be useful to others for any of these boards?
@ricardot said in pimatic-mysensors controller plugin:
@Dheeraj,
Do you plan to continue to develop this plugin? I will very pleased to see a mysensors button. Thank you!
I second this. And also see if we can lose the dependency on serialport 2.0.6 so that we can use Node.js > 4.9.1
I have already published all the documentation, on my website, GitHub and openhardware.io
For now I leave the node as finished.
SmartHome: Wireless LED RGBW Controller – 00:55— giltesa
