[SOLVED] ESP8266 Gateway endless loop
  • Hi every one
    I'm looking for some help. I have ESP8266 setup as a gateway and was having some issues as can be seen in this post
    http://forum.mysensors.org/topic/2265/esp8266-gateway-can-t-press-start-for-inclusion/7
    I got around it with the fixes i had writen but have built a few more sensors so thought i would up date the gateway so I could add the sensors with out so much reflashing. I downloaded the Latest Dev branch and did a clean install of every thing then uploaded the basic ESP8266 gateway sketch.
    when it boots up i am getting the following from serial output
    ü! m!„þæÊõþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with home, channel 1
    dhcp client start...
    .ip:192.168.1.211,mask:255.255.255.0,gw:192.168.1.254
    .IP: 192.168.1.211
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    .IP: 192.168.1.211
    ü! m!BÿÄ1õþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    it just goes in a loop.
    Any help would be much appreciated
  • @Opus40
    I have exactly the same problem.
    I have some problem as well with the last 2.1.0 ESP8266 board files.
    You may want to try by downgrading to 2.0.0, work in my case.
  • @emc2
    Thank you. Worked for me too. 🙂
    But..before I downgraded to 2.0.0 I did a test with GatewayESP8266MQTTClient and that one did work with the 2.1.0 ESP8266 board version.
    So for me, with the latest bord files for the ESP:
    GatewayESP8266MQTTClient is OK
    GatewayESP8266 is not OK
    //Adam
  • thanks Emc2 and mille for the feed back, Ill give 2.0.0 a go
  • I had the same problem after updating to 2.1.0. I was getting wdt reset error, @Admin @hek could you please look into the issue???
  • Thanks going down to 2.0.0 worked for me.
  • Thanks - been racking by brain over this. Going back to 2.0.0 also works for me.
    @Opus40 enabling MY_USE_UDP in ESP8266 prevents wdt from barking (but obviously not a solution for the gw)
  • 24
