MQTT broker PIDOME : How setup MQTT Broker root
  • How to setup MQTT broker root ?
    ARDUINO 1.6.8
    MySENSORS ARDUINO LIBRARY V2.0.0-BETA
    ARDUINO UNO R3 + W5100 ETHERNETSHIELD + NRF24L01 LONG RANGE
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,178,87
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    ARDUINO NANO + NRF24L01
    DallasTemperature Sensor
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    #include <MyHwATMega328.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    #define RF24_CE_PIN 9 /*CE pin */
    #define RF24_CS_PIN 10 /* CS pin, using 10  */
    /* NRFRF24L01 radio driver (set high transmit power by default) */
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL);
    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
    MyHwATMega328 hw; /* Construct MySensors library */
    MySensor gw(radio, hw); /* Construct MySensors library */
    int numSensors=0;
    int node_id = 30; /* set node ID here for manual */
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
      sensors.begin();
      // Startup and initialize MySensors library. Set callback for incoming messages.
      gw.begin(NULL,node_id);
      gw.sendSketchInfo("Temperature Sensor", "1.1");
         gw.present(i, S_TEMP);
      // Process incoming messages (like config from server)
      gw.sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
          gw.send(msg.setSensor(i).set(temperature,1));
      gw.sleep(SLEEP_TIME);
    Serial log MQTTgateway
    Serial log sensor
    Pidome
  • 64
