Ethernet Gateway without NRF24L01+
  • Is possible create ethernet gateway to communicate directly with vera edge without driver NRF24L01 ?
    I want to connect the sensors directly on Arduino without wireless network, only the vera edge and connected Arduino via network cable.
    It's possible ? I have not found any example, I can not change the existing Ethernet controller code 😞
    Corrently Hardware :
    Vera Edge UI7
    Arduno Uno R3
    W5100 Ethernet Shield for Uno
    Motion Sensor (HC-SR501)
    2 Channel Relay - For Open Close garage door
  • Pinging @marceloaqno i remember he had something in the pipline. 😉
    Yes, use the development branch and move the relevant parts of the motion sensor to the GatewayW5100 sketch. With relevant, I mean the stuff inside setup() and loop().
    The gateway should not not be put into sleep, so you have to remove that line and make sure to send the value only when it changes from the last reading.
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/MotionSensor/MotionSensor.ino#L70
  • @hek
    // #define MY_RADIO_NRF24
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    //#define MY_RF24_CE_PIN 5
    //#define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,169   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_BUTTON_PIN  4
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
    void presentation()  {
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      //sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    dont work 😞
    Two problems.
    1. The sketch will flood the gateway with messages, You should only send when tripped value is updated.
    2. The error in Vera indicates a problem in communication with the gateway. Did you set it up correctly (ip address in Vera).
  • @hek
    Tks , I changed the code
        if (lastTripped != tripped ) {
          send(msg.set(tripped?"1":"0")); // Send new state and request ack back
          lastTripped=tripped;
    but vera continues with the same status 😞
    some additional info
  • @hek
    Ok , the message "cant decect device" has disappeared, however not appear the motion sensor, how can I make inclusion?
  • Connected but motion sensor not appear, someone help?
    @mlg
    Did you turn on inclusion mode on Vera and restart sensor a few times?
  • @hek
    Yes but Start the button does not work 😞
    I press but the state does not change, the start it is always green.
  • Any idea?
    Already I realized the factory reset Vera , erase the eeprom arduino and inclusion using the Pin 4, but no effect 😞
    the code that currently have the Arduino
    //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
      //#define MY_SOFTSPI
      //#define MY_SOFT_SPI_SCK_PIN 14
      //#define MY_SOFT_SPI_MISO_PIN 16
      //#define MY_SOFT_SPI_MOSI_PIN 15
    //#endif
    boolean lastTripped = 0;
    Strange...you are using the UI7 branch of the Vera plugin right?
    You could try commenting these two lines away:
    //  #define MY_INCLUSION_BUTTON_FEATURE
    //  #define MY_INCLUSION_MODE_BUTTON_PIN  4
    In case a floating pin causing troubles.
  • @hek
    Yes UI7 branch, I already commented these two lines and check the cables, when I press start button the rx and tx lights flashing
  • for restart sensor a few times, simply disconnect the gnd cable or all cables?
  • Isn't digital pin 4 used by the Ethernet shield?
    Probably not the cause of your problems but just noticed when looking over your code..
  • @einarth
    I already commented this line in the code , my final code
    //#endif
    @hek
    After other factory reset , start button now work !! but the inclusion no ! I press start and after 1 minute change automatically to stop.
  • Any Ideia?
    Inclusion mode is supposed to stop after 1 minute. So it sounds like communication between controller and gateway is fine.
    Did you reset the sensor node during inclusion mode was activated?
    Have you looked in the gateway debug log (while gateway is connected to your computer)?
  • @hek
    How I make sensor node reset ? Disconnected all cables ? digital pin 3 + gnd + 5v ?
    If I disconect all cables I log that
    0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
    IP: 192.168.1.169
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;5;1
    0;255;3;0;9;Eth:
  • @hek
    It's normal? If I disconnect the cables get 1/0/1/0 and not stopped
  • @hek
    I found one solution,I turn on sensor in ethernet gateway and press start inclusion and reload engine in Vera .In this way automatically add the sensor
    However compiled another code by adding a relay but is not added is something wrong?
    it is necessary void before, presentation ? and assign a child ID to RELAY ?
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    // #define MY_LEDS_BLINKING_FEATURE
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    #define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        sendSketchInfo("Motion Relay", "1.0");
        present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    I did'nt have much succes with the radiodevice, and i have made the gateway 🙂
    But have i missed the code eg for the sensors???
    Regards,
    Jan
  • 6
