Serial gateway with several sensors connected to it
  • I am new to the mysensor enviroment, but I have been using arduino for a long time now.
    So I have a smarthome setup with openhab rpi connected to an arduino nano 328p on serial.
    Currently I have 3 sensors(not sure if you can rgb strip sensor though) connected to the nano (gateway) and another nano connected over software serial to the gateway(node 1). So currently I am not using RF at all.
    So I have taken baby step and written 4 independent sketches for my nano and tested them succsessfully, however I now need to integrate them into openhab and hence I turned to mysensor. I tried reading up on the API and tutorials: http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
    so below are my four independent codes:
    https://github.com/skatun/Openhab/blob/master/Bar3.ino
    https://github.com/skatun/Openhab/blob/master/power7.ino
    https://github.com/skatun/Openhab/blob/master/rgb.ino
    https://github.com/skatun/Openhab/blob/master/IRsend.ino
    So I need to rewrite the code to send out/read in the Serial API and this is where I am bit stuck.
    So currently my send method of the powerMeter looks like:
     Serial.print(power);
        Serial.print(' ');
        Serial.println(pulseCount * whPerPulse);  // watt hour elapsed
    but can I just rewrite this to:
    gw.send(power);
    the other 3 sketches does not send anything but just receives messages from my RPI.
    So can anyone point me in the right direction of how to modify my code to fit inside the mysensor enviroment, or is mysensor to much overhead for my setup that i rather should use a simpler approach?
    Any help and hint would be great:)
    Welcome to MySensors! 😉
    There is no need to implement the serial API by yourself, just use the library.
    Start with this one: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerial/GatewaySerial.ino
    It is an example from the development branch, so you need the development library.
    If your node should be able to understand/receive MySensors implement the method "receive()":
    Have a look at: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/RelayActuator/RelayActuator.ino for an example on how to do that.
    Of course you need to strip the code from everything NRF related, because you won't need it, and will throw errors.
  • @TimO
    So I have made a sketch of my setup:
    I also started to modify the bar.ino code with the input from you:
    // Enable debug prints
    #define CHILD_ID_SPRIT 0
    #define CHILD_ID_WINE 1
    #SLEEP_TIME 0
    //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    // constants won't change. They're used here to
    // set pin numbers:
    const int buttonPinSpritOpp = 9;     // the number of the pushbutton pin
    const int buttonPinSpritNed = 12;     // the number of the pushbutton pin
    const int buttonPinVinOpp = 10;     // the number of the pushbutton pin
    const int buttonPinVinNed = 11;     // the number of the pushbutton pin
    const int ledPinSpritOpp = 4;     // the number of the pushbutton pin
    const int ledPinSpritNed = 8;     // the number of the pushbutton pin
    const int ledPinVinOpp = 7;     // the number of the pushbutton pin
    const int ledPinVinNed = 3;     // the number of the pushbutton pin
    const int motorPinVin =  A3;      // the number of the motor pin
    const int motorPinOnVin =A1;
    const int motorPinOnSprit = A2;//
    const int motorPinSprit =  A0;      // the number of the motor pin
    int intCode =-1;
    MyMessage msgHum(CHILD_ID_SPRIT, V_STATUS);
    MyMessage msgTemp(CHILD_ID_WINE, V_STATUS);
      // initialize the motor pin as an output:
      pinMode(motorPinSprit, OUTPUT);
      pinMode(motorPinVin, OUTPUT);
      pinMode(motorPinOnSprit, OUTPUT);
      pinMode(motorPinOnVin, OUTPUT);
      // initialize the pushbutton pin as an input:
      pinMode(buttonPinSpritOpp, INPUT_PULLUP);
      pinMode(buttonPinSpritNed, INPUT_PULLUP);
      pinMode(buttonPinVinOpp, INPUT_PULLUP);
      pinMode(buttonPinVinNed, INPUT_PULLUP);
       // Default values
      digitalWrite(motorPinSprit,HIGH);
      digitalWrite(motorPinVin,HIGH);
      digitalWrite(motorPinOnSprit, HIGH);
      digitalWrite(motorPinOnVin, HIGH);
      sendSketchInfo("BAR", "1.0");
      present(CHILD_ID_SPRIT, S_BINARY);
      present(CHILD_ID_WINE, S_BINARY);
       if ((digitalRead(buttonPinSpritOpp) == HIGH && digitalRead(buttonPinSpritNed) == LOW) || intCode==1) {
        digitalWrite(motorPinSprit,LOW);
        digitalWrite(motorPinOnSprit,LOW);
        digitalWrite(ledPinSpritOpp,HIGH);
        digitalWrite(ledPinSpritNed,LOW);
        send(msg.set(0));
        #ifdef MY_DEBUG
        Serial.println("Sprit opp");
      else if ((digitalRead(buttonPinSpritOpp) == LOW && digitalRead(buttonPinSpritNed) == HIGH)|| intCode==2) {
        digitalWrite(ledPinSpritNed,HIGH);
        digitalWrite(ledPinSpritOpp,LOW);
        send(msg.set(1));
        #ifdef MY_DEBUG
        Serial.println("Sprit ned");
      else{
        digitalWrite(motorPinOnSprit,HIGH);
      if ((digitalRead(buttonPinVinOpp) == HIGH && digitalRead(buttonPinVinNed) == LOW) || intCode==3) {
        digitalWrite(motorPinOnVin,LOW);
        digitalWrite(motorPinVin,LOW);
        digitalWrite(ledPinVinOpp,HIGH);
        digitalWrite(ledPinVinNed,LOW);
        send(msg.set(0));
        #ifdef MY_DEBUG
        Serial.println("Vin opp");
      else if ((digitalRead(buttonPinVinOpp) == LOW && digitalRead(buttonPinVinNed) == HIGH)|| intCode==4) {
        digitalWrite(ledPinVinNed,HIGH);
        digitalWrite(ledPinVinOpp,LOW);
        send(msg.set(1));
        #ifdef MY_DEBUG
        Serial.println("Vin ned");
      else {
        digitalWrite(motorPinOnVin,HIGH);
      if (intCode==0){
        #ifdef MY_DEBUG
        Serial.println("Shutting off");
      if (message.type==V_STATUS) {
         // Change relay state
         if message.sensor == CHILD_ID_SPRIT){
             if message.getBool(){
               intCode = 1;
             else{
               intCode = 2;
         if message.sensor == CHILD_ID_WINE){
               intCode = 3;
             else{
               intCode = 4;
         // Store state in eeprom
         //saveState(message.sensor, message.getBool());
    There are a few things unclear to me: How do I define the baudrate of the serial?
    Then its the actual sending to the gateway:
    send(msg.set(0));
    so how does this msg object work? I need two of these objects one for child node 1 and for child node 2 right?
    Then lets move to the RPI, This will then send out 1;2;3;0;2;1/n which then should send it to the gateway arduino which then parses this and send it out with baudrate 9600 on software serial on pin 11, which then will be received by the code above and the wine comes down.
    So how should my serial gateway sketch look like? And how do I get feedback from my node (rx pin 10 on due) back to RPI?
    Thanks for the tips so far:)
    @skatun I don't now if I understand your question... but will give it a try. Basic setup
    1. The MySensors gateway should talk to your controller (OpenHab) making use of the Serial protocol. You can use an Rpi to host your controller.
    2. any sensors you want to connect the the MySensors network should talk via this gateway to you controller.
    3. The MySensors network was/is designed to communicate via Radio (nRF24L01 and others) between the nodes and gateway. Recently it has been made possible to use wired communication (RS485).
    4. Sensors will be connected to the nodes and communicate with the gateway. In the development edition of MySensors you can also connect the sensors directy to the gateway.
    So from there on...
    1. The baud rate of the (HW) serial is defined in the MySensors library (default 115200).
    2. You use the send message like "send(messageHum.set(humvalue))" to send values from the sensor to the gateway (which sends it to the controller)
    Its defined in MyConfig.h and is normal set to 115200.
    send(msg.set(0));
    You can read some more here: http://www.mysensors.org/download/sensor_api_15#the-full-api
    Also check out the examples to figure out how it works.
    Two childs can be coded like this for example:
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    gw.present(BARO_CHILD, S_BARO);
    gw.present(TEMP_CHILD, S_TEMP);
    gw.send(pressureMsg.set(pressure, 0));
    Edit, Sorry @AWI didnt see your post there 🙂
  • @AWI
    1: Yes it is, baudrate 115200
    2: OK
    3: I am using software serial at 9600(long cables) instead of 485 because then i dont need extra hardware.
    4: yes, LDR,6 rgb strip,IR sender,IR emitter are connected directly
    So from there on...
    1: How to modify the code to use software serial instead of radio/485?
    2:
    bar.ino should then have:
    MyMessage msgWine(CHILD_ID_SPRIT, V_STATUS);
    //and in the loop
    gw.send(msgWine.set(0));
        #ifdef MY_DEBUG
    Now it will send that message out everytime the button is pressed, so I need to modify the code a bit to only send it out if it once every 12s(yes you need to hold the button for 12s to run the motor to the end.) I guess the best would be to rewrite the arduino code so that a single push on the button runs the motor for 12s instead of holding it in for 12s.
    Thanks for the help so far...
    @skatun I have never used a wired connection between two nodes but reading from the RS485 thread it sounds like this class is using the arduino HW serial implementation.
    Guess you will need to take a deep dive in the code to change this...
    @skatun: Have a look at this example: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino
    I don't think you have to change the code, just interconnect both Arduinos and keep in mind that PIN 2 is used by the library for DE-PIN management, which you don't need, but can't use for other things.
  • @TimO
    From the link:
    • Arduino Uno 9 8 10
    Can I not use rx/tx on my node arduino? (Pin 0/1)
    Same goes for my gateway, currently I am using pin 10/11. If I can fix this in software it would be better, then i dont have to resolder my setup, also what happens when you have two rs232 nodes connected to the gateway?
    In the example SoftSerial (a library) is used and not hardware serial (Pin 0/1).
    The node could use hardware serial, if you disable debug and look into the thread about RS485. If I recall it correctly there is a hardware serial implementation but you have to implement it yourself, this is not covered by the library.
    The GatewaySerialRS485 uses SoftSerial on the connection to the nodes and HardwareSerial on the connection to the controller.
    Node <-- (SoftSerial) --> Gateway <-- (HardSerial) --> Controller
    With RS485 you're able interconnect more than two devices and use DE_PIN before transmitting data. With RS232 you're limited to two devices or are in need of additional SoftSerial / HardSerial (and therefore additional PINs) depending on your hardware.
  • @TimO
    I will look into it, however first I need to get the gateway up running.
    So I am struggling to see how locally attached sensors work. I guess (reading several forum entry) that gw object is not needed. What is this inclusion mode? Is that part of the code needed?
    However I can not get my code to compile:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    #define CHILD_ID 9              // Id of the sensor child
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    boolean pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
        attachInterrupt(INTERRUPT, onPulse, RISING);
        lastSend=millis();
        gw.present(CHILD_ID, S_POWER,"Energy Meter");
      unsigned long now = millis();
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        if (!SLEEP_MODE && watt != oldWatt) {
          if (watt<((unsigned long)MAX_WATT)) {
            gw.send(wattMsg.set(watt));  // Send watt value to gw
          //Serial.print("Watt:");
          //Serial.println(watt);
          oldWatt = watt;
        // Pulse cout has changed
        if (pulseCount != oldPulseCount) {
          //gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        request(CHILD_ID, V_VAR1);
        lastSend=now;
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        //Serial.print("Received last pulse count from gw:");
        //Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh;
        lastBlink = newBlink;
      pulseCount++;
    @skatun it looks like you are mixing the development version 2.0 and master branch 1.5 syntax. In development the "class" setup is removed and therefore for "gw." is not used anymore.
    Most of the examples use the gw. Structure though. Look at the samples in the development branch as you will probably want/need the new functionality
  • @AWI
    So I copied ower evrything in the library folder of the development branch. When i then try to compile the serial gateway i get this error:
    Arduino: 1.6.7 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
    In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\examples\SerialGateway\SerialGateway.ino:50:0:
    C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:285:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\examples\SerialGateway\SerialGateway.ino:52:0:
    C:\Program Files (x86)\Arduino\libraries\PinChangeInt/PinChangeInt.h:103:19: fatal error: new.h: No such file or directory
       #include <new.h>
    compilation terminated.
    exit status 1
    Error compiling.
    @skatun It's hard to tell (for me ;-)) from the messages what is going wrong. Which Arduino are you programming for? Are you using the "GatewaySerial.ino" sketch from the development branch examples?
  • @AWI
    I just copied all the files in libraries and hardware in the development zip into c:\program files\Arduino\
    I am trying to get it to run on arduino due and yes I was trying the run the Serial gateway in Library\My Sensor\SerialGateway
  • @AWI How do I Install the development branch correctly? Does it only work with nano 328?
    Hi @skatun did you check this http://www.mysensors.org/about/arduino#installing-the-sensor-libraries ? You install it the same way but download it from https://github.com/mysensors/Arduino (press Download ZIP) and make sure its Branch: Development.
  • @sundberg84
    Well I tried to save it both here:
    C:\Program Files (x86)\Arduino\libraries\Mysensor
    C:\Program Files (x86)\Arduino\hardware\MySensors
    As well as here as described in your link:
    C:\Users\kim\Documents\Arduino
    But I get compile errors no matter where I try to compile serialgateway on due which I found in the C:\Program Files (x86)\Arduino\libraries\MySensors\examples\SerialGateway
    @skatun having the files in multiple folders isnt a good idea.
    Maybe you should remove the IDE and all folders and start over?
  • @sundberg84
    So the IDE by default get installed C:\Program Files (x86)\Arduino but the files folder get default set to this:
    I guess arduino made it that way so that you can load examples from C:\Program Files (x86)\Arduino then mess around with them and save them here C:\Users\kim\Documents\Arduino
    So I never had duplicate files, i tried both locations without sucsess. So which version of the IDE should I use? 1.6.7 is what I have now.
    @skatun Dont know if there are any version conflicts at the moment.
    I dont have the latest version.
  • @sundberg84
    So which directory should i put the files in? BOth hardware and library?
    I install the ide. download and extract mys to same path as ide. That's it.
  • @sundberg84
    I will then delete C:\Users\kim\Documents\Arduino which the ide creates.. Will upgrtade today, and let you know how it goes
  • @skatun
    Default libraries included in the IDE
    0_1459942591088_upload-a9ff62dc-42ba-4ef2-9f12-16091cd52ad0
    User libraries
    0_1459942680955_upload-c18bf0b4-2121-46ae-8fe3-d2441be6dedd
    Its not uncommon to have compile issues when:
    • The IDE is not restarted after uncompressing/copy file to the libraries
    • When upgrading MySensors without deleting the old version first
    I have Arduino IDE 1.6.4
  • @barduino
    Upgrading to Arduino 1.6.8 did the trick.
  • 24
