Bug in SenseBenderDefault sketch
    I was wondering why my SenseBender kept reporting every minute, even though the temperature and humidity didn't change.
    It's a minor one. But in the sendTempHumidityMeasurements(bool force) method, the difference is determined by dividing with 100 and not 100.0 this causes a wrong rounding and always reports a difference higher than the treshhold. Resulting in a temperature report every minute. Even though the temperature hasn't changed much.
    corrected code.
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      float oldAvgHum = raHum.getAverage();
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0); // <-- fixed
      float diffHum = abs(oldAvgHum - raHum.getAverage());
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        gw.send(msgTemp.set(temperature,1));
        gw.send(msgHum.set(humidity));
        lastHumidity = humidity;
    ps. I'm sorry I don't have a github account.
    nice catch!
    @mfalkvidd Thanx! It took my a while, but got it.
    Also, do I compile the Sketch for 8Mhz or 1Mhz?
    @hek so the real problem is too long release cycles, and/or not enough backporting?
    Yes! ๐Ÿ˜ง
    @TheoL
    the sensebender is runing on 8Mhz as default. Originally I made so that it could switch to 1Mhz in order to lower the current consumption. But since we are sleeping for 99% of the time, where it's only the watchdog timer that is running, I don't see that much of a power savings running at 1Mhz, compared to 8Mhz.
    In theory if running on 1Mhz the awaken time is also 8 times longer, than when it's running on 8Mhz.. So that can also contribute to a more "equal" power consumption.
    So in short.. Compile for 8Mhz ๐Ÿ™‚
  • 33
  • 17
