MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
@scalz If the OTA FW upload fails for whatever reason with MYSBootloader, it will reset and re-request a new FW, hence recovery is anytime possible.
@tekka : oki ...so lot of chance I will move to your bootloader, so no need to add eeprom footprint each time, that will give more space on pcb, cool! just for curiosity/knowledge I will look at your new code and try this very sexy bootloader
can't wait to see your rfm69 progress! same size? and what your thought about atsam bootloadr in future? (4k can limit a little bit 328p..)
really interesting, it's an awesome work you have done. great thx for this share
@scalz I think it's always a benefit to have additional eeprom or flash on your pcb for data storage. In terms of bootloader choice it totally depends on your case and preferences. MYSBootloader has some advantages over dualoptiboot, however, dualoptiboot offers more flexibility in an evolving system with e.g. changes of transmissions protocols. On top it is radio agnostic. In my current setup and during prototyping I prefer MYSBootloader over Dualoptiboot since many of my deployed nodes do not have additional external storage.
@tekka yep thx, I know but for some nodes I don't always need a datastorage and had the habits to add eeprom each time mainly for ota. And eeprom footprint is pretty big to place sometimes..but yes for datastorage it's cool. for the pros and cons, I agree with you, it depends of personal needs..
Have you already tried atsam boards with mysensors? I say this because I will assemble soon few atsam boards (atsamd but L family is picopower) I have designed, I will see if I'm able to port things in bootloadr but for the moment no time, too much things already in progress..in other hand, for nonpico, I'm waiting for esp32....
@scalz yes, just started working with atsam and bootloader development, although with limited bandwidth at the moment. More to come soon...
wow impressively cool
thx for your kindness, now I have homeworks to do!
see you soon
Sorry but I dont really get what you mean by freezy ?
You mean a code is compiled but it enters an infinite loop for example ?
yes that's it. a bug in your code, like infinite loop, ram troubles... that should be rare depending of your code. plus generally you/I test on breadboard before sending it in prod, but that can happen and is good to know
@scalz great.
This means that MYSBootloader can handle this problem and enter the bootloader mode even if the MCU freezes.@tekka you state that the current version can handle a freeze SW. Also if the new code is corrupted during programming by unverified CRC or whatever, it will also handle that problem and resets and wait for a new flashing order.
Is this new in this version ? I am some how sure that MYSBootloader previously had a problem handling thoses types of failures, and that's why I was going to use DualOptiboot as I read before that it can handle those failuresSorry for lots of questions but I am trying to reorganise my info.
So its working with a GatewayW5100MQTTClient aswell? That would be fantastic, I thought its only for serial and ethernet gateways. Do I also have to use port 5003?
@tekka If this can help for an RFM69 version :
https://github.com/vvvlc/Funky-FOTA
@rollercontainer confirmed working with W5100mqtt here!
I have to ask again: GatewayW5100MQTTClient or the old Broker Gateway?
I am not able to connect to my GatewayW5100MQTTClient on port 1883 or 5003 with MYSController 1.0.0beta.
The gateway is in working condition with openHAB.
Hello @ all
first thx to tekka for the great job
as the release notes say with the mysbootloader 1.3pre one can use the serial upload.
is its usable via the arduino ide? Because i can upload a sketch but it seems not to start.also as rollercontainer asked is the myscontroller application usable via the old broker or with the new clientmqtt gateway?
Would be nice if there are some instructions how to use
@n1ck1355 @rollercontainer MYSController does not support MQTT (at the moment), but have a look at MyController.org. Please provide more details regarding your issue with MYSBootloader 1.3pre.
thx tekka for clearing this
for my bootloader problem:
i burned the 1.3mysbootloader with the 8mhz config successfully from the arduino dev ide.
then i uploaded a little test sketch like this without errors:void setup() { Serial.begin(57600); Serial.println("Setup Start"); } void loop() { }
but there is no output on the serial monitor. it lookes like the bootloader didn't start the sketch.
I try to add new hex file in MYSController 1.0 but after clicking "reload repo", it tells me 2107-15-31 is not a valid date specification. I don't have the ability to select firmware after this. And after a reboot the "reload repo" is garyed.
Arduino ide 1.6.7
csv :Type,Name,Version,File,Comments 10,Blink,1,Blink.ino.hex,blinking example 20,TimeReporter,1,TimeReporter.ino.hex,TimeReporter demo 30,SenseBender,1,SensebenderMicro.ino.hex,Sensebender micro
Another 'bug". It always ask me to download a "new" version ... I install it but ask me again (1.0 beta)
I think this issue is related to the last arduino IDE version.
@Fabien Are you running MYSController on WINE? I updated a few things, please update to the most recent version of MYSController (build 3312, here or via update button) and post the log. Thanks.
@n1ck1355 Please enable logging in MYSController, reboot the node and post the log here after a few mins of recording.
Hi, i like OTA Update
How it is possible to change the Cannel from 76 to 105?
@rollercontainer said:
@Takero https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyConfig.h#L387
Yes, i know what, but this is not there I am looking for.
The Autor wrote:
Attached bootloader file, compiled with these settings:nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
115200 baud (16Mhz) or 57600 (8Mhz)I want a Bootloader file with Channel 105.
sorry, you are right. Since the source isnt yet available, you cant compile your custom bootloader. So, thats a no.
@tekka here is the log output:
05.04.16 21:51:34 STARTUP Initialize message logging 05.04.16 21:51:34 STARTUP 1.0.0 (build 3312) 05.04.16 21:51:34 STARTUP FPC 3.0.0 / Lazarus 1.6 05.04.16 21:51:34 STARTUP still under development :) tekka 2016 05.04.16 21:51:34 STARTUP Load INI file... 05.04.16 21:51:34 STARTUP INI version NA 05.04.16 21:52:08 INFO Connected to 192.168.0.101:5003 05.04.16 21:52:23 RX 2;255;3;0;15;0100 05.04.16 21:52:23 NODE New node discovered, node id=2 05.04.16 21:52:23 CHILD New child discovered, node id=2, child id=internal 05.04.16 21:52:30 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:52:30 DEBUG Undefined firmware/type for node=2 05.04.16 21:52:30 INFO BL version=258 05.04.16 21:52:30 INFO No FW assigned 05.04.16 21:52:36 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:52:36 DEBUG Undefined firmware/type for node=2 05.04.16 21:52:36 INFO BL version=258 05.04.16 21:52:36 INFO No FW assigned 05.04.16 21:52:43 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:52:43 DEBUG Undefined firmware/type for node=2 05.04.16 21:52:43 INFO BL version=258 05.04.16 21:52:43 INFO No FW assigned 05.04.16 21:53:00 RX 2;255;3;0;15;0100 05.04.16 21:53:07 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:53:07 DEBUG Undefined firmware/type for node=2 05.04.16 21:53:07 INFO BL version=258 05.04.16 21:53:07 INFO No FW assigned 05.04.16 21:53:14 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:53:14 DEBUG Undefined firmware/type for node=2 05.04.16 21:53:14 INFO BL version=258 05.04.16 21:53:14 INFO No FW assigned 05.04.16 21:53:21 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:53:21 DEBUG Undefined firmware/type for node=2 05.04.16 21:53:21 INFO BL version=258 05.04.16 21:53:21 INFO No FW assigned 05.04.16 21:53:38 RX 2;255;3;0;15;0100 05.04.16 21:53:45 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:53:45 DEBUG Undefined firmware/type for node=2 05.04.16 21:53:45 INFO BL version=258 05.04.16 21:53:45 INFO No FW assigned 05.04.16 21:53:52 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:53:52 DEBUG Undefined firmware/type for node=2 05.04.16 21:53:52 INFO BL version=258 05.04.16 21:53:52 INFO No FW assigned 05.04.16 21:53:58 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:53:58 DEBUG Undefined firmware/type for node=2 05.04.16 21:53:58 INFO BL version=258 05.04.16 21:53:58 INFO No FW assigned 05.04.16 21:54:16 RX 2;255;3;0;15;0100 05.04.16 21:54:23 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:54:23 DEBUG Undefined firmware/type for node=2 05.04.16 21:54:23 INFO BL version=258 05.04.16 21:54:23 INFO No FW assigned 05.04.16 21:54:29 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:54:29 DEBUG Undefined firmware/type for node=2 05.04.16 21:54:29 INFO BL version=258 05.04.16 21:54:29 INFO No FW assigned 05.04.16 21:54:36 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:54:36 DEBUG Undefined firmware/type for node=2 05.04.16 21:54:36 INFO BL version=258 05.04.16 21:54:36 INFO No FW assigned 05.04.16 21:54:54 RX 2;255;3;0;15;0100 05.04.16 21:55:01 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:55:01 DEBUG Undefined firmware/type for node=2 05.04.16 21:55:01 INFO BL version=258 05.04.16 21:55:01 INFO No FW assigned 05.04.16 21:55:07 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:55:07 DEBUG Undefined firmware/type for node=2 05.04.16 21:55:07 INFO BL version=258 05.04.16 21:55:07 INFO No FW assigned 05.04.16 21:55:14 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:55:14 DEBUG Undefined firmware/type for node=2 05.04.16 21:55:14 INFO BL version=258 05.04.16 21:55:14 INFO No FW assigned 05.04.16 21:55:32 RX 2;255;3;0;15;0100 05.04.16 21:55:38 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:55:38 DEBUG Undefined firmware/type for node=2 05.04.16 21:55:38 INFO BL version=258 05.04.16 21:55:38 INFO No FW assigned 05.04.16 21:55:45 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:55:45 DEBUG Undefined firmware/type for node=2 05.04.16 21:55:45 INFO BL version=258 05.04.16 21:55:45 INFO No FW assigned 05.04.16 21:55:52 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:55:52 DEBUG Undefined firmware/type for node=2 05.04.16 21:55:52 INFO BL version=258 05.04.16 21:55:52 INFO No FW assigned 05.04.16 21:56:10 RX 2;255;3;0;15;0100 05.04.16 21:56:16 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:56:16 DEBUG Undefined firmware/type for node=2 05.04.16 21:56:16 INFO BL version=258 05.04.16 21:56:16 INFO No FW assigned 05.04.16 21:56:23 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:56:23 DEBUG Undefined firmware/type for node=2 05.04.16 21:56:23 INFO BL version=258 05.04.16 21:56:23 INFO No FW assigned 05.04.16 21:56:30 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:56:30 DEBUG Undefined firmware/type for node=2 05.04.16 21:56:30 INFO BL version=258 05.04.16 21:56:30 INFO No FW assigned 05.04.16 21:56:47 RX 2;255;3;0;15;0100 05.04.16 21:56:54 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:56:54 DEBUG Undefined firmware/type for node=2 05.04.16 21:56:54 INFO BL version=258 05.04.16 21:56:54 INFO No FW assigned 05.04.16 21:57:01 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:57:01 DEBUG Undefined firmware/type for node=2 05.04.16 21:57:01 INFO BL version=258 05.04.16 21:57:01 INFO No FW assigned 05.04.16 21:57:07 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:57:07 DEBUG Undefined firmware/type for node=2 05.04.16 21:57:07 INFO BL version=258 05.04.16 21:57:07 INFO No FW assigned 05.04.16 21:57:25 RX 2;255;3;0;15;0100 05.04.16 21:57:32 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:57:32 DEBUG Undefined firmware/type for node=2 05.04.16 21:57:32 INFO BL version=258 05.04.16 21:57:32 INFO No FW assigned 05.04.16 21:57:39 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:57:39 DEBUG Undefined firmware/type for node=2 05.04.16 21:57:39 INFO BL version=258 05.04.16 21:57:39 INFO No FW assigned 05.04.16 21:57:45 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:57:45 DEBUG Undefined firmware/type for node=2 05.04.16 21:57:45 INFO BL version=258 05.04.16 21:57:45 INFO No FW assigned 05.04.16 21:58:03 RX 2;255;3;0;15;0100 05.04.16 21:58:10 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:58:10 DEBUG Undefined firmware/type for node=2 05.04.16 21:58:10 INFO BL version=258 05.04.16 21:58:10 INFO No FW assigned 05.04.16 21:58:16 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:58:16 DEBUG Undefined firmware/type for node=2 05.04.16 21:58:16 INFO BL version=258 05.04.16 21:58:16 INFO No FW assigned 05.04.16 21:58:23 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:58:23 DEBUG Undefined firmware/type for node=2 05.04.16 21:58:23 INFO BL version=258 05.04.16 21:58:23 INFO No FW assigned 05.04.16 21:58:41 RX 2;255;3;0;15;0100 05.04.16 21:58:45 USER Debug=FALSE 05.04.16 21:58:45 INFO *** Logging STOP *** 05.04.16 21:58:47 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:58:47 DEBUG Undefined firmware/type for node=2 05.04.16 21:58:47 INFO BL version=258 05.04.16 21:58:47 INFO No FW assigned 05.04.16 21:58:54 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:58:54 DEBUG Undefined firmware/type for node=2 05.04.16 21:58:54 INFO BL version=258 05.04.16 21:58:54 INFO No FW assigned 05.04.16 21:59:01 RX 2;255;4;0;0;FFFFFFFF0800077E0102 05.04.16 21:59:01 DEBUG Undefined firmware/type for node=2 05.04.16 21:59:01 INFO BL version=258 05.04.16 21:59:01 INFO No FW assigned
hope it helps finding out whats wrong
@tekka I try with build 3312 and working fine with wine
Now I'm looking for I_PRESENTATION. With 2.0 beta it doesn't seem to work. May I use smartSleep ?
So after few test, wrks fine with I_PRESENTATION request and using smartSleep (with interrupts too).
@tekka : do you have any clue whats wrong with my setup?
Does the gateway need the OTA firmware (flashed) written to it as well as the Nodes?
@n1ck1355 yes, probably there is a timing issue with serial uploads. Need to review the STK500 code. Can you confirm that OTA FW updates work fine?
@DrJeff No, only the nodes
@tekka Cool thanks, can I use Arduino as ISP to program bootloader?
@DrJeff Yep
@tekka , Time to try Thanks!
@tekka yes ota fw updates works. Tried it with the Time fw
@tekka i musst revert my previous post...
I've OTA uploaded the sketch from my first post:void setup() { Serial.begin(57600); Serial.println("Setup Start"); } void loop() { }
and i connected the board over Serial with my computer. After uploading the sketch i did not noticed any output on the serial monitor in the Arduino IDE. Also checked the transfer rate.
However the time reporter firmware works fine.
Is there a way to send ota firmware to node using some cli (python or...) script? I'm using MySensors with domoticz on RPi and when flashing new firmware I usually disconnect gw from rpi plug it into notebook and send fw using MYSController. If I could just disable gw in domoticz and send fw using some script it would be great until (if) domoticz gets support for ota fw.
I've just tried two 3,3V Pro Minis. Flashed the 8MHz MYSBootloader without problems (Nano as ISP). After that I connected the FTDI Adapter and programmed Blink and ReadAnalogVoltage examples without error. Both didn't worked on both Pro Minis. With original Bootloaders, they work.
Where is my fault?
@rollercontainer You have to provide additional information such as logs, etc. for troubleshooting
@tekka Serial not working after uploading MYSbootloader v1.3pre. ArduinoProMini 5v16Mhz. Is it normal?
@ะะปะตะบัะตะน-ะััะฐัะพะฒ please provide additional information such as config and logs.
@tekka
boards.txt:######## settings for ext XTAL 16Mhz, EESAVE, BOD1V8, no lock proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader proMYSBL16.upload.tool=avrdude proMYSBL16.upload.protocol=arduino proMYSBL16.upload.maximum_size=30720 proMYSBL16.upload.maximum_data_size=2048 proMYSBL16.upload.speed=115200 proMYSBL16.bootloader.tool=avrdude proMYSBL16.bootloader.low_fuses=0xFF proMYSBL16.bootloader.high_fuses=0xD2 proMYSBL16.bootloader.extended_fuses=0x06 proMYSBL16.bootloader.unlock_bits=0x3F proMYSBL16.bootloader.lock_bits=0x3F proMYSBL16.bootloader.file=MySensors/MYSBootloaderV13pre.hex proMYSBL16.build.mcu=atmega328p proMYSBL16.build.f_cpu=16000000L proMYSBL16.build.board=AVR_UNO proMYSBL16.build.core=arduino proMYSBL16.build.variant=standard ######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock proMYSBL8.name=ATmega328 internal 8Mhz with MYSBootloader proMYSBL8.upload.tool=avrdude proMYSBL8.upload.protocol=arduino proMYSBL8.upload.maximum_size=30720 proMYSBL8.upload.maximum_data_size=2048 proMYSBL8.upload.speed=57600 proMYSBL8.bootloader.tool=avrdude proMYSBL8.bootloader.low_fuses=0xE2 proMYSBL8.bootloader.high_fuses=0xD2 proMYSBL8.bootloader.extended_fuses=0x06 proMYSBL8.bootloader.unlock_bits=0x3F proMYSBL8.bootloader.lock_bits=0x3F proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex proMYSBL8.build.mcu=atmega328p proMYSBL8.build.f_cpu=8000000L proMYSBL8.build.board=AVR_UNO proMYSBL8.build.core=arduino proMYSBL8.build.variant=standard
MyConfig.h:
#ifdef MY_DISABLED_SERIAL #undef MY_DEBUG #endif #ifndef MY_BAUD_RATE #define MY_BAUD_RATE 115200 #endif //#define MY_DISABLE_REMOTE_RESET //#define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 //#define MY_RS485 #ifndef MY_NODE_ID #define MY_NODE_ID AUTO #endif #ifndef MY_PARENT_NODE_ID #define MY_PARENT_NODE_ID AUTO #endif // #define MY_REPEATER_FEATURE #ifndef MY_SMART_SLEEP_WAIT_DURATION #define MY_SMART_SLEEP_WAIT_DURATION 500 #endif //#define MY_OTA_FIRMWARE_FEATURE #ifndef MY_OTA_FLASH_SS #define MY_OTA_FLASH_SS 8 #endif #ifndef MY_OTA_FLASH_JDECID #define MY_OTA_FLASH_JDECID 0x1F65 #endif #ifndef MY_GATEWAY_MAX_RECEIVE_LENGTH #define MY_GATEWAY_MAX_RECEIVE_LENGTH 100 #endif #ifndef MY_GATEWAY_MAX_SEND_LENGTH #define MY_GATEWAY_MAX_SEND_LENGTH 120 #endif #ifndef MY_GATEWAY_MAX_CLIENTS #define MY_GATEWAY_MAX_CLIENTS 1 #endif //#define MY_LEDS_BLINKING_FEATURE //#define MY_WITH_LEDS_BLINKING_INVERSE //#define MY_DEFAULT_ERR_LED x //#define MY_DEFAULT_TX_LED x //#define MY_DEFAULT_RX_LED x //#define MY_INCLUSION_MODE_FEATURE //#define MY_INCLUSION_BUTTON_FEATURE #ifndef MY_INCLUSION_MODE_FEATURE #undef MY_INCLUSION_BUTTON_FEATURE #endif #ifndef MY_INCLUSION_MODE_BUTTON_PIN #if defined(ARDUINO_ARCH_ESP8266) #define MY_INCLUSION_MODE_BUTTON_PIN 5 #else #define MY_INCLUSION_MODE_BUTTON_PIN 3 #endif #endif #ifndef MY_INCLUSION_MODE_DURATION #define MY_INCLUSION_MODE_DURATION 60 #endif #if defined(MY_INCLUSION_BUTTON_EXTERNAL_PULLUP) #define MY_INCLUSION_BUTTON_PRESSED HIGH #else #define MY_INCLUSION_BUTTON_PRESSED LOW #endif //#define MY_SIGNING_ATSHA204 //#define MY_SIGNING_SOFT //#define MY_SIGNING_REQUEST_SIGNATURES #ifndef MY_VERIFICATION_TIMEOUT_MS #define MY_VERIFICATION_TIMEOUT_MS 5000 #endif //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}} #ifndef MY_SIGNING_ATSHA204_PIN #define MY_SIGNING_ATSHA204_PIN 17 #endif #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 #endif #ifndef MY_RS485_BAUD_RATE #define MY_RS485_BAUD_RATE 9600 #endif #ifndef MY_RS485_MAX_MESSAGE_LENGTH #define MY_RS485_MAX_MESSAGE_LENGTH 40 #endif //#define MY_RF24_ENABLE_ENCRYPTION #ifndef MY_RF24_CE_PIN #if defined(ARDUINO_ARCH_ESP8266) #define MY_RF24_CE_PIN 4 #elif defined(ARDUINO_ARCH_SAMD) #define MY_RF24_CE_PIN 27 #else #define MY_RF24_CE_PIN 9 #endif #endif #ifndef MY_RF24_CS_PIN #if defined(ARDUINO_ARCH_ESP8266) #define MY_RF24_CS_PIN 15 #elif defined(ARDUINO_ARCH_SAMD) #define MY_RF24_CS_PIN 3 #else #define MY_RF24_CS_PIN 10 #endif #endif #ifndef MY_RF24_PA_LEVEL #define MY_RF24_PA_LEVEL RF24_PA_MAX #endif #ifndef MY_RF24_CHANNEL #define MY_RF24_CHANNEL 76 #endif #ifndef MY_RF24_DATARATE #define MY_RF24_DATARATE RF24_250KBPS #endif #ifndef MY_RF24_BASE_RADIO_ID #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL) #endif //#define MY_SOFTSPI #ifndef MY_SOFT_SPI_SCK_PIN #define MY_SOFT_SPI_SCK_PIN 14 #endif #ifndef MY_SOFT_SPI_MISO_PIN #define MY_SOFT_SPI_MISO_PIN 16 #endif #ifndef MY_SOFT_SPI_MOSI_PIN #define MY_SOFT_SPI_MOSI_PIN 15 #endif #ifndef MY_RFM69_FREQUENCY #define MY_RFM69_FREQUENCY RF69_868MHZ #endif //#define MY_IS_RFM69HW #ifdef MY_IS_RFM69HW #define MY_RFM69HW true #else #define MY_RFM69HW false #endif #ifndef MY_RFM69_NETWORKID #define MY_RFM69_NETWORKID 100 #endif #ifndef MY_RF69_IRQ_PIN #define MY_RF69_IRQ_PIN RF69_IRQ_PIN #endif #ifndef MY_RF69_SPI_CS #define MY_RF69_SPI_CS RF69_SPI_CS #endif #ifndef MY_RF69_IRQ_NUM #if defined(ARDUINO_ARCH_ESP8266) #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN #else #define MY_RF69_IRQ_NUM RF69_IRQ_NUM #endif #endif //#define MY_RFM69_ENABLE_ENCRYPTION //#define MY_GATEWAY_W5100 //#define MY_GATEWAY_ENC28J60 //#define MY_GATEWAY_ESP8266 #ifndef MY_PORT #define MY_PORT 5003 #endif //#define MY_USE_UDP #ifndef MY_IP_RENEWAL_INTERVAL #define MY_IP_RENEWAL_INTERVAL 60000 #endif #ifndef MY_MAC_ADDRESS #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED #endif //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254 //#define MY_NODE_LOCK_FEATURE #ifndef MY_NODE_UNLOCK_PIN #define MY_NODE_UNLOCK_PIN 14 #endif #ifndef MY_NODE_LOCK_COUNTER_MAX #define MY_NODE_LOCK_COUNTER_MAX 5 #endif
In node scetch:
I have no logs from node because serial isn't working at all. Which logs should I attach?
@ะะปะตะบัะตะน-ะััะฐัะพะฒ I'll look into that. Seems like bootloader is not handing over to the sketch (corroborates previous reports). Can you post the OTA log (from e.g. MYSController)?
@tekka I'm using mycotroller.org instead of myscontroller. It writes that "firmware update initiated" and nothing happens.
@ะะปะตะบัะตะน-ะััะฐัะพะฒ Then I highly suggest to run MYSController to log OTA traffic for troubleshooting...
@tekka OK, I'll try to do it tomorrow.
@ะะปะตะบัะตะน-ะััะฐัะพะฒ in mycontroller.org you can get log under
Status >> Resources logs
. Changeitems per page
to 500 to display more number of logs.
@tekka I work for MyController.org and it supports firmware upload. Do I need to change anything to support
Currently MyController.org supports forMYSbootloader1.1
@ะะปะตะบัะตะน-ะััะฐัะพะฒ If you use
MYSbootloader
you shouldReboot
your node. AFAIK,MYSbootloader
requiresReboot
to get active.
You should configure firmware in node edit page and reboot the node.
Upload firmware
works only forDualOptiboot
@jkandasa I've tried to reboot and have such rsponce:
Apr 28, 2016 02:49:44 PM serial 0:GatewayNode Received Internal [Log message] send: 0-0-1-1 s=255,c=3,t=13,pt=0,l=0,sg=0,st=fail: Apr 28, 2016 02:49:44 PM serial 1:SensorNode Sent Internal [Reboot]
@ะะปะตะบัะตะน-ะััะฐัะพะฒ It looks like your node is not in the range!
It sends messages it really in is 0.5 meters from gw.
@ะะปะตะบัะตะน-ะััะฐัะพะฒ can you reboot the node manually?
@jkandasa
I have this:[Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006202 [Log message] send: 0-0-1-1 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:010002006302801481E090E00F90DF91CF910895FC01 [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006302 [Log message] send: 0-0-1-1 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:0100020064021382128248EE53E060E070E044835583 [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006402 [Log message] send: 0-0-1-1 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:0100020065026683778385ED91E09183808308951092 [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006502
And yes, it has been updated.
Thanks, OTA works now, allthought remote reboot doesn working.
@ะะปะตะบัะตะน-ะััะฐัะพะฒ I could not guess why remote reboot is not working! (Gateway says "Failed to send reboot command to node"). After OTA update completion, try reboot from MyController.org GUI. It may work with new software.
@jkandasa I've tried and it didn't help.
@ะะปะตะบัะตะน-ะััะฐัะพะฒ rebooting is only working if node is actively processing incoming msgs. Use wait() instead of sleep() within your loop()
@tekka @jkandasa
Thank you.
I've added#define MY_REPEATER_FEATURE
line in Node code, and it is working now.
Guys,
I'm trying to get this working on my ESP8266 gateway (using the latest development branch).
I've uploaded the 16mhz boot loader to an Arduino Nano clone but don't seem to see anything in MYScontroller. I realised that my gateway sketch had channel 125 specified, so took that out for testing as I believe the boot loader uses channel 76...
Do I need to change any fuse settings etc, what am I missing?
Many thanks in advance...
Mark
Edit: Got it working, fantastic!
Is there a way I can change the channel from the default 76?
Also am I correct in thinking that for my Nano's I copy the bits (high, low, extended, lock, unlock) from the Arduino section at the top and replace the pasted lines from the tutorial as it seems to be for the UNO?
is already answered in this therad...
http://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta/35
I have same problem as @n1ck1355. Shetch upload works, data are send, but serial output doesn't work.
I also have the same issues with no node serial output within the Arduino IDE....
@Mark-Swift @novas do you see any traffic over the air from that node? If yes, please post the log, specifically, I'm interested in bootloader messages.
@tekka I apologise, in my case it was the bootloader delay I wasn't allowing for. Opening the serial monitor and being patient, it appears all is well. Apologies for the mistake!
@tekka In my case there were two problems. First same as @Mark-Swift, bootloader deley. I didn't expect that it takes about 30 seconds. Second one was that my gateway didn't run. In this case bootloader is still running and serial output isn't provided.
@tekka I tried to upload a sketch after flashing the new bootloader to an nano. I got te this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4b
What is going on?
OTA update still testing. Updating for several minutes now (I thought the old bootloader and OTA update did not take that long).
@Anduril without additional information it's hard to troubleshoot - looks like a baud rate problem: please post logs from flashing (output when flashing bootlader), fuse settings, mysontroller log during node reboot, and other helpful information.
OK, I will post that information as soon as possible, today or tomorow.
Another thing, is it possible that OTA is much faster with the old BL? It took me few 10 minutes still sending firmware updates when I decided to flash the old one and try again. With the old one it was finished in about 5min. (times are only an estimation) Also frequency of new firmware requests in MYS Controller seemed much faster with old BL than with v1.3 pre. Is that normal or bug?
(had to split because of too long posts not allowed)
here the infos for troubleshooting:
board.txt:## ------------------------- nano.menu.cpu.atmega328=ATmega328 nano.menu.cpu.atmega328.upload.maximum_size=30720 nano.menu.cpu.atmega328.upload.maximum_data_size=2048 nano.menu.cpu.atmega328.upload.speed=57600 nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA nano.menu.cpu.atmega328.bootloader.extended_fuses=0x05 nano.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex nano.menu.cpu.atmega328.build.mcu=atmega328p ## Arduino Nano w/ ATmega328 MYSBootloader ## ------------------------- nano.menu.cpu.MYSBLatmega328=ATmega328 MYSBootloader nano.menu.cpu.MYSBLatmega328.upload.maximum_size=30720 nano.menu.cpu.MYSBLatmega328.upload.maximum_data_size=2048 nano.menu.cpu.MYSBLatmega328.upload.speed=57600 nano.menu.cpu.MYSBLatmega328.bootloader.low_fuses=0xFF nano.menu.cpu.MYSBLatmega328.bootloader.high_fuses=0xDA nano.menu.cpu.MYSBLatmega328.bootloader.extended_fuses=0x05 nano.menu.cpu.MYSBLatmega328.bootloader.file=MySensors/MYSBootloaderV13pre.hex nano.menu.cpu.MYSBLatmega328.build.mcu=atmega328p ## Arduino Nano w/ ATmega328 MYSBootloaderold ## ------------------------- nano.menu.cpu.MYSBLoldatmega328=ATmega328 MYSBootloader old nano.menu.cpu.MYSBLoldatmega328.upload.maximum_size=30720 nano.menu.cpu.MYSBLoldatmega328.upload.maximum_data_size=2048 nano.menu.cpu.MYSBLoldatmega328.upload.speed=57600 nano.menu.cpu.MYSBLoldatmega328.bootloader.low_fuses=0xFF nano.menu.cpu.MYSBLoldatmega328.bootloader.high_fuses=0xDA nano.menu.cpu.MYSBLoldatmega328.bootloader.extended_fuses=0x05 nano.menu.cpu.MYSBLoldatmega328.bootloader.file=MySensors/MYSBootloader.hex nano.menu.cpu.MYSBLoldatmega328.build.mcu=atmega328p
I copied the original entry for the Nano 328p and only changed bootloader files to old and new MYS Bootloader.
During flashing there is no debug output, only "Der Bootloader wurde gebrannt" ("burning bootloader finished) when done.
When powering node up I get these messages:1 10.05.2016 21:00:36 RX 0 - Gateway INTERNAL C_INTERNAL NO I_GATEWAY_READY Gateway startup complete. 2 10.05.2016 21:00:37 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.0.0-beta 3 10.05.2016 21:00:51 RX BROADCAST INTERNAL C_INTERNAL NO I_ID_REQUEST 4 10.05.2016 21:00:51 TX BROADCAST INTERNAL C_INTERNAL NO I_ID_RESPONSE 3 5 10.05.2016 21:00:55 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 6 10.05.2016 21:00:58 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 7 10.05.2016 21:01:01 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 8 10.05.2016 21:01:09 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 9 10.05.2016 21:01:13 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 10 10.05.2016 21:01:16 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 11 10.05.2016 21:01:20 TX 3 N/A C_INTERNAL NO I_REBOOT 0 12 10.05.2016 21:01:27 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFF2CC30102 13 10.05.2016 21:01:27 TX 3 N/A C_STREAM NO ST_FIRMWARE_CONFIG_RESPONSE 0A0001005000D446 14 10.05.2016 21:01:28 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004F00 15 10.05.2016 21:01:28 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004F00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 16 10.05.2016 21:01:28 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004E00 17 10.05.2016 21:01:28 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004E00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 18 10.05.2016 21:01:31 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004D00 19 10.05.2016 21:01:31 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004D00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20 10.05.2016 21:01:35 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004C00 21 10.05.2016 21:01:35 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004C00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 22 10.05.2016 21:01:35 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004B00 23 10.05.2016 21:01:35 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004B00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 24 10.05.2016 21:01:36 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004A00 25 10.05.2016 21:01:36 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004A00FFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26 10.05.2016 21:01:39 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004900 27 10.05.2016 21:01:39 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010049008B002097E1F30E940000F9CF0895F894 28 10.05.2016 21:01:43 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004800 29 10.05.2016 21:01:43 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010048006B010E943E020E947000C0E0D0E00E94 30 10.05.2016 21:01:43 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004700 31 10.05.2016 21:01:43 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010047000F90DF91CF911F910F91089508950E94 32 10.05.2016 21:01:47 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004600 33 10.05.2016 21:01:47 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004600611103C01095812301C0812B8C939FBF 34 10.05.2016 21:01:50 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004500 35 10.05.2016 21:01:50 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004500FF1FEC55FF4FA591B4919FB7F8948C91 36 10.05.2016 21:01:50 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004400 37 10.05.2016 21:01:50 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A000100440021F069830E94A6016981E02FF0E0EE0F 38 10.05.2016 21:01:54 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004300 39 10.05.2016 21:01:54 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010043001491F901E057FF4F04910023C9F08823 40 10.05.2016 21:01:57 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004200 41 10.05.2016 21:01:57 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A000100420030E0F901E859FF4F8491F901E458FF4F 42 10.05.2016 21:02:01 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004100 43 10.05.2016 21:02:01 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010041000F931F93CF93DF931F92CDB7DEB7282F 44 10.05.2016 21:02:05 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004000 45 10.05.2016 21:02:05 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004000F8948C91822B8C939FBFDF91CF910895 46 10.05.2016 21:02:05 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003F00 47 10.05.2016 21:02:05 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003F00322F309583238C938881822B888304C0 48 10.05.2016 21:02:08 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003E00 49 10.05.2016 21:02:08 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003E008C93888182230AC0623051F4F8948C91 50 10.05.2016 21:02:12 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003D00 51 10.05.2016 21:02:12 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003D00D4919FB7611108C0F8948C9120958223 52 10.05.2016 21:02:12 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003C00 53 10.05.2016 21:02:12 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003C00E255FF4FA591B4918C559F4FFC01C591 54 10.05.2016 21:02:13 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003B00 55 10.05.2016 21:02:13 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003B00FF4F8491882349F190E0880F991FFC01 56 10.05.2016 21:02:16 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003A00 57 10.05.2016 21:02:16 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003A00DF9390E0FC01E458FF4F2491FC01E057 58 10.05.2016 21:02:16 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003900 59 10.05.2016 21:02:16 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A000100390003C08091B0008F7D8093B0000895CF93 60 10.05.2016 21:02:17 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003800 61 10.05.2016 21:02:17 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A000100380002C084B58F7D84BD08958091B0008F77 62 10.05.2016 21:02:17 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003700 63 10.05.2016 21:02:17 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003700809180008F7780938000089584B58F77 64 10.05.2016 21:02:21 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003600 65 10.05.2016 21:02:21 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010036008830B9F08430D1F4809180008F7D03C0 66 10.05.2016 21:02:24 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003500 67 10.05.2016 21:02:24 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A000100350028F4813099F08230A1F008958730A9F0 68 10.05.2016 21:02:24 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003400 69 10.05.2016 21:02:24 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010034008081806880831092C1000895833081F0 70 10.05.2016 21:02:28 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003300 71 10.05.2016 21:02:28 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010033008460808380818260808380818E7F8083 72 10.05.2016 21:02:29 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003200 73 10.05.2016 21:02:29 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003200E0EBF0E0808181608083EAE7F0E08081 74 10.05.2016 21:02:30 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003100 75 10.05.2016 21:02:30 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003100808181608083E1EBF0E0808184608083 76 10.05.2016 21:02:31 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001003000 77 10.05.2016 21:02:31 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001003000808182608083808181608083E0E8F0E0 78 10.05.2016 21:02:31 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001002F00 79 10.05.2016 21:02:31 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001002F00EEE6F0E0808181608083E1E8F0E01082 80 10.05.2016 21:02:35 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001002E00 81 10.05.2016 21:02:35 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001002E00816084BD85B5826085BD85B5816085BD
which seem to be working OTA update, but not very fast (about 75 messages in 1 minute). Here to MYSController debug of that period:
10.05.2016 21:01:16 RX 3;255;4;0;0;FFFFFFFFFFFF2CC30102 10.05.2016 21:01:16 DEBUG Undefined firmware/type for node=3 10.05.2016 21:01:16 INFO BL version=258 10.05.2016 21:01:16 INFO No FW assigned 10.05.2016 21:01:20 TX 3;0;3;0;13;0 10.05.2016 21:01:20 INFO FW "Blink" assigned to node 3 10.05.2016 21:01:27 RX 3;255;4;0;0;FFFFFFFFFFFF2CC30102 10.05.2016 21:01:27 CHILD New child discovered, node id=3, child id=internal 10.05.2016 21:01:27 DEBUG Undefined firmware/type for node=3 10.05.2016 21:01:27 INFO BL version=258 10.05.2016 21:01:27 INFO Send FW info to node 3: type=A, version=1, blocks=0x0050, CRC=0x46D4 10.05.2016 21:01:27 TX 3;0;4;0;1;0A0001005000D446 10.05.2016 21:01:28 RX 3;255;4;0;2;0A0001004F00 10.05.2016 21:01:28 DEBUG FW update started, node id = 3 10.05.2016 21:01:28 TX 3;255;4;0;3;0A0001004F00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10.05.2016 21:01:28 RX 3;255;4;0;2;0A0001004E00 10.05.2016 21:01:28 TX 3;255;4;0;3;0A0001004E00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10.05.2016 21:01:31 RX 3;255;4;0;2;0A0001004D00 10.05.2016 21:01:31 TX 3;255;4;0;3;0A0001004D00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10.05.2016 21:01:35 RX 3;255;4;0;2;0A0001004C00 10.05.2016 21:01:35 TX 3;255;4;0;3;0A0001004C00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10.05.2016 21:01:35 RX 3;255;4;0;2;0A0001004B00 10.05.2016 21:01:35 TX 3;255;4;0;3;0A0001004B00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10.05.2016 21:01:36 RX 3;255;4;0;2;0A0001004A00 10.05.2016 21:01:36 TX 3;255;4;0;3;0A0001004A00FFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10.05.2016 21:01:39 RX 3;255;4;0;2;0A0001004900 10.05.2016 21:01:39 TX 3;255;4;0;3;0A00010049008B002097E1F30E940000F9CF0895F894 10.05.2016 21:01:43 RX 3;255;4;0;2;0A0001004800 10.05.2016 21:01:43 TX 3;255;4;0;3;0A00010048006B010E943E020E947000C0E0D0E00E94 10.05.2016 21:01:43 RX 3;255;4;0;2;0A0001004700 10.05.2016 21:01:43 TX 3;255;4;0;3;0A00010047000F90DF91CF911F910F91089508950E94 10.05.2016 21:01:47 RX 3;255;4;0;2;0A0001004600 10.05.2016 21:01:47 TX 3;255;4;0;3;0A0001004600611103C01095812301C0812B8C939FBF 10.05.2016 21:01:50 RX 3;255;4;0;2;0A0001004500 10.05.2016 21:01:50 TX 3;255;4;0;3;0A0001004500FF1FEC55FF4FA591B4919FB7F8948C91 10.05.2016 21:01:50 RX 3;255;4;0;2;0A0001004400 10.05.2016 21:01:50 TX 3;255;4;0;3;0A000100440021F069830E94A6016981E02FF0E0EE0F 10.05.2016 21:01:54 RX 3;255;4;0;2;0A0001004300 10.05.2016 21:01:54 TX 3;255;4;0;3;0A00010043001491F901E057FF4F04910023C9F08823 10.05.2016 21:01:57 RX 3;255;4;0;2;0A0001004200 10.05.2016 21:01:57 TX 3;255;4;0;3;0A000100420030E0F901E859FF4F8491F901E458FF4F 10.05.2016 21:02:01 RX 3;255;4;0;2;0A0001004100 10.05.2016 21:02:01 TX 3;255;4;0;3;0A00010041000F931F93CF93DF931F92CDB7DEB7282F 10.05.2016 21:02:05 RX 3;255;4;0;2;0A0001004000 10.05.2016 21:02:05 TX 3;255;4;0;3;0A0001004000F8948C91822B8C939FBFDF91CF910895 10.05.2016 21:02:05 RX 3;255;4;0;2;0A0001003F00 10.05.2016 21:02:05 TX 3;255;4;0;3;0A0001003F00322F309583238C938881822B888304C0 10.05.2016 21:02:08 RX 3;255;4;0;2;0A0001003E00 10.05.2016 21:02:08 TX 3;255;4;0;3;0A0001003E008C93888182230AC0623051F4F8948C91 10.05.2016 21:02:12 RX 3;255;4;0;2;0A0001003D00 10.05.2016 21:02:12 TX 3;255;4;0;3;0A0001003D00D4919FB7611108C0F8948C9120958223 10.05.2016 21:02:12 RX 3;255;4;0;2;0A0001003C00 10.05.2016 21:02:12 TX 3;255;4;0;3;0A0001003C00E255FF4FA591B4918C559F4FFC01C591 10.05.2016 21:02:13 RX 3;255;4;0;2;0A0001003B00 10.05.2016 21:02:13 TX 3;255;4;0;3;0A0001003B00FF4F8491882349F190E0880F991FFC01 10.05.2016 21:02:16 RX 3;255;4;0;2;0A0001003A00 10.05.2016 21:02:16 TX 3;255;4;0;3;0A0001003A00DF9390E0FC01E458FF4F2491FC01E057 10.05.2016 21:02:16 RX 3;255;4;0;2;0A0001003900 10.05.2016 21:02:16 TX 3;255;4;0;3;0A000100390003C08091B0008F7D8093B0000895CF93 10.05.2016 21:02:17 RX 3;255;4;0;2;0A0001003800 10.05.2016 21:02:17 TX 3;255;4;0;3;0A000100380002C084B58F7D84BD08958091B0008F77 10.05.2016 21:02:17 RX 3;255;4;0;2;0A0001003700 10.05.2016 21:02:17 TX 3;255;4;0;3;0A0001003700809180008F7780938000089584B58F77 10.05.2016 21:02:21 RX 3;255;4;0;2;0A0001003600 10.05.2016 21:02:21 TX 3;255;4;0;3;0A00010036008830B9F08430D1F4809180008F7D03C0 10.05.2016 21:02:24 RX 3;255;4;0;2;0A0001003500 10.05.2016 21:02:24 TX 3;255;4;0;3;0A000100350028F4813099F08230A1F008958730A9F0 10.05.2016 21:02:24 RX 3;255;4;0;2;0A0001003400 10.05.2016 21:02:24 TX 3;255;4;0;3;0A00010034008081806880831092C1000895833081F0 10.05.2016 21:02:28 RX 3;255;4;0;2;0A0001003300 10.05.2016 21:02:28 TX 3;255;4;0;3;0A00010033008460808380818260808380818E7F8083 10.05.2016 21:02:29 RX 3;255;4;0;2;0A0001003200 10.05.2016 21:02:29 TX 3;255;4;0;3;0A0001003200E0EBF0E0808181608083EAE7F0E08081 10.05.2016 21:02:30 RX 3;255;4;0;2;0A0001003100 10.05.2016 21:02:30 TX 3;255;4;0;3;0A0001003100808181608083E1EBF0E0808184608083 10.05.2016 21:02:31 RX 3;255;4;0;2;0A0001003000 10.05.2016 21:02:31 TX 3;255;4;0;3;0A0001003000808182608083808181608083E0E8F0E0 10.05.2016 21:02:31 RX 3;255;4;0;2;0A0001002F00 10.05.2016 21:02:31 TX 3;255;4;0;3;0A0001002F00EEE6F0E0808181608083E1E8F0E01082 10.05.2016 21:02:35 RX 3;255;4;0;2;0A0001002E00 10.05.2016 21:02:35 TX 3;255;4;0;3;0A0001002E00816084BD85B5826085BD85B5816085BD
When uploading standard BlinkWithoutDelay sketch I get this:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Mat\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Mat\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Mat\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=MYSBLatmega328 -ide-version=10607 -build-path "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino" C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Mat\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Mat\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Mat\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=MYSBLatmega328 -ide-version=10607 -build-path "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino" WARNUNG: Kategorie '' in der Bibliothek UIPEthernet ist ungรผltig und wird auf 'Uncategorized' festgelegt "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "nul" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "nul" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.S.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WInterrupts.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\hooks.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\hooks.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_analog.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_analog.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_digital.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_digital.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_shift.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_shift.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\CDC.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\CDC.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial0.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial0.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial1.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial1.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial2.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial2.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial3.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial3.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\IPAddress.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\IPAddress.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\PluggableUSB.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\PluggableUSB.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Print.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Print.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Stream.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Stream.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Tone.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Tone.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\USBCore.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\USBCore.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WMath.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WMath.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WString.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WString.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\abi.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\abi.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\main.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\main.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\new.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\new.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.S.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WInterrupts.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\hooks.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_analog.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_digital.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_shift.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\CDC.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial0.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial1.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial2.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial3.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\IPAddress.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\PluggableUSB.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Print.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Stream.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Tone.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\USBCore.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WMath.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WString.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\abi.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\main.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\new.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.elf" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp.o" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/core\core.a" "-LC:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp" -lm "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.elf" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.eep" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.elf" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.hex" Der Sketch verwendet 1.006 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes. Globale Variablen verwenden 15 Bytes (0%) des dynamischen Speichers, 2.033 Bytes fรผr lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes. avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4b avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4b
I noticed that the baudrate in my boards.txt was not set to 115200 as in your guide. I changed this and reburned the bootloader, still the same result.
With the old bootloader flashing works the same way. When powered up the log is as normal:
82 10.05.2016 21:11:11 RX 0 - Gateway INTERNAL C_INTERNAL NO I_GATEWAY_READY Gateway startup complete. 83 10.05.2016 21:11:12 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.0.0-beta 84 10.05.2016 21:11:28 RX BROADCAST INTERNAL C_INTERNAL NO I_ID_REQUEST 85 10.05.2016 21:11:28 TX BROADCAST INTERNAL C_INTERNAL NO I_ID_RESPONSE 3 86 10.05.2016 21:11:28 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFFFFFF0101 87 10.05.2016 21:11:30 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFFFFFF0101 88 10.05.2016 21:11:32 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFFFFFF0101 89 10.05.2016 21:11:34 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFFFFFF0101 90 10.05.2016 21:11:36 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFFFFFF0101 91 10.05.2016 21:11:37 TX 3 N/A C_INTERNAL NO I_REBOOT 0 92 10.05.2016 21:11:41 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST FFFFFFFFFFFFFFFF0101 93 10.05.2016 21:11:41 TX 3 N/A C_STREAM NO ST_FIRMWARE_CONFIG_RESPONSE 0A0001005000D446 94 10.05.2016 21:11:42 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004F00 95 10.05.2016 21:11:42 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004F00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 96 10.05.2016 21:11:42 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004E00 97 10.05.2016 21:11:42 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004E00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98 10.05.2016 21:11:42 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001004D00 99 10.05.2016 21:11:42 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A0001004D00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF [.....] 250 10.05.2016 21:12:21 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001000200 251 10.05.2016 21:12:21 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010002000C946E000C946E000C946E000C946E00 252 10.05.2016 21:12:21 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001000100 253 10.05.2016 21:12:21 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010001000C946E000C946E000C946E000C946E00 254 10.05.2016 21:12:22 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_REQUEST 0A0001000000 255 10.05.2016 21:12:22 TX 3 INTERNAL C_STREAM NO ST_FIRMWARE_RESPONSE 0A00010000000C945C000C946E000C946E000C946E00 256 10.05.2016 21:12:23 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST 0A0001005000D4460101 257 10.05.2016 21:12:23 TX 3 N/A C_STREAM NO ST_FIRMWARE_CONFIG_RESPONSE 0A0001005000D446 258 10.05.2016 21:12:43 RX 3 INTERNAL C_STREAM NO ST_FIRMWARE_CONFIG_REQUEST 0A0001005000D4460101 259 10.05.2016 21:12:43 TX 3 N/A C_STREAM NO ST_FIRMWARE_CONFIG_RESPONSE 0A0001005000D446
with all messages transfered in about 40s (about 150 messages, ~3 times faster)
Hope this helps to find the problem. If you need more information just let me know.
@Anduril Is your nano running at 16 or 8Mhz? Also, is the node next to the GW or is a repeater in between?
@tekka I only copied the standard fuses (no 1/8 divider) and I think it is running on 16Mhz. Might be good to try with different baudrate for the 8Mhz version.
But still, do you know why the OTA transfer is slower by a factor of 3?
The sketch for my current project is quite big and needs several minutes to transfer. With serial upload working this would be much faster, but I have to unplug the nano from the circuit to reach the usb port. So fast OTA upload would be best.
@Anduril I had problems with 8MHz with 3,3V and 115200kBPS. I only use 38400kBPS with my 8MHz nodes. (Of cause your Bootloader must also be set to the same Baudrate as specified in the board.txt, they must match, i.e. you cannot just change the Boards.txt and have another Baudrate for programming.)
I'm not sure if @tekka is providing a Bootloader hex file with 38400kBPS and 8MHz. From his first post I'm assuming he ueses a 57600kBPS with 8MHz. This might also work, however 57600kBPS with 8MHz introduces a baud rate error of 3.5% which sometimes causes problems with my PC/FTDI Dongle. So I personally use 38400kBPS which only has 0.2% Error: http://wormfood.net/avrbaudcalc.php (fosc=8MHz)
Hi. @tekka thanks for your works, OTA fw updates works very well (using MYSBootloader 1.3pre), but i've one question, after OTA updates successful and node running the sketch without error, how to update the fw using new ones? e.g an updated version of the sketch.
I'm using MyController.org for controller by @jkandasa . So I ask to both of you.thanks.
@Anduril a factor 3 slower is a bit surprizing, in my hands the new bootloader performs even better than the old one. Do you have a repeater in between or are GW and the node close together? As @Dirk_H pointed out, the current .hex was compiled for 16Mhz (and is also compatible with 8Mhz) but I
will prepare a separate 8Mhz version and 38.4kBaud for testing.
I have just started to update all my nodes to 2.0.0 dev.
Started to update my serial gateway then update MYSController to 1.0.0beta and use the bootloader MYSBootloaderV13pre.hex
First i could't burn the bootloader to my Arduino Pro Mini 5v, needed to changed the values in board.txt:
From this:proMYSBL16.bootloader.low_fuses=0xFF proMYSBL16.bootloader.high_fuses=0xD2 proMYSBL16.bootloader.lock_bits=0x3F
To this:
proMYSBL16.bootloader.low_fuses=0xF7 proMYSBL16.bootloader.high_fuses=0xDA proMYSBL16.bootloader.lock_bits=0x0F
It took about 50min to use OTA to upload a simple sketch for a humidity sensor with MYSController.
I have the gateway and the sensor very close (about 10cm from each other).
@ErrK Fuses have to be adjusted according to HW specifications, e.g. crystal vs. internal RC oscillator settings etc. Your new high fuse (clearing EESAVE) cleared the node settings in the eeprom after flashing the new bootloader (did you use your node as GW before?). 10cm between node and GW is far too close causing radio interferences - you may get better results by moving them further away.
@tekka Thanks. It's working when i move them further away.
@tekka did some testing again. I don't have a repeater inbetween, but maybe they were to close to each other (~30cm).
I repeated the tests a few times:
when on my desk the new bootloader is significantly slower than the old one.
When 2m away I don't see many messages arriving. Maybe my power suply used when not at my pc was not stable enough to give the current for sending with pa-lna. I will repeat the tests with a improved setup the next days.
Can I give you specific information where the problem is? Maybe a special log or anything else to help find the problem?
@Anduril hmm...I'm not experiencing any speed issues with the new bootloader. Can you activate debug on your GW and post the log while running OTA updates?
@tekka here the serial monitor while OTA upload with
0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok: 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0 0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail: 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail: 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706 0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail: 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0 0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail: 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5 0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102 0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5 0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5
@Anduril There are some communication issues here, i.e. the node radio doesn't not appear to receive msgs. If you put GW and node further away, different position, away from interference sources (wifi, speaker, monitor, etc.) do you see any improvements? Also you should try with different radios, larger caps, decoupling caps, stable PSU or batteries. What type of nRF24 are you using? Genuine, Clones (blob-version?).
@tekka I tried a few combinations: different positions (nearest ~20cm, farest ~5m with walls), radios (probably clones, but no blobs, nRF from mysensors store and others, also pa+lna for gateway) and different caps with no success. Still quite a lot of packages lost during transmision.
I then reflashed the old bootloader again and it worked flawless for 5m and 20cm.
@Anduril Can you re-test this version of MYSBootloader (16Mhz, CH76, 250kbp) with the most recent dev 2.0.0 version (i.e. GW), clearing EEPROM before flashing is advisable. In my setup, I get pretty decent data rates for OTA updates...
@tekka I will test this asap (hopefully this weekend). One point for clearing EEPROM: do you know if the sketch also works on the ESP8266? Because I thought to have cleared the EEPROM and uploaded a sketch without wifi config, but it still connected to my wifi.
@tekka I did test your new bootloader, with no success. I also tried to use the nano with 8Mhz internal clock, but same result.
Here again the serial debug of my ESP8266 gateway:
With the new bootloader:0;255;3;0;9;read: 5-5-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok: 0;255;3;0;9;read: 5-5-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFAA160102 0;255;3;0;9;Client 0: 5;0;4;0;1;6E000100000819CC 0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=ok:6E000100000819CC 0;255;3;0;9;read and forward: 5-5-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0 0;255;3;0;9;read: 5-5-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok: 0;255;3;0;9;read: 5-5-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFAA160102 0;255;3;0;9;Client 0: 5;0;4;0;1;6E000100000819CC 0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E000100000819CC 0;255;3;0;9;read: 5-5-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFAA160102 0;255;3;0;9;Client 0: 5;0;4;0;1;6E000100000819CC 0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=ok:6E000100000819CC 0;255;3;0;9;read and forward: 5-5-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0 0;255;3;0;9;read: 5-5-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok: 0;255;3;0;9;read: 5-5-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFAA160102 0;255;3;0;9;Client 0: 5;0;4;0;1;6E000100000819CC 0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=ok:6E000100000819CC 0;255;3;0;9;read and forward: 5-5-255 s=255,c=3,t=7,pt=1,l=0,sg=0 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0 0;255;3;0;9;read: 5-5-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok: 0;255;3;0;9;read: 5-5-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFAA160102 0;255;3;0;9;Client 0: 5;0;4;0;1;6E000100000819CC 0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=ok:6E000100000819CC
with the old bootloader:
0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FD07 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FD070895262FF999FECF92BD81BDF89A0197 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FD070895262FF999FECF92BD81BDF89A0197 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FC07 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FC07CB01840F951F2E9105D041505040D8F7 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FC07CB01840F951F2E9105D041505040D8F7 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FB07 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FB07B8F70895DC01A40FB51F4150504040F0 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FB07B8F70895DC01A40FB51F4150504040F0 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FA07 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FA07F2BDE1BDF89A319600B40D9241505040 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FA07F2BDE1BDF89A319600B40D9241505040 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F907 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F90711240895DC01CB01FC01F999FECF06C0 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F90711240895DC01CB01FC01F999FECF06C0 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F807 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F807990B08957AE0979F902D879F802D910D 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F807990B08957AE0979F902D879F802D910D 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F707 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F7078D910190801921F441505040C8F7881B 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F7078D910190801921F441505040C8F7881B 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F607 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F6071EF4909581959F4F0895FB01DC0104C0 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F6071EF4909581959F4F0895FB01DC0104C0 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F507 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F50703C018D0820F911D219120532A30C8F3 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F50703C018D0820F911D219120532A30C8F3 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F407 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F40710F02E30C8F32B3239F02D3231F46894 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F40710F02E30C8F32B3239F02D3231F46894 0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F307 0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F307FC0188279927E89421912032E9F32930 0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F307FC0188279927E89421912032E9F32930
just for completeness my settings for burning the old bootloader:
nano.name=Arduino Nano nano.upload.tool=avrdude nano.upload.protocol=arduino nano.bootloader.tool=avrdude nano.bootloader.unlock_bits=0x3F nano.bootloader.lock_bits=0x0F nano.build.f_cpu=16000000L nano.build.board=AVR_NANO nano.build.core=arduino nano.build.variant=eightanaloginputs nano.menu.cpu.MYSBLoldatmega328=ATmega328 MYSBootloader old nano.menu.cpu.MYSBLoldatmega328.upload.maximum_size=30720 nano.menu.cpu.MYSBLoldatmega328.upload.maximum_data_size=2048 nano.menu.cpu.MYSBLoldatmega328.upload.speed=115200 nano.menu.cpu.MYSBLoldatmega328.bootloader.low_fuses=0xFF nano.menu.cpu.MYSBLoldatmega328.bootloader.high_fuses=0xDA nano.menu.cpu.MYSBLoldatmega328.bootloader.extended_fuses=0x05 nano.menu.cpu.MYSBLoldatmega328.bootloader.file=MySensors/MYSBootloader.hex
And to note something I noticed (but don't know if it's related): sometimes the MYSController loses it's connection to the gateway. Serial monitor is still printing values but nothing in MYSController. When I reconnect the Controller it is working again.
edit: and is it normal that a sketch needs more than 20 min to upload? I mean the sketch is quite big (>70% of max), but it seems to be to long even with the old (for me faster) bootloader.
edit2: one hour and about 24k messages (MsgID in MYSController) later my node is still updating...
Did any one able to make this work with atmega328p-PU 28 DIP 8MHz internal clock? or is it just me having problems with this boot loader?
I was able to load the boot loader successfully and able to upload a sketch but then nothing happen, i see nothing in the serial port (default 115200) and the gateway does not find any node.
I am using latest dev branch of 2.0 and the boot loader from this thread.
Just for compression i loaded another boot loader for 8MHz internal clock (Arduino on breadboard) and uploaded a sketch to it and it worked perfectly communicating with the gateway.
I want to be able to upload OTA.
AM i doing something wrong? does this boot loader even supports this MCU?
I have a node with the NRF already soldered. Since Arduino as ISP uses some of the pins used by the NRF, is there anything I can do to flash the bootloader without unsoldering the NRF? Thanks!
@abmantis You can just solder ISP wires to arduino without disconneting NRF. It's programming well (I've already tested this solution with my network)
@ะะปะตะบัะตะน-ะััะฐัะพะฒ Thank you! Will try that soon
Any updates regarding the bootloader?
I managed to use the bootloader with version 2.0, thanks.
Yeah, the bootloader works well with the v2.0 release.
The major issue it has currently is that sometimes it takes quite a long time to flash a sketch. It seems that when the wireless connection is not perfect, it stops for 2 or 3 seconds multiple times. Like, send 10 packages, stop 3 seconds, send 5 packages, stop again.
any news about 1.3 final release?
@tekka
I used the MYSBootloader 1.3pre with version 2.0.0
I managed to upload FW to nodes with MYSController.As mention:
"supports OTA FW AND serial FW updates"But I cannot get anything to serial port with the nodes.
Is the serial option really works on this bootloader?
the specs:
1.board - my own developed board with atmega328p au without external clock.
2.board.txt:######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock proMYSBL8.name=ATmega328 internal 8Mhz with MYSBootloader proMYSBL8.upload.tool=avrdude proMYSBL8.upload.protocol=arduino proMYSBL8.upload.maximum_size=30720 proMYSBL8.upload.maximum_data_size=2048 proMYSBL8.upload.speed=57600 proMYSBL8.bootloader.tool=avrdude proMYSBL8.bootloader.low_fuses=0xE2 proMYSBL8.bootloader.high_fuses=0xD2 proMYSBL8.bootloader.extended_fuses=0x06 proMYSBL8.bootloader.unlock_bits=0x3F proMYSBL8.bootloader.lock_bits=0x3F proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex proMYSBL8.build.mcu=atmega328p proMYSBL8.build.f_cpu=8000000L proMYSBL8.build.board=AVR_UNO proMYSBL8.build.core=arduino proMYSBL8.build.variant=standard
- the bootloader hex file is : MYSBootloaderV13pre.hex from MYSController 1.0.0beta
So is serial possible or/and should I change something?
@Mickey :
It's the same problem i've posted about 4 months ago here.. i also cant run sketches i've uploaded via serial..
i hope it is solved with a new release...maybe the final already @tekka?
